Question about AT&T Lands Phones
Disabled phone line
Recently a local lightning strike created a power surge which fried my answering machine. I purchased a new AT&T standalone machine and, after hooking it up into the single line phone system, it will work perfectly for about 2 hours, then for some reason the phone lines inside the house will go dead (callers hear a busy signal). if i take the answering machine out of the loop, the phones operate normally. does anyone have previous experience with this phenomenon? will another answering machine fix this, or will i have the same problem? thanks
  • 192 Answers
Sounds like the answering machine is picking up the telephone line and not releasing it.
Hence the busy signal, cause the answering machine has the line off hook. It's like leaving your telephone off hook, the next caller will get a busy signal...
The answering machine might be bad... have you noticed that you were talking on the phone and hung up then the next call would be the busy signal? Maybe test this out.
Do you have the correct voltage to the answering machine, too much power or too little power can do funny things to telephone equipement.
Posted on May 12, 2009
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
HP printer 7310. Fax want work. We had a storm but I got a new printer to wall cord and copied ok. Today, the Fax want work has error) Ox886a7a16. Can you help? Lights just blink..and all is stated on the...
If you got hit with a power surge from a lightning strike, it can come into a device from the AC outlet OR the telephone line. I suspect the modem (needed for FAX) section of your machine is fried. If this is in a home office, you should really have a 'whole house' surge protector installed to avoid business interruptions.
We have the Intermatic IG-1300-2T; for 4 telephone line protection it is : IG-1300-4T
Simple to install in the main breaker box and both include 5 years of insurance for losses of $10,000.
You can see them here:
Intermatic Surge Arrestors
The 4 line model (4T) is currently on sale.
Sep 06, 2011 | Office Equipment & Supplies
When i connect the lan wire my mother board shows lan not connected why/
Either the cable is defective (it has a break inside it so try another one) or the onboard LAN chip was fried by the power surge generated by a lightning strike that came in your vicinity.
That is unfixable, disable the onboard one from the BIOS and install a simple PCI LAN card in its place.
Aug 17, 2011 | Intel D945GCCR Motherboard
Our hp printer j4680c took a lightning strike. We replaced the power adapter but when we plug it into the printer the light goes out on the adapter. Is there anything else we can try? The unit doesn't...
This sounds as if it has shorted out the main power board inside the printer. Some small TV Repair shops handle out of warranty printer repairs, but will charge considerably for this. Unless your willing to pull it apart it would be more economical to replace the printer. But ask around, someone may be willing to give you a quote, and this should be weighed against the cost of a replacement
Unfortunately with lightning strikes the amount of power surging up the line can destroy many components inside the printer,and not much can be done from the outside.
Sorry it was not the answer your looking for, but lightning is a electrical devices worst enemy!!
Regards GM
Apr 12, 2011 | HP Photosmart Premium C309A All-In-One...
Sanyo dp32648 possible lighting strike, whats needed to fix and a possible cost an can i repair myself?
It wont turn on? Well if it is damaged by lightning the only thing damaged would be the varactors on the power supply. They are there to absorb tremendous surge of electricity. The same way a surge protector works. A worse case scenario is the power supply board is fried up. Then being a non electronic technician you can purchase the whole board or order on line and install them yourself. If you brought it to a shop they will charged you for the labor and the board. Don't buy used boards on the internet because a lot of them are no good in my own experience. Get a new one for about a little over a hundred buck or so.
Jun 26, 2010 | Sanyo DP32648 32 in. LCD TV
My FF 2125ATF answerer/phone is not working correctly. The handset clicks constantly and the buttons most of the time don't beep when pressed and then there is no dial tone. The battery pack has the...
It sounds as though your phone has been hit by a power surge or lightning. Try the phone at another location and try another phone at this location to make sure there are no problems with the line. I would almost bet you will find that another phone will work but this phone will not work at another location. Phones are very susceptible to a power surge and to a lightning strike. If another phone works at this location then just buy another phone. It will be cheaper than having this one repaired. Phones are cheap but repairs are not. Merry Christmas to you and your family.
Dec 16, 2009 | Southwestern Bell FF-2125BL Cordless Phone
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
I have ge simon 3 which suddenly says phone not
you may have had a lighting strike to the phone line causing a surg to your unit. it may be fried. try completly powering down the system and powering it back up, then try to send a signal to your monitoring station. also you my have your monitorimg station try and connect to your system and check the programing it may have been scrambled.
mj
Apr 02, 2009 | GE Security Simon 3 Wireless Home Security...
POWER SURGE
sounds like DC on that output.
needs service possibly fried all the output transistors on that channel
Jul 30, 2008 | Xantech PA1235X Amplifier
Lightning Strike
Replace with new will need new main board (170 bucks) and modeum board, for best protection it needs a fax filter that protects power line and phone line, standard surge protecter only protects power line
Nov 30, 2007 | Brother MFC 210C All-In-One InkJet Printer
Lands Phones Logo
202 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
