Question about Arris SURFboard® SB5101 Cable Modem
SB5101 Motorola Modem Disconnects Randomly
I have a SB5101 Motorola SURFboard Modem. It randomly disconnects all the time. It only loses connection for about 1 minute. All the lights go out, I lose connection, then 1 minute later they come back on by themselves and the internet it fine again. It happens quite a bit, and I am getting really frustrated. My ISP has come by many times to fix the problem. They just dont know what is causing it, so there isnt much they can do.
If you guys have any ideas, or need any additonal info, plz let me know. Thanks
  • 5 more comments
  • nsarge87 May 12, 2009
    They have changed the modem 4 times now. The guy came today and gave me another one. It did not fix the problem. They have also changed the wires that connect the modem to the outlet.
    You are also correct about the power light going off. And they changed the power adapter also.
    I'll try the drivers, but I'm pretty sure I'm current. anything else I can check, or that you need?
    1970-01-01 00:00:03
    6-Notice
    M571.1
    Ethernet link up - ready to pass packets
    2009-05-12 12:02:41
    6-Notice
    M573.0
    Modem Is Shutting Down and Rebooting...
    2009-05-12 12:02:41
    3-Critical
    R004.0
    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o
    2009-05-12 11:30:20
    6-Notice
    M571.1
    1970-01-01 00:00:09
    3-Critical
    R002.0
    No Ranging Response received - T3 time-out (US 1)
    1970-01-01 00:00:02
    6-Notice
    M571.4
    Ethernet link dormant - not currently active
    1970-01-01 00:02:34
    3-Critical
    D001.0
    DHCP FAILED - Discover sent, no offer received
    1970-01-01 00:00:23
    3-Critical
    T001.0
    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
    Sorry, that didnt copy too well. Ignore after "anything else i can check, or that you need?" in the previous post.
    Downstream
    Frequency: 693000000 HZ
    Signal to Noise Ratio: 35.7dB
    Power Level: 0.1 dBmV
    Upstream
    Channel ID 1
    Frequency: 38000000 HZ
    Power: 44.7 dBmV
    My roommates computer is connected to the same modem, so he loses connection when I do.
    I don't think it is the surge protector, because my roommates computer is connected to the same protector. His computer doesnt go out, and I'm really sure it is not happening when an appliance is turned on.
    I was thinking that it could be a power surge over the coaxil cable. It might not be grounded properly. What do you guys think. Could that be the cause?
    I dont think so, and I am in an apartment so it is kinda hard. I know there is some areas my isp cant get into, because only the landlord has access to it.
  • nsarge87 May 13, 2009
    So I was checking my logs from the modem, and everytime the internet goes out, this is what is logged in the modem: "Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o" Does that mean anything to anyone?
  • nsarge87 May 16, 2009
    This problem has not been fixed yet.... Any more ideas?
  • davewilhite May 11, 2010
    T3 timeout is a bad signal. could be a loose cable, or low signal. It could also be noise on the lines that go down the street. I would find out if your neighbors are having the same problem. when you go to your modem's homepage 192.168.100.1 what are your upstream/transmit, and Downstream/receive power levels?
Thousands of people have this problem and i have 2 of them. Hey guys? dont you think if u change the modem, the power adapter, the cables, and the ISP do u think maybe.. the problem is that the modem is just a piece of ****?
Posted on Feb 05, 2011
    Scholar:
  • 145 Answers
If all the lights go out I would assume you mean the power light as well. Couple of things I would look at:
Has your ISP replaced the modem including the power adapter?
Has your ISP verified there is no short on the incoming data cable? You could try to wiggle the incoming data cable to see if the lights go out. I would do the same on the power cable.
If it's not a mechanical fault (cables), verify that you have the correct and current drivers for your modem and operating system.
Good luck and thanks for using FixYa.
Posted on May 12, 2009
  • 1 more comment
  • Rick Osgood
    Rick Osgood May 12, 2009
    Wow... that's annoying. So, you have ruled out the modem, power cord and cable. There are only two other things I would try.
    1) Run an extension cord from another outlet (preferably on another circuit) to see if there are any issues with the power to the modem. Is there any chance that the connection dropping in the modem is happening at the same time something else is being used in the house? What I mean is, could an appliance be on the same circuit and when it is powered on, you loose the connection.
    2) Borrow or find a way to try another computer on this modem. The problem may be in your PC.
    The second point is a stretch but you have eliminated everything else except bad power to the router and your pc causing the proble.
    Good luck again and let me know how it works out.
  • Rick Osgood
    If both computers drop the connection at the same time then it is definitely the ISP's issue. I would ask that they replace the connection at the drop point or at least test the cable from the drop point to your wall jack. If this does not work then have them pull a new line from the drop point to your house. If you are in an appartment then this might not be so easy but there is a bad connection or cable somewhere. Any construction done around the time this started by chance?
  • Rick Osgood
    Final thoughts. I am thinking your ISP runs a main drop to a utility room and then it is split off to the various apartments. The problem may be between the main drop point and the cable to your apartment. You should discuss with the landlord.
    Whish I could help more but I think you have ruled out the problem being within your pc's and router.
    Best of luck.
How do i connect belkin n300 wireless router to motorola surfboard SB5101 cable modem?
The ISP modem (cable) connects to wireless (yellow port) PC and other devices connect to any port available on wireless. This is the standard setup.
Aug 28, 2012 | Belkin Share N300 Wireless N Router
The modem randomly drops the connection and restarts on it's own. Usually does this when there is a download or upload taking place while I am online or even when I am playing Xbox online. Why is this...
There can be any of a number of reasons for the modem randomly dropping your connection, but the vast majority of these are going to deal with a poor signal coming in over the coaxial cable line. Call your cable provider and let them know the modem is resetting. If they claim there are no problems, ask them for the signal strength and the "SNR". The signal strength should generally be within a ballpark of -10dbmv to 10dbmv, the closer to 0 the better. The SNR should not be any lower than around 32 or 33db.
Aug 18, 2011 | Arris SURFboard® SB5101 Cable Modem
What type of wifi router should I buy
you can add any router you want. since the surfboard is just a modem, you can add any router you want. just make sure that after you plugin a router into the surfboard, that you disconnect the surfboard from it's power, wait 10 seconds and then reconnect the power. this is to let the surfboard see the router since it is known to remember it's last connected device.
Apr 08, 2010 | Arris SURFboard® SB5101 Cable Modem
My modem randomly disconnects and reconnects and has been doing so the past month, is it my router?
I have been experiencing the same problems recently for the past 3 weeks and I had the same modem going on 5 years with no problems so, I replaced it with another exact model still same problems. I have the cable people coming out next week and, I will get back with you with the solution.
Jan 03, 2010 | Arris SURFboard® SB5101 Cable Modem
My Internet times out randomly, and causes me to lose connection in game (COD Modern Warfare 2)
There should be somewhere in the setup screen saying disable timer, you have to unchecked that.
Nov 11, 2009 | Arris SURFboard® SB5101 Cable Modem
SB5101 Modem disconnects randomly
That sounds more like a bad cable signal than a modem problem - can you get to the modem status page (It's normally visible at htpp://192.168.100.1) - and see what the recieve signal level is?
Jul 01, 2009 | Arris SURFboard® SB5101 Cable Modem
Motorola surfboard sb5101 random interruptions.
Yes, try reporvisioning another modem on there system that modem is hosed and your going to need another if you bought it from the cable provider or renting it ask them for another modem..
Apr 22, 2009 | Arris SURFboard SB5101 Cable Modem
My motorola surfboard sb4200 modem randomly disconnects and then is unable to 'Send', as in the light doesnt go on. This seems to fix at random times and can go off for hours at a time, plz help
Have you contacted your ISP yet? You may be having issues with your connection, such as an upstream low signal-to-noise ratio or upstream receive power.
Also, since your modem is older you may want to have their tech support check and see what the power level is. If it's well above 50, closer to 60, then it's time to replace the modem. What happens is that if the signal is bad then the modem will have to "work harder" to stay online. After awhile they wear out. Another sign is if it's running hot - which means that it's struggling to stay online. Have your ISP confirm this for you.
Finally, have you checked with your ISP to see if there are any ongoing issues in your area? Don't go by what the recording says, as it reads your area code and prefix - and often is inaccurate.
Hope I've helped!
Jan 14, 2009 | Arris SURFboard SB4200 Modem
DISCONNECT EVERYTIME
Modems firmware needs to be updated
or
Electrical interference is causing all the trouble
Make sure there is no interfernce in the surrounding
Jun 07, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola SB5101 Modem disconnects
* If you can connect after disconnecting power and reconnecting, it means there is formation of static charge on modem
* Check whether there is any cordless phone or any other satellite devices next to the modem. If so, move the modem 10 feet away.
* If your modem is placed on carpet, please place it on wooden desk
If this doesnt work, please dont rate me down, if it works, please rate me as fixya!!! lol...
Have a nice day!!!
May 18, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Arris SURFboard® SB5101 Cable Modem Logo
2,213 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
