Question about HP Computers & Internet
Lost both usb ports on nx5000
Also my blue tooth
How can i get bluetooth on hp 530 notebook pc(KD088AA#ACJ)
Hi meenarawat48...
You can install blue tooth on any computer using a "Blue Tooth Dongle"...it is a small item that plugs into your usb port and makes your laptop blue tooth compatible.
Do a "google search" on Blue tooth dongle to find one on the net.
http://www.dealextreme.com/p/super-mini-bluetooth-2-0-adapter-dongle-vista-compatible-11866
Please take time to rate me
Jul 26, 2011 | HP Computers & Internet
How to connect samsung mobile internet without pc suite?
I found A PC blue tooth at wallmart for less that 20 bucks, transfers pics audio everything on all my cells. plugs into usb port all you have to do is install disc from blue tooth, make blue tooth on and visible on cell phone then pair them code 0000
Jun 02, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
I want to know how to tell if my Dell D610 has the hardware for bluetooth
Nope...it seams that this model do not have any blue-tooth port ..but just a infrared data port ..so if you need to use blue-tooth on it you have to get a blue-tooth USB adapter ..and use it on the usb port ..
http://cgi.ebay.com/2x-Tiny-Bluetooth-V2-0-EDR-Dongle-Wireless-Adapter-A2-/260605992227?cmd=ViewItem&pt=PDA_Accessories&hash=item3cad53dd23
May 20, 2010 | Dell Latitude D610 Intel Pentium M 1.6GHz...
Need bluethooth for sony vaio vgn-n365e laptop
WHen you say blue tooth do you mean you want to hook it up to your home wireless network? if so you can buy a USB blue tooth adaptor to run on your computer. IF it does not have a USB slot you willl have to buy a rs232 port with usb adaptor or blue tooth adaptor. There is a difference between a blue tooth that you hook up at your home and a blue tooth that you can connect anywhere on line, for instance verizon wireless has a large area to use a blue tooth connection to the net but it costs you money. With the verizon plan you can use te net anywhere you can get a signal just like a cell phone. the blue tooth will allow you to connect to unlocked services for instances many hotels and cafes have wireless acess for free all you do is connect it up. If you need more help let me know and I will be glad to tell you where you can buy it and how much it costs.
Nov 20, 2009 | Ovens
Windows vista which USB cable do I need to use a
As far as I am aware the mouse you are talking about is NOT blue-tooth but a regular wireless mouse.
It came with a small wireless dongle that plugs into ANY regular usb port and does not need a cable.
Blue tooth does not usually use cables either as it is a wireless format but different to regular wireless
If your mouse is blue-tooth then you should ensure that your laptop or pc also has blue-tooth.
Should it not have blue-tooth then to use the mouse you would need to purchase a usb blue-tooth adapter. this is not a cable but is classified as a "dongle" you that's true !
This dongle plugs into any regular blue-tooth port on occasion windows will detect and install the required files but some blue-tooth dongles will come with a cd that you need to install.
If this information was useful please click
Aug 16, 2009 | Trust (14694) Keypad, Mouse
I cant connect my HTC p3400i using my Homepc
Browse the Web on your mobile: Download settings from your Service Provider...
Browse the Web on your Desktop PC using your mobile as a modem - Activate blue tooth on your mobile & your PC (If no internal blue tooth port like most Laptops) you will have to purchase a separate Blue tooth dongle and follow the setup instructions....hopes this makes sense.
Jul 16, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
USB Port not working
Turn off the computer and remove the plug and battery wait for 20 mins then put it back in. Try again. Also check if you have a question mark or exclamation point in device manager.
Click start then run then type in devmgmt.msc then click ok
Nov 07, 2008 | HP Compaq nx5000 Notebook
Motorola H700
Is your HP Blue Tooth compatible? Check the specs for your system and see. If it does not say it has Blue Tooth compatibility then you can buy a rather inexpensive Blue Tooth doggle that plugs into one of your USB ports.
Jun 02, 2008 | Motorola Mobility H700 Wireless Headset
Blue tooth adapter and hs850 headset on my computer
Yes, you need the blue tooth driver. The one that comes with your blue tooth "toggle". Although my laptop said "blue tooth compatible" I still needed a toggle. They are fairly cheap to buy and go into a USB port.
Sep 17, 2007 | Motorola Mobility HS850 Consumer Headset
Computers & Internet Logo
99 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
