Question about Dremel 395 Variable Speed Multipro Rotary Tool Kit
I have a Dremel Multipro model 395 the problem is that i plug it into the wall flip the power on and nothing happen the motor do not start ....... no burn smell last time i've use it and the brush on each side are half used ??? what I can try oppen it ? and see if the power wire are correctly weld ???
SOURCE: Dremel 395 Type 2
Dremel Authorized Service Center
4631 East Sunny Dunes
Palm Springs, CA 92264
(800) 275-2052
Rob Dremel
they have the part you need for $1.25
Posted on Jun 20, 2008
  • 13 Answers
SOURCE: switch
Definitely not Home Depot. Try googling 'dremel model 395 switch', you'll probably come up with something. If not, there's always dremel themselves. This is a current model so there shouldn't be any real problem getting parts.
Sorry, don't know about installation, but I can tell you most of these dremels are real easy to fix in general, not complicated at all.
Posted on Jul 29, 2008
  • 384 Answers
SOURCE: carving stone with a rotary tool
Are you asking for permission? If so, it OK with us, better check with your wife and her mother.
Posted on Jul 21, 2009
  • 165 Answers
SOURCE: Dremel MultiPro Model 395 was used to cut out
Drywall dust has ruined your tool. It seizes up bearings and bushings like you wouldn't believe.
Posted on Feb 28, 2010
  • 3 Answers
SOURCE: dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Posted on Sep 26, 2010
Plug it in - turn on switch - nothing happens
OK there's not much to these first check, the power plug, check cable, if you can, open it up and see if there is power to the On/Off switch, if there is check the switch, if they are all good but still no go, then most likely culprit is the speed controller, you will need to replace it.
Mar 02, 2011 | Dremel Variable - Speed Multipro Rotary...
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
Sep 14, 2010 | Dremel 395 Variable Speed Multipro Rotary...
The motor on my dremel 395 works but the bit doesn't turn
there is a coupling between the motor and the spindle that has probably cracked or stripped out. I suggest going to Dremel.com and getting an original replacement part for this. They are not hard to install.
Sep 02, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 doesn't seem to be getting any power. It's almost new
Return it for replacement. If your power source is good and you have pressed the ON switch/button and nothing works, it is likely faulty. If you are not familiar with pulling them apart, it is best not to! Seek a replacement (hopefully under warranty)
Mar 03, 2009 | Dremel Variable - Speed Multipro Rotary...
Switch
Jul 20, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 Variable Speed Multipro Rotary Tool Kit Logo
200 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
