Question about Refrigerators
Freezer only getting down to 20 degrees
Amana model tz21q2l only getting to 20 degrees in freezer
  • 159 Answers
It is one of two things low gas or thermostat
Posted on May 15, 2009
What settings do you recommend for the refrigerator and freezer/
fridge --around 4 ( should be at 5 degrees c and freezer around 6---minus 20 degrees c
for the fridge settings the numbers work down from hot --7 to zero --- 1 where as the freezer works from 1--- zero to minus to 7 really cold at -20
adjust each depending on the time the door is open and the frequency of the opening ---examples
if you find that lettuce is freezing at 4 and you are the only person using the door , put it up to 5 but if there a family and the door is continually being opened or held open while the minds are being made up , you may have to consider 2 or 3
Sep 18, 2016 | Amana Side-By-Side Refrigerator 26 cu. ft....
Amana bottom freezer temp 16 below. Turn temp down a little temp goes to 20 above
With that kind of spuratic actions I would strongly lean toward that the temperature control, also know as the cold control , is probably malfucntioning. Before I can 100% call that fact I would need more inforamtion, model number the most important. Also, a description of how the machine looks on the inside, like frost on the wall, ice, etc.
Apr 29, 2012 | Refrigerators
Wide variation in temperature in refrigerator section (40 degrees in top, 20 degrees in bottom, also, freezer set at WARMEST setting is ten degrees below zero.
Amana refrigerators older than 5 years have both a cold control and freezer control. this may be your problem. But check both the gaskets on the doors and check for heavy dirt on condser coil. Both can cause wild temp problems. Hope this helps
Aug 17, 2011 | Amana Refrigerators
The model number is TZ21Q2L . The freezer is working ( has to be kept up high though or it doesn't freeze properly) but not the refrigerator. Everything is warm. Cleaned out underneath but still isn't...
all the machine does is blow cold air from the freezer to the fridge so when you open the freezer do you hear the fan blowing?if not you have a bad evap. fan motor.also is ther any water leaking into the fridge section?pull out the bottom draws and if water is there you most likely have a blocked drain and it's freezing up the air ducts,one more thing to check,put your hand on the back inside wall of the freezer,if there's like snow or ice on the wall you have a defrost problem.let me know what you find.
Apr 18, 2011 | Amana Refrigerators
What is the cu. ft. of this model refrigerator Amana TZ21Q2L
Per my Manual , The Amana TZ21Q2 is 21.1 cu ft. and energy guide $69
Apr 02, 2011 | Refrigerators
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
My upright freezer only goes down to 31 degrees, I have a refill adapter and it shows that R-12 is 52 psi, R-22 is 28 psi, and R-502 is 20 psi. Im not sure what I have in the freezer, i figured you could...
Refrigerators dont loose refrigerant (extremely rare) for the past 20 years .(except Amana ) I think your problem is elsewhere such as : dirty coils , frost on the rear wall (behind panel) indicating a defrost problem , compressor fan or freezer fan not working .
Jul 18, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
