Question about Vizio L32 32 in. LCD HDTV
No power at all
My L32 hdtv doesn't turn on when plugged to a power supply at all.  I removed the back panel portion of the t.v.  Power is present going to a "circuit board" located at the top right portion, however there are 2 plugs that connect that "circuit board" to another one located in the middle portion of t.v (this is the one that the AC plug is located).  I checked the small glass fuse, and that was O.K.  Any ideas on what could be the problem.  Maybe a burnt capacitor or something.
  • 3 more comments
  • samziasam Dec 11, 2007
    Have you folks found any solution to this problem? My vizio tv light does flash
    on and off on power light but it doesnt turn on. Could you please email me the solution.
    Sam Zia
  • kmen Jan 03, 2008
    same thing
  • Anonymous Jan 22, 2008
    Mine will not turn on. Not by remote or hard mount power button. It worked fine without any issues for several months. Then two hours after the last use, it would not turn on. No power light or any sign of life. I checked power at the TV end of the cable, that was fine.
  • dpsmith80 Jan 26, 2008
    Same problem as everyone else however my yellow power light blinks very slowly. Was working fine last night. This morning not so fine. Has anyone gotten an answer on this yet.
  • KAMEs Jul 03, 2008
    My VIZIO L32 HDTV stopped suddenly and does not turn on. I checked the cord. I also removed power cord for 5 minutes and then connected to power as per the suggestion of VIZIO technical team. The power in my VIZIO HDTV is still not coming. My TV is less than two years old and purchased fron SAM'S CLUB. I woul appreciate your suggestion.
  • 3 Answers
I have the same set.. power light on front stays yellow (standby). first thing im going to check are the mainboard (one in the middle) fuses.. these are very tiny and are rightbelow the right plug where the power comes in. they are labeled f3, etc. and are tiny and white. looks like one says 3 amp and one is 2 amp. if one of these are open then the main board will not recieve the proper voltages to turn on the set when the power button is pressed.
Posted on Nov 28, 2007
    Problem Solver:
  • 12 Answers
I am having the same promblem I think does your light flash on and off on power light, mine does I am going to trouble shoot the board on monday at my company I work for I am a tech at a company that repairs other lcds this big and bigger but not for vizio so if i find anything I will let you know if you want?
Posted on Oct 28, 2007
Power cord plug position
usually found on the is usually connected directly to power supply.
Jul 18, 2012 | Vizio L32 32 in. LCD HDTV
Dead set (no indication lights coming on when I push the power button.
Hi Gwendolyn,
First of all thank you for posting your question here at Fixya.
I'm assuming here that you're TV is a Vizio L32 HDTV.
My initial advice is to ensure that the AC source(outlet) is live. Please plug the unit to a known working outlet, if you are using a surge protector, directly plug the power cord of the TV to the outlet to confirm that the AC source is not the issue here.
If you've confirmed that the AC source is not the problem, then the fault is inside the TV and most likely the power supply. Most of the TV with a dead set symptoms that I've encountered is a power supply issue but of course needs to be confirm.
If your unit is not under warranty period (if so, avail it because the manufacturer will fix it for free, opening the rear cover will void the warranty), open the back cover, check the internal fuse of the power supply board, this is near where the AC power cord's directly connected. Check its continuity using the multimeter/ohmmeter, if you found it open, replaced it with a new same current rating that is printed on its body itself. Sometimes internal fuse fail due to voltage surge/flactuation, aging, etc, replacing with new one resolve the issue, however if the fuse blow again, this is an indication of more serious problem on the power supply board, it needs to replaced the entire board.
If the fuse is intact, you have to measure the output voltage of it through connector J1 (pin 9,10,11). You should be getting 5 Volts. If there's no voltage at these pin, you're power supply board is dead, replaced the entire board. If the 5 volts is present, replaced the main board.
I've provided you a links for the power supply board and mainboard below.
Vizio L32 Power supply board
Vizio L32 Mainboard
Let me know if you need further assistance.
Rating and feedback are highly appreciated!
Hope I helped you.
Good luck and take care!
Have a nice day!
Kind Regards,
Dec 13, 2011 | Vizio L32 32 in. LCD HDTV
I have the Vizio vp322 hdtv10a that doesn't turn on,I opened the back panel and found that the capacitors aren't bulging.
Hello, might need a Main Unit or Power Supply by the sounds of it. Try out a company named for parts. I have used them with great success in the past. I included a link to their site from your model page. Hope that helps!
Sep 06, 2011 | Vizio L32 32 in. LCD HDTV
Tv won't turn no the vizio logo only blinks
That problem is 2 causes,its either power supply or system board.
This are some D.I.Y procedure for troubleshooting.
  1. Open the back cover by removing all screws at the back.
  2. Try to look at the power supply board and find the leak/bulge on top capacitors.If you found,replace it with the same type and ratings.
  3. If the power supply doesn't have any leak capacitors.Try to power it ON to perform voltage checking.
  4. Check the output voltage of power supply such as 5vdc,12vdc and 24vdc by using voltmeter.If this 3 supplies having a voltage drop or flickering voltage while on power ON.Check the following parts on the power supply,change value/open resistor,shorted transistor and diode or repeat step # 2.
  5. When the output voltage is stable and all parts looks OK.The problem could be on system board.Unfortunately the system board or main board is not for D.I.Y because the parts inside is very logic and very sensitive.That is replaceable.
Thank you and good luck.
Jun 06, 2011 | Vizio L32 32 in. LCD HDTV
Television turned off and wont come back on
If theres no lightrs then your power supply unit is shot and you will need to get a new one. try going to a tv surplus store or a place like best buy and asking for the part first get the model number of the power supply this is the thing that all the cables in your tv are plugged into. hope this helps
May 07, 2011 | Vizio L32 32 in. LCD HDTV
Have a Vizio 32in flat screen. Turned it on with the remote and heard a loud pop and now the tv will not turn on. Is this fixable
Yes,the power supply board is dead,common problems.That the board,where the power a/c plug into it.Tries websites like, to buy a refurbish power supply board for the replacement.
Sep 08, 2010 | Vizio L32 32 in. LCD HDTV
The power went off at my house due to an overload and when the breaker was turned back on, the tv had no power, no green or orange light. I unplugged the power cord and plugged it in later and the tv...
The power supply board is dead,that the board where the power cord plug into it.Take ur tv aparts,replaced the power supply board,ur tv should work again.Tries websites like, to buy a refurbish power supply board for the replacement.
May 23, 2010 | Vizio L32 32 in. LCD HDTV
Won't turn on.
Your LCD TV has a problem in power supply circuit board maybe the fuse is busted already just open your unit and locate the fuse.
Good luck:
Don't forget to rate:
Jul 07, 2009 | Vizio L32 32 in. LCD HDTV
Vizio hdtv turns self off and light staysthen turn off n on again
The power supply has gone bad. Replace the power supply will fix it.
Feb 15, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L32
i took it to the tv repair sop and my power supply printed circuit board was blown and it would have cost $609.00 for labor and parts
Mar 05, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
164 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
