Question about Dakota Dodge RB4 Navigation, CD, AM/FM, with CD Changer Controls
Auto radio Replaced the battery in my dodge truck and now the redio dosnt work. Chysler indash Radio P56038567AH went south while disconnecting battery connections to clean poles. 01 PT Cruiser where I have replaced battery in the past with no problems. Now yellow leds on equalizers slides are blinking and no radio. HELP!!!!
    Genius:
  • 1,847 Answers
Check the fuse box, all the fuse should be intact.
nogo
Try reset the radio, by unpluging form the battery for 12 hr and repluge back.
nogo
Take the the radio out and check for and worn out cables.
Let me know the status
Thanks
Kevin
Posted on May 12, 2009
Battery went flat radio wont work now.how do i get code?
Search Results
    Car Radio Stopped Working after the Battery Died
    cartech.about.com > ... > Car Radio Components FAQs, and More
    First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
    radio won't work after new battery installed - Car Talk
    community.cartalk.com/.../radio-wont-work-after-new-battery-installed
    Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
    Another Flat Battery - Radio No Longer Works - Hyundai Forums ...
    www.hyundai-forums.com/.../128744-another-flat-battery-radio-no-long...
    Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
    Dead battery..now radio won't work - Honda CR-V Owners Club
Dec 09, 2015 | Cars & Trucks
Factory stereo not working and needs replaced. how does dash come apart to do this
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Remove cup holder.
  3. Remove trim panel above cupholder by pulling straight out.
  4. Remove center instrument panel trim panel.
  5. Remove screws holding radio to instrument panel.
  6. Pull radio rearward to gain access to the back of radio (RADIO). CAUTION: Pulling the antenna cable straight out of the radio without pulling on the locking antenna connector could damage the cable or radio.
  7. Disconnect the antenna cable by pulling the locking antenna connector away from the radio (ANTENNA TO RADIO).
  8. Disconnect bolt holding ground strap to the radio (if equipped).
  9. Disconnect the wire connectors from the back of the radio.
Nov 19, 2013 | 2002 Dodge Grand Caravan
I have chevrolet eveo and asking me redio code
Contact a dealer. They may need to get your radio serial number to get the proper code, but that's what you need to do. If you bought the car new the radio code is probably in the owners manual packet.
Jan 10, 2012 | 2006 Chevrolet Aveo
Was this problem ever solved, I have the same condition in my 1997 Chylser Concord: By ddunne912 on Feb 26, 2010 My 1995 dodge acclaim radio has a problem ,sometimes it works fine then for no reason the...
call a dodge or chysler dealer and get a find out who repairs there radio and send out for repair sounds like a bad radio or maybe a recall on the type of chysler factory radio ..simple solution is check craigslist for a working cheap aftermarket radio .then go out buy a dash kit, wire harness and antenna adapter and then install new used radio that is the cheapest solution.
Dec 23, 2010 | Chrysler Car Audio & Video
2001 dodge neon has a code of 601?
P0601 is an internal problem with the PCM (powertrain control module) ( the computer) Can you disconnect the battery and reconnect it and the can run? Does the car run Now? ( probly not) the repair procedure says to replace the PCM and reprogram it. This is a dealer job as the VIN and the computer have to be matched with the chysler data base.
Sep 28, 2010 | 2001 Dodge Neon
Plug volkswagen radio
i have a 1998 vr6 and i replaced my radio as well with a wiring harness that only fit two of the factory plugs, the third plug is for the optional cd changer that goes in the trunk, so after about 3 days of trouble shooting i noticed a BLACK wire that went to both remaining plugs, took it out of one plug and spliced it into the other wires that were remaining and it worked, assuming that your radio shows that it has power but no sound, that was my issue, now it works fine, hope this helps
Jan 29, 2010 | Volkswagen PAC C2R-VW Radio Replacement...
My battery went dead and the redio said put in the code and it gave me three trys and then cut off. What do i do
try to disconnect the battery again, the negative post for about 30 second and put the post back on and input the code again. if you don't have correct code, take you registration up to the Mits dealer and they can get you the correct code using the vin number.
Oct 03, 2009 | 2001 Mitsubishi Diamante
2001 dodge stratus radio
I researched and found I needed to reseat or replace the IOD fuse. In my Dakota this is labled "Interior Lights". By pulling this fuse it allowed the radio to reset and everything came back. Hope it works !
Nov 29, 2008 | 2001 Dodge Dakota
Car Audio & Video Logo
223 people viewed this question
Top Dakota Car Audio & Video Experts
xxxxxx xxx
Are you a Dakota Car Audio and Video Expert? Answer questions, earn points and help others
