Question about Sharp XV-Z2000 Multimedia Projector
The projecter lamp timer expired and the projector wouldn't turn on. Replaced the bulb but it still won't power on. Tried the lamp counter reset procedure with no change. How do I get the projector out of the power down safety mode.
  • jasbo
    jasbo May 11, 2010
    are any of the leds on the top of the projector lit? if so, which ones? red or green?
  • 2,237 Answers
Try the lamp timer reset again. hold down enter, down arrw, and menu then press power.
Posted on Aug 19, 2009
  • 1 more comment
  • jasbo
    jasbo Aug 19, 2009
    also reset the bimetal breaker located inside the machine on the front of the lamp housing.
  • wmaskinner
    wmaskinner Nov 08, 2012
    The what?
  • wmaskinner
    The bimetal what?
Reset lamp timer on epson 5500c after timer has expired
Could be a bad ballast. Did you get the door and latch closed completly?
Apr 26, 2012 | Epson Powerlite 5500c - Lcd Projector -...
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Cannot reset lamp timer as will not project. Replaced the lamp in my 3m X50, bulb came right on. I had to shut it down before reseting the lamp timer. Now will not light up so that I can navigate the...
    It does not sound like resetting the lamp timer is what is keeping the projector from throwing an image. Try walking through the steps of the installation backwards to remove the bulb completely. Then reinstall the bulb again from scratch making sure everything is seated properly. If it powers up again just remember to set the clock back on the bulb.
    Mar 03, 2011 | 3M X50 Multimedia Projector
    TURN PROJECTOR ON. FAN TURNS ON NO LAMP, RED SATUS LIGHT COMES ON
    Bulb timer has expired. Press the left arrow, right arrow and power switch simultaneously for a few seconds. The projector should power up, but this indicates that a new bulb is required and should be fitted as soon as possible, as there is a risk of the old bulb exploding.
    Sep 15, 2009 | Office Equipment & Supplies
    Sony vpl-hs20 cineza projector- reset lamp counter
    These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
    1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
    Connect the power and set the projector to standby mode.
    Press these buttons on the remote control in this order, for less than 5 seconds each.
    Reset - Left Arrow - Right Arrow - Enter
    This is required, to reset the lamp timer.
    Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
    Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
    How do I access service menu to reset lamp timer for Optoma H56?
    In order to reset the bulb counter you need to access the Service Menu:
    To access the Service Menu:
    Turn on and warm up
    press the following sequence:
    Up
    Up
    Left
    Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
    Apr 15, 2009 | Optoma H56 Multimedia Projector
    Bulb Replacement
    the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
    this problem is because of the following:
    1) wrong bulb
    2) cooling fans not working adequately
    3) defective ballast
    check the above for a solution
    Jan 08, 2009 | Toshiba Replacement Projector Bulb...
    LP130 projector - no light from lamp
    there are several other issue that can arise with this unit
    you may want to check out fixmyprojector.com
    Jun 30, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
    Infocus LP725 projector
    The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
    Check the projector’s lamp to ensure that it is securely connected
    in the lamp module. Make sure by removing it and reinserting it.
    Check the cables for problems.
    When testing, power up in this order. Projector, Computer monitor, Computer.
    A minor power surge may cause the lamp to shut off. Turn the
    projector off, wait at least 30 seconds, then turn it back on.
    I hope these suggestions help
    May 25, 2007 | InFocus LP725 and LP735 Replacement...
    Sharp XV-Z2000 Multimedia Projector Logo
    466 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
