Question about iRiver PMP-120 Digital Media Player
Formatting the iriver x20
Hi, I have had the iriver X20 8GB stop opening due to bad files which have been loaded to it. It was suggested to me to Format the device, but after reading the manual its not clear how to do it at all. Other than it needs to connected to the PC. But as it doesn't open due to bad files the PC doesn't recognise it.
 Any tips on how to format the device?
Secret reset buttons?
I think you need to have a Windows XP w/SP1 or later and USB 2.0 port to connect to. Any older operating system/Pc will not do. Once you make the connection, simply Right-Click on the new drive letter (PC would have created for the player) and click <Format> followed by <start> .
Posted on Dec 04, 2007
Song names in X20
i think you should try this...
if you dont already, download iriver plus 3
install it
open iriver plus 3
plug in iviver
go to tools>Portable Device>Disk Initialization
this should format your iriver and replace all the original files
i reccomend only putting music, video, pictures and ebooks on via iriver plus 3
and also please make sure you safely remove the iriver each time you connect it to the computer
if you dont, there is a chance that you will screw your iriver, you may have heard of the "building library" problem, which nobody has found a solution for yet.
i hope this helps you!!
good luck!
Jun 06, 2009 | iRiver X20 MP3 Player
I can't figure out how to put playlists on my iriver x20
yea i know what ur talking about. unfortunately the iriver x20 can only read SOME types of playlists. for example the windows media playlist that some people use doesnt work but the .m3u files which u can convert on winamp does work. its a real pain i know but that's why i just add files while i listen to them on the music menu of the x20.
hope that helps!
Feb 18, 2009 | iRiver X20 MP3 Player
Iriver X20 won't read on Iriver plus 3
this is a major problem i found with iriver plus 3. it tends to stall quite regularly. i suggest using wmp11 its just as effective. it cannot convert files but it syncs up quite nicely
Hope that helps!
Nov 08, 2008 | iRiver X20 MP3 Player
External memory - sd card recognition on pc??
if it doesn't even appear on windows explorer either the sd card, usb link or iriver is defective. if all else fails try getting a memory card reader. this allows you to store files on the card through the computer and still be able to insert the card as external storage on the iriver x20. the only trouble with that is that its hard to get the card in and out of the iriver
Nov 02, 2008 | iRiver X20 MP3 Player
Iriver X20 switches off when using FM Recorder
there may be a problem with the menu files...
Aug 30, 2008 | iRiver X20 MP3 Player
IRIVER X20
you need to download the files onto your comp and then use wmp 11 and sync..
if u need to change formats of the music, video or pictures use iriver plus 3 that came with the product
Jun 02, 2008 | iRiver X20 MP3 Player
**error** can't open this file???
Be sure you are using the latest version of Iriver Plus 3, to load your music. It automatically makes all the necessary conversions to put files on the player.
May 08, 2008 | iRiver X20 MP3 Player
Iriver x20
try and view hidden files...
it depends wat the folder is...
it might be a system folder, in which case you'd be better to just ignore it
Apr 05, 2008 | iRiver X20 MP3 Player
Iriver mp3 player
Same problem on a 2GB x20 I just bought. Easy to get things into the device, but nothing recognized as playlist either using iriver plus3 or Media Player.
Feb 05, 2008 | iRiver X20 MP3 Player
Downloading movie length DVD to iriver x20
Yes, you need to convert all your movies to a format iRiver and understand and play.
Here's a link:
Movie Converter for iRiver and instructions
I'm not sure whether Movie Converter supports original DVD files. If that is not the case, then you'll have to convert DVD video into a format that iRiver X20 can use, and then feed that new video to Movie Converter.
However, that would be a bit redundant: to save on time and quality, you could use other video Conversion tools, such as SUPER:
http://www.erightsoft.com/SUPER.html
After loading your DVD, you set the parameters to mirror those accepted by your iRiver model. In case of iRiver X20, those parameters are:
Extension: AVI [[also known as container]]
Video Codec: WMV9 SP, MPEG-4 SP [[MPEG-4 = XVID, DIVX]]
Video Resolution: max 320 × 240
Video Framerate: max 30 fps
Video Bit Rate: max 512 kbps
After successful conversion, upload your new video file to your iRiver X20 and play it back. If it plays [and plays correctly] - then congratulations - it works! If it does not play, then you might have made a mistake while setting the output parameters in SUPER.
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Jan 05, 2008 | iRiver X20 MP3 Player
iRiver PMP-120 Digital Media Player Logo
313 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
