Question about HP Photosmart M425 Digital Camera
Lens will not open
These are the symptoms.
   Camera turns on
  The photo lens(on back) says x amount of photos used
The lens will not go out or open
Page 32 in book (When I replace the batteries, the camera comes on briefly then shuts right back off.)
 please help!!!
Re: Lens will not open - HP Photosmart M425 Digital Camera Digital Cameras
Same problem?
Posted on Nov 20, 2008
Find the reset hole near the opening where you insert your battery. Press a paperclip in the hole and hold for about 6 seconds.
Posted on Sep 04, 2008
0 characters
3 Points
Hi, Hope u can help. Dropped the camera. Now when I go to turn it on it says, Lens error,
you possible bent the lens or the connectors of the lens.
do you have a camera with removable lens, just remove the lens
put another lens on, try take photo's, check the color and layout, view the photo, than try putting the old lens back on, see if if works,if you have the same results, than the lens maybe damaged
see if the lens is under any type of warranty, c/c, bank card.
contact dealer or manufacture or camera or lens repair shop to see if it is worth trying to fix or buy a new one.
pick up any photo magazine look in the back for camera and lens repairs, or lens company talk to a service technic.
Sep 18, 2015 | Nikon COOLPIX Digital Cameras
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
Nikon Coolpix S5 camera. Lens shutter remaining open.
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon representative."
Nov 18, 2009 | Nikon Coolpix S51c Digital Camera
When taking indoor photos, sometimes i get shadows on different placesof the photo
If you're getting shadows on the bottom center of indoor photos when take with a flash, it is most probably due to the length of the lens on the camera.
A long, telephoto / zoom lenses will create the largest amount of shadow, while shorter and wide angle lenses will be least likely cast shadows. You can reduce the amount of shadow in pictures by removing the lens hood that may be on the end of the lens. The lens hood is to primarily to shield the lens from direct (sun) light, and probably isn't needed for indoor flash photography. Also, rely less on the zoom function of the lens on the camera and physically moving closer to your subject instead. The flash will need to provide much less light output and result in more flashes per battery.
You could use a separate flash - held off the camera so that the lens is not obstructing the light of the on camera flash. Using a Nikon Speed Light, you can set the on camera flash to provide a low output, that would be used primarily to trigger a Nikon Speed Light held by someone or arranged on another surface etc. Youtube is a great source for real life, practical "How To" videos for many operations of the camera and accessories.
I hope this was helpful!
Oct 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
I dropped my Powershot SD 500 and now the lens cover does not cover the lens. It leaves a gap when closed and does not retract all the way when open. It seems that the resolution on some of my photos is...
A bit of gentile persuasion may be necessary.
Have you tried to push the lens into the camera body?
I believe that the camera has lost track of where the lens is in it's range of travel.
use your finger and see if a small amount of pressure will put the lens back ito position.
In the end, this is not a new camera, if it is dead a better replacement can be had for as little as 120 $US
Jul 27, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
S800 lens won't close, can't take photos
The lens was bent to one side, so bump with my palm to straighten it back. I was able to start using my Samsung again.
Mar 21, 2009 | Samsung Digimax 800K Digital Camera
M547 camera lens will not open
My son has this camera and dropped in the sand this summer. He had the same problem.
I found this blog posting.
Read it. And try all the techniques.
I took the camera to our photo printing store and the guy sprayed it with compressed air. It didn't do the trick but I think it helped. We tried all the techniques in the article. In the end I put some WD-40 in a dish and used a toothpick to drip the WD-40 into the space between the lens barrel and the camera case. I powered on the camera while my son pulled on the lens. He pushed back the flaps and pulled from them. Somehow, after several tries - and I was ready to give up - the lens opened. We still got a lens error message. We kept brushing away and blowing out sand and turning the camera on and off. Eventually it started working. However, the zoom is not working. But we are going to go back to the photo store and have him blow more air into the lens.
Good luck. Hope this isn't too late and helps you.
Aug 10, 2008 | HP Photosmart M547 Digital Camera
Not able to shoot photos
OK, I have this camera and it started doing this to me about a week ago.  I assumed it had reached the end of it's life after many, many excellent photos.  As a last resort when the lens popped out after first switch on (when it's doing the clicking business) I grabbed the lens and wiggled it gently back and forth (as if zooming a conventional SLR).  It appears to have been fixed, remarkably!  I switched off and switched it back on and all seems OK.  (I'm not holding my breath and will probably keep looking for a new one but for the moment it's sorted out.)
Mar 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Yep. another lens stuck.
i had this problem after putting it in a jug of bear (i know, i know...not so smart)...i washed the camera with a small amount of dishwashing detergent and a good rinse and it seemed to solve the problem for me....not sure if this is the recommended way of dealing with it though.
Oct 22, 2007 | Olympus Stylus 770 SW Digital Camera
When powered up, "Remove lens cover, press button"
The symptom of "remove lens cover" always showing can be caused by two different things. If the lens assembly has become jammed and will not move when the camera tries to extend it - this can cause the message. On some cameras a stuck-closed shutter can cause this message as well. The symptom you describe of seeing two images prior to the failure is strange. I cannot make any kind of conclusion from that information without further elaboration. Does the lens extend when you turn the power on? If not the lens is jammed. Do you see nothing but black all the time on the screen and the captured photos? If so the shutter is stuck closed. Either of these problems will require complete disassembly and re-setting of the lens elements. Check with your manufacturer and see if they will fix it under warranty. If not, there are service providers available on the internet who can service your camera. David Millier Advance Camera Repair
Feb 27, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
HP Photosmart M425 Digital Camera Logo
64 people viewed this question
Top HP Digital Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Digital Camera Expert? Answer questions, earn points and help others
