Question about HP LaserJet 2550L Printer
2550Ln will not print
Cannot get to the website for "help with printer lights". Triangle is amber, horseshoe light is solid green. Last week the drum light was on and the yellow cardridge light was on. They are not on now. My students need to print end of year projects - HELP
  • POCBM
    POCBM May 11, 2010
    Is the triangle solid or flashing?
    What is the status of the GO light above the big button?
  • 134 Answers
If the supply lights are not lit, then you may have a paper jam. Check the rear cover. Also sometimes paper jam lights come on even though the paper has not jammed, just misfed from the cassette. Please let me know any further details.
Posted on May 12, 2009
It is showing a triangle with excalamtion mark blinking
That would be the attention light.... Indicates that the input tray is empty, the print- cartridge door is open, or bad toner. Is there any lights that are on solid or flashing? (could also have a bad fuser ... need to trouble shoot this a little more)
If you hit the green button does it do anything?
- www.trusttechnology.biz
Mar 13, 2014 | HP LaserJet 1320 Printer
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
ZyXEL Prestige 600 Series router failure
Not sure which specific router in the series you have but the following may help:
Well there should be a power light on and solid green, a DSL light solid green and on. The internet and ethernet lights should be blinking green if sending and recieving data.
I'll bet thats amber and not orange. In which case you have a 100mbps conenction to between the pc and router.
Check here for more details.
Aug 28, 2009 | Computers & Internet
Green horseshoe light is continually lit
If it is solid on, it means the printer is ready to print; no action is required. If it's flashing, it means the printer is processing data and should print soon.
If you are printing from your computer and nothing comes out, with the "Horseshoe" light staying solid, I suggest checking the connection between your computer and the printer, or at least the printer configuration. Most of the time, unplugging, then plugging cables back in does the trick.
Jul 06, 2009 | HP Color LaserJet 2550n printer + HP Color...
Triangle symbol on our printer with a AMBER LIGHT FLASHING?
There is an issue with the media/paper. First thing is to make sure there is paper, and if so, that it's touching the intake rollers. Next is to check for jams, which are usually under the imaging drum. Open the front lid and remove the drum (it's in the front; follow the directions shown on the label on the front right.) Also, check for jams where the paper exits the printer.
Final two things. The lid could be ajar - simply push down firmly to ensure all the contact switches are closed. The last thing is an issue with the fuser, which may require replacing it. I highly recommend getting the service manual from HP, as it is easy to follow and has extensive troubleshooting.
Jul 01, 2009 | HP LaserJet 2550n Printer
LaserJet 2550n: only amber attention light blinking.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 26, 2009 | HP LaserJet 2550n Printer
SOLID AMBER LIGHT ON DIMENSION 3000
One of two things:
Either the power supply is marginal
or
the motherboard is bad.
Good luck.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
I have problem with Dell 1720dn Printer its not working one green light is on and another Amber light solid on paper sighn can you help me
According to the manual the light combination meas the following:
Load <input source> <type> <size>Load the specified paper input tray with the designated paper type and size.
This info can be found here at this dell website:
https://support.dell.com/support/edocs/systems/prn1720/en/1720_en/en/d0e772.html#operator-panel-lights-chapter
Good Luck!
Rich Lilja
Jan 21, 2009 | Dell 1720dn Laser Printer
HP Laserjet 1320n Error Lights not in Manual
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
May 27, 2008 | HP LaserJet 1320 Printer
HP LaserJet 2550L Printer Logo
285 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
