Question about Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504; boot from USB? Reformat HD w/o CD-ROM?
I have the infamous Toshiba Satellite 5005-S504 without a working CD-rom.  I want to reboot the HD with the same OS, Windows XP.  Am I able to do this with a USB drive?  IF not is it possible?  I am up for all options.  Thanks!  Hope to hear from you!.
Joe
  • 2 more comments
  • mrwacki Oct 14, 2007
    Thanks for the reply.
    I have tried the F12 idea.  The five options that are displayed to me are icons and they look like the following:
    -three circles on top of one-another_ I assume the HD
    -one circle_ I assume the CD-rom drive
    -one 3.5" floppy disk_I assume to mean the floppy drive(which oddly it doesn't have a floppy drive)
    -two computer looking screen with straights line between them_I assume to mean networked based
    -PCMIA card_ I think that is what is called.
    These are the five options.  My confusion comes from the following:
    -There are three USB ports.  How do I know which one?
    -How do I stage the data on a USB drive for install?  Will the computer understand the "disk" order and then also install all needed drivers?
    In general will this work?
    Thanks! Look forward to hearing from you again.
    Joe
    infamous... this model, when it was new, caused a lawsuit against Toshiba for overheating and some other issues.
  • mrwacki Oct 15, 2007
    I have done the 'esc' key... it takes me to a black sceen with the words "press F1 key for default startup"  or something like that.  There is no option for bios.  I think that is part of my issue.
    I looked last night and found I386 options for reboot, but my computer does not have them on it.
    The cd rom will read DVDs, but when a data or audio cd is in the drive will not even recongize a media is there.  Odd... but true.
    Thanks for your help and support.
    Joe
  • Anonymous May 04, 2008
    iam unable to enter in bios set up. how to enter in 5005-S504 PC Notebook.
  • Anonymous Jul 12, 2008
    i use toshiba satellite 5005-s504 now pc start slowly about 30 minute . ican use bios , and usb soprt run about 10 minute and stop run. ican not it have ploplem. you can tell my
    thanh
First these laptops are what is called "Legacy Free", meaning there is no BIOS, at all, ever, for all time, not gonna be there.
Second, the Floppy option is referring to any supported USB Floppy drive. If you have one great, if not this will be more difficult.
NOTE**** - If at any point you do not know what I'm referring to, please do not attempt this, you will likely render your HDD useless.
If you have the Floppy on USB, then you will need the XP setup on Floppy Disk and there are alot of disks, and from my own experience so far, No, a USB flash drive will not work, I even tried an emulator which formatted it as a floppy disk.
If you do not have a floppy, then you will need to remove the harddrive and connect it via an external USB drive cage to another pc, create two partitions, one for your OEM OS disc, the other for the installation. Obviously your OEM OS Disc is not all that large, only partition what it needs, and make sure you make it a bootable partition. For XP you will also need the SATA drivers for the hard drive as XP does not have them included in the setup disc. If you do not have these, you will need to find them or just stop here, because you can go no further.
This is one of the biggest drawbacks of a "Legacy Free" system, you cannot change the SATA operation in BIOS like most other pc's. The system configuration is done through a windows utility from Toshiba.
Posted on Jan 09, 2009
    Scholar:
  • 181 Answers
Are you saying you want to re-install XP on the hard drive? If the 5005 has the same bios as 90% of the Toshibas out there, "usb devices, or usb rom" should be one of the options in the boot order in the bios. It's a bit different tho, in that if you press F12 for temp boot order, it seems as if it doesn't do anything, but in fact, the icons across the lower 1/3 of the screen are your boot options; just move the highlight to the desired icon.
Good luck.
BTW, what's made these "infamous"?
Posted on Oct 14, 2007
  • jim walenciak
    jim walenciak Oct 15, 2007
    try this: upon boot, keep pressing "esc" until it tells you to press f1.
    do so.
    In the bios, check the boot options which may give opportunity to use the usb drive.
    Otherwise, I've got a pcmcia cdrom... it's a possibility.
    What's wrong with the systems cdrom?
    Good luck; sorry I'm not better help in this situation.
    Thanks
  • jim walenciak
    Hi again,
    Do the esc - f1 thing. that will access the bios. There is a tab in the bios for boot order. See if you have any viable options for what you have to work with.
    Good luck.
    dvd rom drive...that's just wierd.
If you find anything worth doing let me know im haveing a more complicared problem ....... ive lost all my disk i got with my toshiba satellite and it is causing me serious problems when it comes to reformatting my computer is there any other way to do this that dosnt involve the disk that came with it????
Posted on Nov 24, 2008
Hello i got a question. why my laptop is when i play the dvd video is work fine. but when i play video in interent like for example youtube the video is play too slow. (the sound finished before the video). Can anyone help me with this? please
Posted on Jun 09, 2008
Boot from USB:PenDrive
Unfortunately you will not be able to with your computer. Being the age, the BIOS was not equipped to allow such a function. You will need an Optical CD-ROM or DVD drive. Sorry
Mar 18, 2010 | Toshiba Satellite 5005-S504 Notebook
I have problem whit Toshiba 5005-S504.My Windows Xp was **** and i try to reinstall but the notebook can't boot from enythink. I try whit standart way by DWD rom but dwd can't read the disk whit...
Hi, you will have to change the boot sequenc.when you turn on watch the screen and you will see very quickly to press F2 or a different key to go into the bios. I think it is on the first screen to change the sequence - Boot from cdrom then hard drive.
Then insert your dvd and install, if you need more help, please ask.
Jan 30, 2010 | Toshiba Satellite 5005-S504 Notebook
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Changing BIOS priority on toshiba satelite 5005-s504
as i recall, ntloader is software for the OS load, after hardware boot, so you already passed up your chance to enter bios, which you realize. i used to have a toshiba laptop, was it the delete key or F2 to enter BIOS? try delete, and make sure youre pressing it from restart like once a second as it's booting to make sure you hit it in the windows of time it's looking for key presses before it's time to load the operating system. you'll be fine. it's just unnerving to be locked out like that...
Feb 01, 2009 | Toshiba Satellite 5005-S504 Notebook
Can't recover
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Oct 24, 2008 | Toshiba Satellite 5005-S504 Notebook
Looking for Toshiba 5005 cd/dvd drivers
this link will take you to the support page
select portables, satelitte, click on archived models, then select 5005-S504-507-or 508 whichever it is.
once selected click on show results
click on drivers.
Apr 05, 2008 | Toshiba Satellite 5005-S504 Notebook
Reformatting the Toshiba Satellite 5005-S504
you did not specify what operating system you are currently using, anyhow, if you are using winxp, configure the bios setting set the cd rom as your 1st boot device and insert the winxp cd to the cd rom then save and exit the. computer will automatically reboot after exit. a message will appear "press any key to boot from cd" you may press a key. you follow correctly instructions or message from the screen then you will succeed. hoping that this will help you. if you have some queries you may send me thru my e-mail.
Dec 28, 2007 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
4,834 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
