Question about Garmin StreetPilot i3 GPS Receiver
Garmin street pilot 330
I am charging thru usb port at home
Left it for a 3 hours, it said :"charging battery" when i hooked it up to the USB.it said "charging battery"
Left it for 3 hours, then went to use it in car and it immediately said "low battery"
This happened twice. It is faitly new but I have chasrged it this way in the past as my car has no cigarette lighter,
Thanks
Susan
sosystem@gmail.com
Take the navigator 2 a repair center, because somethin that new, shouldn't happened unless it hasn't been charged for awhle after being in the box on the shelf
Posted on Oct 14, 2007
We have 1350 Garmin GPS . How long do we charge the battery before set up.
There are 3 ways to charge your garmin satnav.
  1. You can connect it to your computer' USB port with the mini USB plug. Plug the narrow end of the cable into the back of the satnav and the USB end into the computer. Turn both on and it will charge in 8 hours approximately
  2. Connect the supplied car charging lead. Plug the narrow end into the back of the satnav and plug the other end into the cigarette lighter socket of your car for approximately 4 hours.
  3. You can also charge it with an optional mains charger which also takes 4 hours approximately.
May 10, 2011 | Garmin GPS
Garmin 340 street pilot
Remove the battery out and put back in after 5 minutes to reset it.
, check also that the in car power cable is working, and the Garmin is not drained. Tru to connect it to power outlet if you have an adapter
Mar 29, 2008 | Garmin StreetPilot c340 GPS Receiver
Street pilot 330 will not turn on when plugged into car power supply. Poosible battery charge needed?
Does the car charger cord have a fuse in it at the point where it plugs
into the lighter port, a lot of car chargers have a fuse, I can't tell
if your end, the part that goes inside the lighter port has a cap that you unscrew to replace the fuse, and garmin does not show it.
If the car is running, and it does not work, there is something wrong with the car adapter, or the unit at the plug, the battery should not have anything to do with it.
If the battery starts the car the battery is fine.
Feb 07, 2010 | Garmin StreetPilot C330 GPS Receiver
How to charge battery street pilot 550 on computer
If everything is working correctly you should be able to just connect your Garmin to the USB on your computer and it will charge the battery.
May 02, 2009 | Garmin StreetPilot c550 GPS Receiver
Streets and Trips program is asking for a Com3 port
You will need to download a USB driver for you computer from http://www.garmin.com. Street and Trips will then recognize your GPS device.
Mar 31, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin won't turn on or charge.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 23, 2009 | Garmin StreetPilot C330 GPS Receiver
I have a street pilot c550 and it will not boot up. It gets to where it says loading maps then it goes black
I found the resolution on this site. I removed the face of the unit and hit the reset button on the right side of the unit. I put the faceplate back on. I connected the unit to my laptop via USB port. I downloaded the software for the c5550 from the Garmin site. I installed the base software and the upgrades. I left it connected to the laptop for a few hours to fully charge. I then disconnected it from the laptop and hit the red button to turn the unit on. I received a software update message, when that was done, the unit completely booted up.
Dec 13, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 330 street pilot keeps shutting down, only had it 1 year
Have you tried charging the unit on the computer? If not, try doing this for a few hours. Sometimes it can help.
Nov 04, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot i3 GPS Receiver Logo
49 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
