Question about Canon Office Equipment & Supplies
Irc3380i drum Could anyone point me to the right instractions for olcating and changing the drum in the canon irc3380i photocopier. Ive hunted high and low for a guide but not found a single thing
  • 76 Answers
This the procedure how you removed the drum in irc3380 machine. first open the front door and remove the small cover in your right side.then open the side door.and turn the black lever to right.then push the other lever at the top of blk lever.then remove the 2 screw in both side its locate near in the blk lever in right and the other screw in your left side opposite of the other screw,then when you remove the screw pull the unit out.and you will see the square button at the top off thegray cover plastic in the rear side.push that button and pull it out.and in the rear side you will see a small blk lever to hold the itb unit.(take note not to touch the surface of the itb belt the shiny black one.then you will see the 4 color drum.unlock first before you take out the drum
Posted on May 12, 2009
Canon ir 2420 photocopy is keep asking me insert drum unit but it there
if you had changed the drum cylinder than the one yo have replaced is shorter than the original to solver that replace with the right one
Oct 27, 2015 | Canon Office Equipment & Supplies
My machinw canon iR1024 A doesnt have clear photocopies.does the rollers have dirty ordamaged?
It will probably need a new drum unit they are easy to change, when you get it just dont touch the cylynder with your fingers as the oil from your skin can damage them.
This part is located under the right side door.
Dec 06, 2011 | Canon iR 2016i Black and White Copier
White stirkes in canon iR2016 photocopying result
It is either the drum unit or developer unit or transfer roller. if your counter is 150 000 copies change dev unit and transfere roller.
Oct 03, 2009 | Canon iR 2016i Black and White Copier
Np 6045 Canon photoopier drum scretch in the durm hwo to solve
Change the OPC drum and the drum cleaning blade.
Sep 27, 2009 | Canon NP 6050 Copier
Canon irc3380i paperjam
This problem fault manual presenting the track. Follows to consider several reasons. Check the condition rubber roller seizure of the paper. Check and clean lower brake platform. Check and value the possible ragged sheet of paper. Check presence a stranger subject in giving device. Try to give the paper along on format by narrow side. Thank you, good luck!
Sep 16, 2009 | Canon C2058 Color Copier
Copier NP6216 produces thick dark strips
Hello sir; I suggest you either replace drum blade or replace whole drum cartridge.
Aug 20, 2009 | Canon Office Equipment & Supplies
Canon photocopier 1600 Cleaning Blade not cleaning properly
Perhaps the pblm is not in "the drum unit"... check the mirrors may be are dirty.
Jan 12, 2009 | Office Equipment & Supplies
How to change the drum
On this machine it is beter to get a technition out to replace the drum.It is not as easy as the NP6030.
Oct 31, 2008 | Office Equipment & Supplies
245 people viewed this question
old marine
old marine
