Question about Frigidaire FGF326AS Gas Kitchen Range
Oven Fridgidaire Model FGF326ASF
F3 Code when trying to turn on oven, replaced part according to owners manual, still have the same problem. Don't know what to do.
  • bratface9121 May 22, 2009
    Yes, that was replaced and still getting the error.
Just moved in, range is working great but is it a self cleaning oven?
Posted on Jul 31, 2010
Oven Door Frigidaire model FGF326ASE door will not close
Posted on Jul 19, 2009
  • 39 Answers
You replaced the EOC? Thats what the issue is
Posted on May 22, 2009
I was cleaning my self cleaning whirlpool accubake oven and a F1 and E7 code appeared. I have just bought my house and the prior owner did not leave any manuals. Help please
Most Whirlpool appliance manuals are available from Whirlpool: http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . You will need the model number from the oven. This should be located behind the oven storage drawer on the rim. It will usually be on the left for a range and on the right for a wall oven. On rare models the plaque with the model number will be behind the door. If you add a comment with the model number, I'll try to post a direct link to the manual.
Are you sure about the error code? F1 and E7 aren't in my code books. I have an F7 and E1 code that indicates a short between the door switch or latch switch and the chassis or ground. (For double ovens, there are two of the switches for each door. The code doesn't specify which oven has a bad switch.) The F5 E7 error is a door latch that will not unlock. An F3 E7 error indicates that the warming drawer sensor has shorted out.
For the F3 E7 error, simply replace the sensor. For the other two errors, the solution depends on the door lock state. You start by unplugging the oven and checking all the wires and their connectors. See http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes for the complete set of steps. If the wires/connectors are okay, you probably need to replace one of the door switches if the oven door was locked when the error occurred. If it wasn't locked, then you can check the voltage to the various switches and replace any that are bad. If it isn't a switch, then it is the control that has failed and must be replaced.
I hope this helps.
Jul 02, 2011 | Ovens
My fridgidaire oven shows a f3 error code
F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 06, 2010 | Frigidaire Ovens
What the code f3 means on my conventional oven model # is 911.9584991
According to the code manual you have a defective Oven temperature sensor (RTD). The manual states it is open. You will have to replace it. Here is a link to the manual including parts blow outs and ordering info. Hope this helps
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-9119584691/0582/0124111/P0804107/00004?blt=06&prst=&shdMod=
Sep 06, 2010 | Kenmore Kitchen Ranges
We need to replace the ignitor on a fgf326asf, we
The stove Frigidaire Mod. FGF326ASF give an F3 error don't have manual instructions, could you tell me please what that means
May 07, 2010 | Frigidaire FGB24S5A Gas Single Oven
When I try to turn on the oven he control panel shows a f3 code
F 3 CODE FOR WHIRL POOL IS (OPEN OVEN TEMP SENSOR . replace this sensor . this should correct problem ..
Dec 03, 2009 | Dryers
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
Unfortunately, it appears that GE did not make that model to be repaired.
According to the owner's manual, there is a one year warranty.
After that, GE offers no support for it, but they sometimes make exception is people raise heck with Customer Service.
Good luck.
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Error code F03
although i don tknow what model your talking about all the F3 codes in ovens is pointing toward bad oven sensor, replace oven sensor
Mar 16, 2008 | Ovens
Kenmore Electric Oven Model 4088816 - Error Code F3
f-3 means the oven temp sensor is bad. replace the sensor and problem solved
Nov 25, 2007 | Ovens
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Frigidaire FGF326AS Gas Kitchen Range Logo
686 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
