Acer aspire screen goes all lines
Screen goes all lines all colors. only way to get out of it is to shut down and restart. can you help me
  • bamba456 May 11, 2010
    Did you try installing the drivers again?
  • 355 Answers
Parts that can be involved are LCD display, display ribbon cable, or in worst case graphic chipset on motherboard.
If the problem goes on and off when pressing LCD display enclosure, then it can just be the display cable or the LCD itself.
The computer must be taken apart to find out what is causing the problem. First you try adjusting display ribbon cable, then, if moving cable problem goes away, but you cannot fix it, you replace the cable that costs few dollars. If this still does not work you replace the display.
Cheapest replacement can usually be found on Ebay
Posted on May 12, 2009
Acer aspire 5520
try f8 at the logo screen then disable automatic restart on system failure from the menu to find out what the error is
Jul 15, 2017 | Computers & Internet
Acer is going straight to a black screen after the acer logo in startup....it just shows a tiny blinking line. It goes no farther. I need help fast
Apparently your Acer cannot find the operating system. As soon as the Acer logo comes up, there should appear in one of the bottom corners "F" & a number should appear. Immediately start pressing that F number (top row of keyboard). This should take you to a boot screen. Scroll down to boot sequence. Hit enter. Make sure boot-up sequence is CD or floppy drive first, second should be HDD, then escape. Restart computer. Should then boot off CD drive. I am assuming you have an operating system (XP, windows, etc.). Let me know if this doesn't work.
Apr 07, 2013 | Acer Aspire 5734Z4386 Notebook
I have problem with my acer aspire one note book, even after shut down i see light on bottom left corner,on screen and, if i remove battery then it goes, and again comes when i connect battery, thanks,...
make sure you are not just selecting sleep option instead of shut down, some comps have the sleep option set where the shut down one is .
hope that helps
Jan 09, 2011 | Acer Aspire One PC Notebook
Acer aspire one ZG5....connected to another monitor pressed control key and F5. The other monitor starts to boot up windows, gets to a certain point and then shuts off connection from acer laptop, who's...
As by your description, your mainboard of the laptop is faulty as the unit fails to produce a good picture on both its own LCD and on a external LCD
May 25, 2010 | Acer Aspire 5100 Notebook
Screen failure
since you can't restart or shut down properly from menu try disconnecting the power for a few minutes and then plug it back up and go from there. Maybe it will scan the disk and fix the error
Apr 04, 2010 | Acer Aspire One D150-1587 Netbook
Screen freezes and shows crazy purple colors in the screen or pink horizontal lines. The one time it shuts itself down, the other i have to use the on/off button to shut it down. When restarting it gives...
Incedible in one web page I found this solution and its work for me, the problem is the batery, just remove and no more frezee screnss and horizontal lines in color purple, Hope this helpt to you.
Oct 26, 2009 | Acer Aspire 5520-5908 Notebook
Vertical lines and then it goes white lcd screen
the only thing I have been able to do when this happens is force a shut down and completely remove all power sources to the laptop battery pack and chargers, wait a few seconds and restart.. this seems to be a common glitch with these acers... Mine has done this since day one I have had it for three years now and it is still functioning fine... so do that if ya want ..
Apr 08, 2009 | Acer Aspire 5100 Notebook
ZIG ZAG Lines on Screen, Computer comes to a halt. processes stop
resart in safe mode by tapping the f8 key as the computer starts , before it says "starting windows"
once in safe mode navigate to the controll panel, select DISPLAY, click the settings tab at the top, In the screen resolution box , set it to a lower setting , restart, if it works , save the setting and your done . If it doesnt, go back to display settings and change it to a lower setting and restart. you could also back the color quality to 16bit in the same place and this might help in some cases.
Feb 18, 2009 | Acer Aspire L100 PC Desktop
Acer aspire 5600 shut down
it sounds like the video card cannot support or handle the pressure put on it by the game you are trying to play, if it is an OEM game have a look for the minium system requirements that the game will run on, you can also find this information on line, you will probably find out that the graphics card doesn't support the game, do this check with all games you try to play
another thing is to upgrade your memory because some laptops don't have a devoted graphics card thus they are relient on the system memory
good luck
Nov 16, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
