Question about Optoma HD72 Multimedia Projector
HD57 WE ARE EXPERIENCING 2 VERTICAL LINES ABOUT 2 THIRDS FROM THE LEFT ON OUR IMAGES. WE FOUND THAT IF WE APPLY LIGHT PRESSURE TO THE ZOOM RING IT DISAPPEARS. ONCE WE LET GO IT REAPPEARS. COULD YOU PLEASE ADVISE?
Is the string connecting the lens cap dangling in front of the lens?
Posted on Apr 28, 2009
Hit it on top
Posted on Jan 01, 2008
Samsung 52" lines and double images until tv warms up
It is a Samsung which means power supply issues.
Jan 30, 2018 | Samsung Televison & Video
Screen show vertical lines from center to left. I open the front bessel and everything looks ok but when i apply some presure to the upper center between the two latches. that will make the display be...
Do the lines go away with the bezel off? You could put a piece of foam on the screen behind the bezel. Sounds like something is loose and if you can't tighten it, you possibly can keep the pressure on the screen to keep the display normal.
May 24, 2010 | Dell InspironTM 1501 Notebook
My camera was dropped. The LCD screen is black with two small crack lines on screen. There are some light vertical lines but no image at all (in camera or playback mode). Zoom moves. I can hear camera...
The screen is fully damaged. You will have to get it replaced. Prior to that click a few snaps and transfer them to yous PC and check whether all the images are sharp and do not show any problem. Cause the service centre might try to get more money from you saying a different problem was found. If the images are fine. dont forget to mention the same to the service centre people.
May 01, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Vertical lines in my laptop screen
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
May 19, 2008 | LG 42PX5D 42 in. Plasma HDTV
Vertical screen lines and resolution is in extra large format.
Possibly either or a hardware fault..
Does the pc have an external monitor port? Most do.. If you can get another monitor, plug it up and use the correct hot keys (keys on your keyboard) to switch between the laptop monitpr & the external, it might help diagnose the problem. Maybe select a generic driver for the external monitor.. Although the pc will probably pick it up ok. If you need further help, let me know. Rgds.
May 02, 2008 | Dell Inspiron 8200 Notebook
Printed lines shift to left and double images
Are the lines vertical? Have you tried to align the printheads? This can be done using your printer's installed maintenance software.
Mar 28, 2008 | Office Equipment & Supplies
LG Plasma picture probles
hi there. I have this same TV, and the exact same problem. Last night, i was playing around with it, took off the entire back of it to see if I could fix it. After a few minutes of tinkering, I found that if I apply pressure to the TV in a specific way, the left side of the picture comes back. Here's what I did: standing in front of the TV, I hold the top of it, in the middle with my right hand, and the upper left corner with my left hand. Then, I gently apply pressure, forward (away from me) with my right hand, and backwards (toward me) with my left hand. Sort of like trying to "bend" the screen. At some point, the picture comes back .. . the problem is, if I let go, then the colored lines come back . . . maybe one can mount it on a wall in such a way that the pressure is still there . .. i haven't tried. That's all I got.
Oct 27, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Optoma HD72 Multimedia Projector Logo
154 people viewed this question
Top Optoma Office Equipment & Supplies Experts
Computer Links
neOen
Level 1 Expert
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
