I can't boot in mac os 10.5 with my cd installation even with "C" press boutton thank you for your response zou
  • 72 Answers
U can change ur os settings.................
then u wil get it.
thank u
Posted on May 12, 2009
MacBook Laptop Will not boot from CD and OS freezes during setup
Since you have an Intel Mac book you can boot to DOS 6.22 and use Fdisk to remove your partition at which point you can format it and install Mac OS.
Apr 12, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have replaced my harddisk in ibook G4...how to install mac os
The problem appears to be that your ibook is only a G4 processor snow leopard needs an intel processor. The highest system you can instal on it is 10.5 i.e. leopard.
Jun 25, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
My PowerBook G4 does not recognize internal hard drive. when i boot without cd it will not boot and i will see a question mark on the screen and a small icon that represent mac os. i have Mac OS X 10.3...
If you plugged this into a PC and formatted it you probably formatted it with NTFS or another Microsoft file format. This will not be recognized by a Mac. You will need to pop the hard drive back into your Mac and boot to the installation CD. From here you will need to go into disk utility and reformat the drive with a GUID Mac Extended format partition. If you open disk utility and the drive doesn't show up you probably have an issue with the drive controller on the logic board.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jun 28, 2011 | Computers & Internet
When i turn it on it wont stop loading and after about 10 mins it turns off
font.f1 {font: 12.0px Helvetica} Thanks for asking your question with Fixya Support. I will be glad to assist you.
Try running a Disk Repair with Disk Utility using your Mac OS X installation disc or restore disc (which came with your Macbook)
font.f1 {font: 13.0px 'Myriad Pro'}
-RUN DISK UTILITY WITH STARTUP DISK-
Insert your Mac OS X Startup disk
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the startup disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Mac
See if that process helps bring your Macbook up to the normal desktop.
If it does not, use the SMC reset procedure.
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off.
• Disconnect the AC adapter and remove the computer's
battery.
• Press and hold the power button for 5 seconds and then
release the button.
• Reconnect the battery and AC Adapter.
• Press the power button to restart the computer
This should help resolve the issue for you. If it does not however, just let me know.
Thank you.
Regards,
Mactechtrainer
Feb 04, 2011 | Apple MacBook Mac Notebook
I have an acer aspire laptop with genuine vista os. i didnt operate for quit sometime and now, when i wanted to use it. it even didnt boot giving me a message. 'boot manager missing'. what is the problem...
If your Windows Vista computer has encountered the dreaded "BOOTMGR is missing" error, you aren't alone. If the problem isn't hardware related you can fix it with relative ease as long as you have a Windows Vista DVD handy.Boot off the Windows Vista DVD and then click Next at the first prompt:You should see a link in the lower left-hand side for "Repair your computer"The installation process will attempt to find your Vista installation directory. If there's more than one in the list, select the correct one and then use the Next button again.Click the first link for "Startup Repair".The installation process will repair the system, and then prompt for you to reboot.Alternatively you could have chosen the Command Prompt option instead, and use the following command to fix the boot options only:
bootrec /fixboot.
At this point you should be able to reboot your computer, remove the DVD and everything should be working.
Sep 19, 2010 | Acer Aspire 4730-4947 Notebook
My acer aspire 5315 always show boot prepare os. When i want to install windows it cannot show cd boot (booting from cd/dvd) so i can't install windows. what is the solution sir? thank.
Restart you computer then hit F2 for Boot Bios Setting then GO TO Advance. Change the SATA Mode . ACHE. ot IDE. or Comfatibility.. then enable the F12 boot. make in enable. the hit F10 for save and exit...
Insert you cd os Installer then hit F12 for **** menu. select the CDROOM for boot....
Dec 30, 2009 | Acer Aspire 5315 Notebook
Just repaired g3 ibook. Hard drive needs formatting, as it has xp loaded on it. Ibook starts up, boot tone, proceeds to load, then screen has a file in the center of screen with the osx finder square face...
With the OS X Installer CD in the drive, try booting your mac and holding down the option key immediately after you hear the start up chime. This will (hopefully) load a firmware boot loader that will show available start up discs. Hopefully the OSX installer will show up as CD Icon. Select the Icon with your mouse or keyboard and press enter to start up with the Installer CD. From the installer you should be able to erase and format the drive as Mac OS Extended before installing OS X.
If the computer still won't boot from the CD double check that it is a retail OS X installer CD. If your CD has "software restore" or "ibook restore" or any other varient of restore written on the label; or if it names a particular model such as "ibook install" or "imac install" it is not a retail copy and may not be a bootable disc. A retail copy will only name the version of the operating system followed by the word install written on it's label and usually have a brief instruction on booting from the CD by holding the C key at startup.
Hope this helps, let me know what happens.
Apr 03, 2009 | Apple iBook G3 Mac Notebook
Folder with blinking question mark in it after start-up
Folder with a blinking question mark means a missing system folder, in other words there isn't an OS installed. To fix this you need to boot from the OS X installer CD. With the OS X installer CD in the drive, hold down the C key on your keyboard when you start your mac. This tells the mac to boot from the optical drive (i.e. CD drive) and load the OS X installer. From there just follow the onscreen instructions to install OS X.
Also, you should be aware that the ibook is not compatible with Windows XP. Only the newer “intel macs” of the past few years are compatible with XP. Your mac predates Apple's transition to intel processors and Windows XP compatibility on the mac platform by a few years. This is why your Windows XP CD didn't load on it. The ibook is Mac OS X only.
It only runs on Mac OS X however it is compatible with newer versions of the OS. 10.2 jaguar is kind of old and a little buggy. You may want to consider installing 10.4 Tiger for improved stability and performance. Avoid the newest version (10.5 Leopard) as it is geared towards newer and faster machines.
Hope this helps. Enjoy your mac
Feb 03, 2009 | Apple Computers & Internet
Ibook G3 will not start
If you stilll have the Mac OS installation CD available the when it is starting up press down C and it will start from the Mac OS X installation Set up then you can reinstall OS X and it should work.
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
