Hello everybody
I have an inter d101ggc motherboard and i am using it with 2 X 512 MB ram sticks till today. Suddenly today, a blue screen error has occurred and computer shuts down and will never reboot (as it says a file has not matched with its checksum). So i removed one hard disk out of my two hard disks (2 X 80GB) and still the problem exists. So i performed a brute force check and found that all are working except for the ram sticks. The problem is if i use one of the either ram sticks in one of the either 2 slots ( d101ggc has two slots for ram) every thing works just fine (computer boots and vista loads). But if i install both rams computer doesnt even boot(not even a beep) . And if i change the order of ram sticks in the slots computer boots but says that a file hasnt matched its checksum and halts the booting.
Kindly provide a solution for my problem.
You've got either mismatched RAM memory or 1 of your sticks are bad. You can isolate this by booting 1 stick at a time. If the machine boots fine with both sticks (one at a time) then they are mismatched or your motherboard isn't configure to handle the 2 sticks together (not very likely but a possibility) Hope this clarifies your problem All the best!
Greg
Ok, assuming the following: the PC is virus free and you havn't made any recent changes to the BIOS, we're down to 2 possible issues:Bad battery; a bad battery doesn't supply enough power to the motherboard when it's powered down; most motherboards will try to work through start up errors due to lack of power but some will leave you with the BSOD (blue screen of death)
Bad motherboard; this would explain why you can't run both sticks of RAM at the same time; although it will run one at a time, a bad motherboard can be overwhelmed by both sticks of RAM suddenly running more processes than it can handle
I hope this helps and wish you the best of luck resolving your problem!
Greg
I am sorry..
If you read my problem carefully...
-->i have stated that i have earlier worked on the system with those two rams and
-->i have checked one ram at a time and they worked fine in any slot.
Hope the question is clear .......
Thank you any way for the solution...
Hack this problem please....
Thank you greg. I would take the suggestion and i am finally taking my pc to a service center for those two problems cant be solved by me.
