Question about Echo Garden
Need new flywheel the keyway is broke off for echo handheld gas blower model :SRM-1501
  • 246 Answers
Hello allenr154:
>>You can View a Breakdown/IPL of this Unit at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM and Enter the Model Numbers (SRM-1501). Then Double Click on the Model in the Results Area. Now you can Select the Section of the Unit you Wish to View.
The Flywheel Part Number is 15680144730 and is Approximately $67.40us.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
Where is the flywheel located on an Echo PB251 gas leaf blower?
Before you go through the trouble of dismantling the blower to get to the flywheel you should perform a compression test. 140 psi is ideal. Less than 100 its probably not worth repairing. Less than 90 it shouldn't run.
Jul 13, 2014 | ECHO, Inc. PB-251C Handheld Blower
Echo blower wont fire
you sheared the flywheel key... If it's a PB250 251 or something along those lines you are going to need a new carb and flywheel. Take it to the dealer and see if they can fix in under warranty... Why the carb you say, it leaked causing the flywheel to come loose. If it's not under warranty then do not repair, you can buy a new one for about $160 USD
Dec 24, 2013 | ECHO, Inc. PB-251C Handheld Blower
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
If it doesn't turn over when you pull the rope it could be in the starter assembly or the flywheel where the starter pawls engage it. If it turns over then you need to check for fuel, spark, air and compression.
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
My Echo Leaf Blower (PB-251) will not run at high speed. It is running to rich. Help please. Charlie
I've been fighting with an Echo PB-251 blower and an Echo SRM-225 string trimmer since near the end of last lawn season (this is the forth season I've had them). Along comes a thread on a firearms forum and lo and behold the answer to the problem is spelled out in terms even I can understand.
After reading that thread (which attributes the problem of the engine bogging down when throttle is activated to collapsing fuel lines) I was going to just replace the fuel lines, but I discovered that there are kits that include new fuel lines, rubber grommets, filters, clips and cap seals for about $13.00 each. Hell, the kit for the SRM-225 even provided a new primer bulb. Ten minutes after the UPS truck delivered them to my door I had both machines running like new again. If you've tried other things and it still hasn't worked I highly suggest you try this.
Jan 05, 2011 | ECHO, Inc. PB-251C Handheld Blower
How do you replace a broken flywheel on an echo pb 251
Not sure if I understand. Do you mean the complete flywheel inside the engine? Or are you talking about the impeller that draws in the air for the blower? Please repost if you mean the impeller, and explain a bit about what happened. If it's the engine flywheel, you basically remove the shroud/body until you get down to the flywheel, remove the nut holding it on, and remove the non-broken pieces. Then, put the new flywheel on, being careful to line it up with the keyway on the shaft. You can easily damage a new flywheel if you put it on improperly.
Dec 05, 2010 | Garden
Need oil/gas ratio for Echo back pack lblower - model PB-400E
Since every engine is different the manufacturer almost always has it printed in the gas cap. It should look like 50:1 or 50/1 (50 parts gas to 1 part oil).
Mar 31, 2010 | ECHO, Inc. PB-251C Handheld Blower
My echo pb2100 gas leaf blowers pull cord is loose and will not recoil
COULD BE THE SPRING INSIDE THE RECOIL NEEDS MAY NEED A NEW ONE
Sep 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
I just installed a carb kit on my echo srm 230 gas powered trimmer. I was very careful to put it back together the same way I took it apart. My problem is that I can't get the gas bubble to pump any gas...
on my srm-230, there is a screw under the bulb. Panilling9 is incorrect. There is one under the bulb and four on the outside. If yours is like mine, the four screws on the outside hold down a metal plate that in turn hold the bulb against a plastic plate (not sure what this is called). This metal plate has an extension at the bottom to protect the hoses. If this is put on backwards, the protector will be facing the wrong direction and crack the plastic hose connections when tightened (very easy to do without noticing). This would also be assuming that you put the hoses on the carb before you tightened down the metal plate. If this is the case, then air could be leaking in and you can't create a good suction to draw gas into the carb. Of course there are several other things that could be happening here, but just thought I correct the screw under the bulb issue.
Apr 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
212 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
