Question about Arris SURFboard SBG900 (49402201900) Modem
I can't connect the network games!!!
Hello I am using the wireless LAN with my laptop which the router is Motorola SBG900 . ISP:Telstra Internet.
I can connect the internet normally. Sign in MSN, downloads....
But I can't play any network games (wow) or login Garena server...
How to solve it?
Please help!!!!!!
  • 6 more comments
  • limitation May 12, 2009
    Thanks I had tried.BUT IT STILL DID NOT WORK.
    Thx .but i don't know the userID so i can't change the setting on router......
    "go with port forwarding.or u have to put a static ip address"
    how should i do?
    thx abhisek. but the username and password has changed..
    i only know the password
    u mean 192.168.100.1 ?
    with the username root password 12345?
  • limitation May 13, 2009
    thx even i don't get the permission to set the router....
    just 2 i use wireless directly..
    yup....
  • limitation May 14, 2009
    thanks i will try
  • 115 Answers
U have to change some settings on the wireless router.go with port forwarding.or u have to put a static ip address .Also u can try out DMZfirst turn off the firewall and try playingbest of luk
Posted on May 12, 2009
  • Abhisek Das May 12, 2009
    find the default gateway address which will be the ip address of the router,,type it in the address bar and userid box and password box will come up.default username is root,,passwrd:12345,,then check the options at the top ,,
    yep.192.168.100.1 is the ip address of the wireless router.put it n the adress bar and enter,userid and passwrd box comes up,,if it keeps on coming.then either the username or the passwrd has been changed.1 thing u can try is reseting the router,,but it will be a bit risky,,it will also disrupt your entire wireless netwrk and you hav to reconfigure the router.was the motorola router provided by ur ISP?call them up and ask them to reset it ,,take dwn the username and passwrd and then go inside the router settings,,best of luck again
SBG900 disconnects from internet periodically (15min - 1 hour)
does it happen at the same time daily or is it periodically ?
this might be because of an overload of users using your network at the one time or
it might be a fault in your wireless router how old is it ?
if you call your ISP internet service supplier during the outage time and get them to test the connection you will need to have your computer turned on they will be able to tell you where the fault lies
hope this helps you
Sep 19, 2011 | Arris SURFboard SBG900 Wireless Router...
Motorola SBG900 LAN problems
This is simply a firmware problem of your Motorola Router so what is the best thing to do here is to update the firmware of your router, you can download the latest firmware from Motorola's web site....
Oct 21, 2008 | Computers & Internet
Hi , plz guide me to connect my laptop to belkinRouter.
To begin with connect the Modem to the Cable/DSL/ADSL slot on the router and connect the computer to the LAN slot. Now run the disk given with the router. Enter your ISP settings and your internet would be working wired and wireless. Now connect to your wireless network using your laptop/wireless computer. Find the belkin network and connect to it.
Hope this helped.
Jan 23, 2011 | Computers & Internet
Set up wireless security
1 On a computer wired to the SBG900 USB or Ethernet port, open your web
browser (for example, Microsoft Internet Explorer)
2 Type http//:192.168.100.1 and press ENTER to display the login window:
3 In the User ID field, type admin (case sensitive) and press TAB.
4 In the Password field, type motorola (case sensitive) and click Log In to
display the SBG900 Setup Program main window:
As soon as your network is operational, run the SBG900 Setup Program to:
"Wireless Network Setup"
For a LAN with one or more wireless clients, enable wireless security on the SBG900.
After enabling wireless security on the SBG900, as required on each wireless client:
> If you disabled ESSID broadcasting on the SBG900, set the client Network
Name (ESSID) identical to the ESSID on the SBG900.
> If you enabled WEP on the SBG900, set the client WEP key identical to the
WEP key on the SBG900.
> If you enabled Allow Only Listed Stations Access, be sure the MAC
address for each client is correctly listed on the SBG900.
Dec 22, 2010 | Arris SURFboard SBG900 Wireless Router...
Having problems connecting my lap top to my wireless cable modem. Its a motorola SBG900 gateway. everything seems to be connected. Im able to use it with a ethernet cable just need help geting it to be...
Ok. As per your statement your laptop is working perfectly , when you are connected your laptop with with the cable wire.So the network cable is OK. So you have to configured the wireless cable in your laptop when it is connected to your laptop. After connecting the cable wire to your laptop you have to findout the gate way of your ISP ( Internet Service Provider). To find out the gate way , kindly follow the following instructions.
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ).To find out the above mentionedaddresses first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of Motorola SURFboard SBG900 Wireless Router will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly.
Oct 03, 2010 | Arris SURFboard SBG900 Wireless Router...
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SB5100 and linksys router connection
The only thing that you need to setup on your Linksys for it to work with cable is to make sure that DHCP is enabled on the router.  You will need to plug your router into the modem via the ethernet cable and then plug your neighbors pc into a link port on the router (the cable modem plugs into the internet port)  You will also need to follow the reboot procedure.  Power everything off.
1: Turn on the surfboard and wait about 1 minute for the surfboard to make a connection with your ISP (the link light should come on).
2:Turn on your router and wait for your router to sync up with the surfboard . 3: Turn on your computer. Whenever you plug anything into a cable modem, you must recycle power to the modem.  It "remembers" the last device that was plugged into it, so it's memory needs to be cleared.
Apr 24, 2009 | Arris SURFboard SBG900 Wireless Router...
Motorola SBG900-SiS191 Ethernet Controller
Setup your IP addresses correctly by checking available IP addies in router.
You will have to know your router addie and your available wireless addies (in router). For this you need to enter router configuration (read manual).
Open network properties, tcp/ip properties, check "use following ip addie and enter something like 192.168.1.5 depending on what your router is setup as available.
Enter same subnet as your router.
Enter DNS server addies from you ISP.
Feb 02, 2009 | Arris SURFboard SBG900 Wireless Router...
Wireless Doesn't Work - No light.
If someone else setup the router for you they may have turned off the wireless. If you can connect via ethernet use the web based configuration utility to turn it back on.
The intial setup is as follows in the manual:
To provide an initial wireless connection to your network and the Internet:
1 Connect the SBG900 to the cable TV system as described in Section A.
2 On each wireless client computer, install the wireless adapter hardware and
driver software according to the manufacturer's instructions.
3 On each wireless client computer, set up a wireless adapter profile to
“connect” the client to the SBG900. The procedure depends on your
wireless adapter and computer operating system.
In your initial profile, use the SBG900 default wireless Network Name
(ESSID) motorola (case-sensitive).
Your computers are connected but not secure.
The default SBG900 settings provide no wireless security. After
your wireless LAN is operational, be sure to enable security as
described in “Setting Up the Wireless LAN” in the SBG900
User Guide
Oct 30, 2008 | Arris SURFboard SBG900 Wireless Router...
Arris SURFboard SBG900 (49402201900) Modem Logo
548 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
