Question about Samsung YH-925 MP3 Player
Yh925 i just changed the battery and when i turn it on i get an error message that says initial fail. the device cannot initialize HDD
  • rangermike Nov 24, 2007
    I installed a new battery and when I turned it on I got an error message that stated:
    INITIAL FAIL
    The device cannot initialize HDD
    Please connect to adapter and try again.
    I connected to the adapter and received the same error message time after time.
  • Anonymous Mar 29, 2014
    THE DEVICE CANNOT INITIALIZE HDD
    Problem Solver:
  • 10 Answers
I know your problem. Your HDD is not clipped in. Press that little square circut thing in untill you hear a click.
Posted on Dec 30, 2007
SOURCE:
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
them from Dell or even using somebody elses (match version with sticker on your laptop).
Check the hdd connection underneath laptop - make sure cable is not loose, etc.
Probably safe to say your data is gone unless you're willing to spend $$.
Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
Initialization failed
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Selah.
Sep 15, 2008 | Computers & Internet
The device cannot initialize HDD?
Remove the back panel of the player you will probably find that it will work fine. I did this to my daughters unit and found that the panel was pushed in and depressing the reset button all the time. I rescued it out of the garbage when she bought an i-pod, now I have this unit for myself and it works great.
Jul 26, 2008 | Samsung YH-925 MP3 Player
SAMSUNG YH920GS- Error Message- device cannot initialize hdd
You are missing a critical update from Microsoft that will allow the computer to recognize this as an MTP device rather than an MSD device - this is a new problem that did not exist before.
Try a firmware upgrade, but it may not be successful since the repair was unsuccesssful.
Otherwise, get all the most recent Windows Updates from www.microsoft.com.
If none of the above work, write me back.
-Tha Mp3 Doctor
Jan 01, 2008 | Philips SA4010 MP3 Player
Samsung YH 925
Hi, run the recovery utility that you install from the CD. Reinstall firmware. C
Aug 07, 2007 | Samsung YH-925GS MP3 Player
Initial fail error
The HDD is disconnected from the player. When you open up the player just carefully push the circut board thing on the gold foil behind the hdd in untill it clicks.
Feb 17, 2007 | Samsung YH-925 MP3 Player
Error message
Did you try pushing the reset button and/or reinstalling the software? sometimes that helps. Also, I have a question for you: I am thinking of replacing the battery on my yh-j70, as it is getting weak, was it easy for you to open the player and can you then simply pull out the battery or do you have to solder? Would you happen to know where batteries can be bought for this unit? Thank you
Oct 30, 2006 | Samsung Yepp YH-J70 Digital Media Player
Samsung YH-925 MP3 Player Logo
184 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
