Question about Norcent Technologies Computers & Internet
How do I turn the monitor volume on for a norcent
Had desktop speakers set up and took them off, now I'd like to use the monitor sound. How do I turn that on?
Norcent 19" monitor
    Sergeant:
    Champion:
  • 225 Answers
Please try to go to Control Panel > select Sound, Speech and Audio Devices > select Sound abd Audio Devices > then at Speaker Set-up select Monitor Stereo speakers. Best regards
Posted on May 13, 2009
No volume on my norcent television
check the simple things first:
Do you have sound when a DVD ETC is connected via rear inputs for audio and video?
Look to see if speakers in set are switched ON or OFF.
Look to see if volume is down or very low both on the set and a box if one is used.
If set has connections for external speakers is it set Internal or External.
May 16, 2012 | Norcent Technologies LT-3222 32 in. LCD...
How to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
May 02, 2012 | ASUS Computers & Internet
The Sound of the Monitor is not working.
Check cable connections between the monitor and the sound card/motherboard output, you could unadventedly dislodged it, check the monitor speaker volume control on the monitor menu. If all else fails connect the headphone input directly to the PC case front or back sound output - much better than via the monitor anyway - shorter pathway makes better sound, last but not least: use a better set of speakers - monitor speakers ****
Mar 06, 2010 | Computers & Internet
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
Can not get this monitor to play sound on PC using XP Version 5.1. a driver needed?
there is not a windows xp 5.1 so I am going to take a wild guess and you mean you want 5.1 surround sound
If your computer plays sound through its own speakers normally then you do not need a driver.
I took this from the FAQ
  1. Make sure the audio cable is plugged in to the back of the monitor and in to the Green port in the back of the computer.
  2. Press the Right Arrow button on the monitor itself and set the volume to 10.
  3. Double check your audio settings on your computer and make sure nothing is muted.
This is not one of the better monitors in this price range having only a VGA input but is suitable for most people.
Aug 14, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
Recently, I purchased an Acer H233H LCD Monitor with the HP e9180f Desktop. However, the built-in stereo speakers in the monitor are not working. The sound card in the desktop is fine, as headphones and my...
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
Jul 25, 2009 | Acer H233H bmid Monitor
I have computor with Norcent LM 965WA monitor. Really liked the fact it had built in speakers. Worked great, now when I plug in the wire from compuitor to monitor, static but no sound. Any suggestions...
Hi and welcome to FixYa,
With your indulgence, pls verify that it is indeed the built-in speakers of the Norcent that is the issue. Temporarily plug in to the computer a pair of headphones or even an old external computer speakers. If sound, then the monitor speakers are verified, if likewise static, then it is a computer issue.
Let's try the easy one's first:
  • check/replace the cable;
  • try other ports to plug it in at the computer;
  • determine if the sound device/driver for Norcent shows up in your Device Manager;
  • determine if on Sound Property in COntrol Panel, the Norcent is selected as the default device;
  • you may want to update the firmware and driver available here.
Would appreciate a postback for any updates on any development(s) (or even the lack of any). Pls include what Operating System you are running and if the Norcent is using USB connectors or standard cables. Good luck and thank you for using FixYa.
Mar 09, 2009 | Computers & Internet
No sound
What kind of monitor is it? What kind of sound is it?
Many companies will let you access and print out their manuals for free online if you input your model and make on their website. Search under "manuals".
Also, the HP w22 LCD I have has internal speakers whose settings and volume levels are controlled through the buttons on the front bottom of the monitor. The monitor has a 'PC Audio In' jack on the back side, which is used to input the digital signal from the back 'audio output' jack of the computer desktop. This HAS to be plugged in with a specific audio cable to power (transmit the digital signal to) the internal speakers.
Check your settings for your external speakers by clicking on 'control panel', then 'hardware', then 'speakers' (IF your computer has located them, meaning that they're plugged in with their driver downloaded). You should be able to configure the speakers and test them for sound.
Windows may have a 'volume mixer' on your taskbar that controls the levels of your Windows application sounds, your device (speaker) sounds, and the Media Player(s).
Dec 11, 2008 | Computers & Internet
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Need Help With Speaker Problems
Have you tried the speakers on something else it could be the plug clapped out Thats a bold question when one says "I know the speaker is not defective,".....it sounds simple...but I think a little more common sense HERE!!! You might want to try some headphones if the sound comes out of the computer than the problem clearly lies with the speakers sometimes they may like they were going good but when on the move some strange things happen to the speakers that one cant quite fathom. I think your speakers have clapped out why Im positive they have.......goodluck
Sep 01, 2007 | Norcent Technologies LM-962 19" LCD...
Computers & Internet Logo
279 people viewed this question
Top Norcent Technologies Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Piyal Perera
Piyal Perera
Brandon Murphy
Are you a Norcent Technologies Computer and Internet Expert? Answer questions, earn points and help others
