Question about Frigidaire Gallery GLWS1339EC Top Load Washer
My washing machine fills to the correct level initially, then keeps draing and refilling. It used to work if I put the selector on one notch less than full, but now it does it on every size setting.
  • 1,543 Answers
Make sure the drain pipe the washer drain hose goes into is at least 34 inches above the bottom of the washer. The drain hose must not be sealed to the drain pipe, or you may experience siphoning of water out of the washer.
Posted on May 12, 2009
My washer fills fills with water but doesn't agitate. Water just keeps running, then leaks out the back
Sandy, it's not a matter of recognizing (or not) the wash cycle. There is a pressure switch (behind the water level selector) which determines when the water has reached the correct height. If this switch is defective, the machine will continue to fill.
If you can give me the model number of your machine, I can provide you with the part number of the switch. Depending on your model, replacement of the switch is not difficult.
Feb 01, 2015 | Washing Machines
Have a Model 100 bosch washing machine will fill but does nothing after that .Doesn't seem to wanna spin or move Drum/
Try rotating the load size / water level selector switch back and forth. If this works, then your switch is going out. If it keeps on filling and doesn't stop, then your selector switch OR the level sensor (both located in compartment behind controls) is bad (probably level sensor).
The motor is locked out until the water level requirement is met, then the level switch allows the motor to be turned on.
Sep 10, 2010 | Bosch Washing Machines
My Aeroccino keeps overflowing even though the level of my milk is below the min level.
I am having the same problem but not every time. I went back to where I bought it and spoke with one of the reps and was told that if there is moisture under the rubber seal on the lid this will happen. To solve this I remove the rubber seal and clean it and dry it off after I am done using it. Also turn the lid over on top when not in use. Hope this helps.
Mar 01, 2010 | Nespresso Aeroccino Automatic Milk Frother
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Washing Machine won't stop filling up
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
May 20, 2008 | Maytag Performa PAV2200
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Not draining
Clean out the lint draw and then run vinegar through a cycle.
If this doen't work try CLR. or/and put the drain hose to the lowest level and then put a flexible clear tube down to unblock it.
Use less detergent in the machine. I make my own detergent and I don't have any problems as one of the ingredients in it help keep all lines clear.
If that doesn't solve the problem contact Bosch directly.
Jan 08, 2008 | Bosch Nexxt 700 Series WFMC6401UC Front...
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
78 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
