Question about HP PSC 2355 All-In-One InkJet Printer
Error:0xb9000027 my hp printer displays error:0xb9000027 on the little lcd screen when I place my memory card into the slot on the printer. Whats that mean?
  • Inala Praveen Kumar May 11, 2010
    It means, the data on your memory card is corrupted(may be coz of virus).
    There is no problem what so ever with the printer,fault is with the card.Try formatting it using a card reader and re-try it in the printer.
With my pc hooked up to the printer i get error
codes on it it is a psc 2355v all in one
Posted on May 22, 2009
What's your question?PLEASE HOW CAN FIX HP 5100 PRINTER CODE 53.13.03
These error occurred with the printer's memory in DIMM Slot J3 (as labeled on the formatter board). This may be unsupported memory.
To help you troubleshoot the error 53.13.03 appearing on the HP 5100 printer, please follow the steps given below:
- Press the Cancel Job button.
- Turn the printer OFF, and turn it ON again.
- If the message returns, check the memory DIMM in Slot J3 to ensure it is supported memory.
- Move to a different memory slot to determine if the slot is bad.
- Reseat or replace memory in DIMM Slot J3.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-bpl11648
If the message persists, contact HP Support Center for further assistance from the link given below:
http://www8.hp.com/us/en/contact-hp/support.html
GuruAid.com
Jun 02, 2016 | HP Office Equipment & Supplies
My SanDisk 8GB will not download in the printer - an error saying Memory Card Error shows on the screen
The D7160 works with SD cards. Your 8GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work with this printer. You need to use SD cards, 2GB or smaller.
Oct 09, 2013 | HP Photosmart D7160 InkJet Printer
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
Sd slot used to read cards, now "memory card error"
i am trying to copy my photos from my 4 GB SD memory card on to my computer through my printer HP PSC 2355 all in one printer. But as soon as i put the card into the slot it turns green and the a couple of minutes later turn Red and flashes and i cannot read it on my computer
Dec 04, 2009 | HP Office Equipment & Supplies
When putting the memory card into the slot, the screen reads 'memory card error'. Also, will not read the camera when plugged into USB socket. Please Help!
The camera port only supports USB-equipped digital cameras that support Pict-Bridge. If you attach a USB device that is not compactible digital camera (or Bluetooth adaptor) to the camera port, an error message appears on the color graphics display. If you have an older HP-brand digital camera, try using the USB that came with the camera. PLug it into the USB port on the back of the HP-all-in-one and not into the camera port near the memory card slots, This works with HP digital cameras only.
By default, Windows XP will format a memory card of 8 MB or less and 64 MB more with the FAT32 format, Digital cameras and other devices use the FAT (FAT 16 or FAT 12) format and cannot operate with a FAT32 formatted card. Either format your memory card in your camera or select FAT format to format your memory card in a Windows XP PC.
Hope this helps.
Thanks.
Have a good day.
Nov 30, 2009 | HP Photosmart 2610 All-In-One InkJet...
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Memory card error when using sd card to download pictures
Hi
Whats the memory size of your SD card? this printer only support 1gb card.
Thanks for using Fixya
May 13, 2009 | HP Photosmart C6100 All-In-One Printer
My 5 yr. old stuck a screwdriver into one of the memory card slots....now a camera light is flashing and the display panel shows, "Memory Card Error"
If the power was on when he did that there's nothing that can be done other than buying a new hp officejet, If power was off you will still have to get a new officejet, because then pins to read the memory card will be beyond repair.
Mark
Apr 09, 2009 | HP Officejet 7210 All-In-One InkJet...
HP Photosmart 2610 error message
Turn off your printer. Look in My Computer for any HP Memory card icons. Right-click on them and disconnect all that you see.
Mar 19, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP PSC 2355 All-In-One InkJet Printer Logo
287 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
