My computer won't turn on
Screen says input missing
  • eitan ger
    eitan ger May 12, 2009
    I have the same problem
Did you check the cables? please check if they are all connected
Posted on May 12, 2009
  • 413 Answers
Kindly check the vga cable and also see that cpu is in running condition sometimes due to cpu failure you may get such message but usually it is the video cable from monitor that might not work
thanks and regards
Superscan tv
Since you didn't give the model SuperScan TV, I am going to speculate that your TV has composite video input only; like the 19TVD3S that I know. If your laptop has a VGA port, you will need a VGA to composite video converter. See http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011407&p_id=4724&seq=1&format=2 . Other stores have similar items. You can't use a VGA to composite video cable; these cables are for connecting to projectors that read the computer's RGB signal.
Other converters are available for VGA to component video. If your laptop has an HDMI output, then a HDMI to component video converter would be a good idea. (A few rare computers came with TV out; then you just need the correct adapter for the port to composite or component video.)
Next you may need to enable the external video output in your BIOS. The port can be disabled for power-saving. In that case, look at the splash screen as your computer boots up. It will tell you (in a brief blink) if you need to press Esc, Del, F1, F2 or another key to access the BIOS. Press the key repeatedly after turning on the computer (after shutting down); if you miss the timing, turn off the computer and try again. I've missed the timing several times.
Once the port is active, make sure that the TV is on and set to the video input. Then turn on the computer. If you have Windows, you will have to choose the screen to use for your display. For most newer versions of Windows, right click on a portion of the desktop (somewhere with no icons or running programs). Select Screen Resolution or a similar line. Then you can select using the monitors as duplicate monitors, extended monitors or Monitor 1 or Monitor 2 only.
I hope this helps.
(If your TV has newer inputs, use the VGA port if available. The HDMI port for many TVs do not always interpret a computer HDMI signal correctly.)
Jul 02, 2013 | Computers & Internet
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Westinghouse SK-26H520S no picture sound
The input signal is missing and the blue screen background comes on the screen. Change the input to some other device which you are sure works and see.
Jul 25, 2012 | Westinghouse SK-26H520S 26 in. LCD HDTV
Vizio LCD TV Model L37HDTV10A - I have attached a Digital TV Antenna to the proper input, but once I open the on screen display go to the DTV input and attempt to access the TV setting to program the...
Sometimes it takes a while for the TV to go through this set up such as a half hour to an hour. Just be patient an make sure the antenna is set to air.
Jun 20, 2011 | Televison & Video
My Philips 170C monitor does not work when I turn on. It only says "attention signal off".
it thinks this is no input signal. make sure your computer is on and the cables are secure, switch your screen with a known good one from a freind. this will rule out your computer. if the pc is fgood maybe go into the bad monitor menu settings and make sure the input mode is correct. if this is not the cause you may need to have it repair, your monitor video or display board maybe bad.
Dec 26, 2009 | Philips 170C4FS 17" LCD Monitor
"Input not supported" roaming on my screen
It means that the resolution of the windows is set too high for your monitor. You will have to find some better monitor to connect it to it, and then to lower the resolution, after that, it should be working just fine
Nov 15, 2009 | Acer P191WBD LCD Monitor
System software missing,I installed updates on web updater on my garmin 465T and it said it was finished so I unplugged it from the PC and now it won`t work.The Garmin logo comes up on screen and above it...
Did you first make sure it was safe to disconnect from your computer before you unplugged the unit??? You first must click on the icon that shows you have something connected to the computer and click the turn it off, or safe to disconnect box and wait for the computer to tell you it is safe to do so. Try that,, and see if it helps you.
Sep 10, 2009 | Garmin Nuvi 465T Car GPS Receiver
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Computer won`t boot
u will have to reformat the hard drive and load win 98 or win xp whichever u want to fix this
you can have more detailed info at
http://www.computerhope.com/issues/ch000474.htm
Jan 31, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
