Sir, I have purchased a intal 945 Gccrl Oem Motherboard on 10-may-2007 from Computer Empire(Nehru Place) .motherbord no display .pl change my mother bord. BTCR70800ER0 AAD78647-300 D945GCCR Vikas sindu 458/10 Rampura Chander Quater Delhi-110035 Mobile-9718896547, 9313144801 E-Mail-vikasdesigner51@yahoo.com jitender_mb@yahoo.com
My motherboard (M/b intel 945 Gccrl Oem) is not working due to the problem of no display. I had purchased it from computer empire at nehru place on 10TH may 2007. so,please take some action towards my...
Your motherboard's warranty expired.
You need to repair it by own and if you don't want just purchase VGA card for the same. it cost you around 1000-2000 INR.
May 15, 2009 | Intel D945GCCR Motherboard
945 Pl Driver
There are 4 versions of the 945PL. The drivers, utilities, and manuals for all can be found here:
MSI 945PL Downloads
Thanks for using Fixya.
Mar 26, 2009 | MSI 945PL Neo-F...
THE SLOT OF AGP CARD IS LOOSE WHAT'S THE OPTION?
first use ur on board display card for this
pick out ur agp card from agp slot and then check ur display if it is ok then change ur agp card if it is not ok then clean ur ram and re insert in motherboard and then chk if same then try with other ram moduel.
Jan 29, 2009 | ASUS K8S-MX Motherboard
No Display
hi, when you start your computer its giving a beep if not check your memory(Ram) remove it and check it your motherboard giving a continous beep, if yes replace your ram
Sep 26, 2008 | MSI K8MM-V Motherboard
Processor for P5VDC-MX
Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
Jan 29, 2008 | ASUS P5VDC-MX Motherboard
Aopen motherboard: MS-6378 VER:3 Faulty
just u clear the cmos and load the defaults settings in bios then  restart the computer.,if not check the cmos voltage +3v,if voltage not appear pl change the battery it self
Was it helpful to u pl give the rating for me
Thank u
Oct 23, 2007 | AOpen AX34-U Motherboard
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
