Question about Samsung Refrigerators
Refridgerator won't cool, freezer is OK
Samsung refridgerator MODEL # RS2358BAWW, Refer won't cool. The freezer is ok.
  • Anonymous Apr 01, 2014
    Have Samsung rs263tdbp and the demo/cool off mode will not turn off. Have pressed the Light and Freezer buttons together for mode than three seconds and still stays in that mode. Help!
  • 159 Answers
If it is a bottom freezer and top refrigerator it is low gas in the system need to be topped up
Posted on May 22, 2009
Why is my refridgerator not cooling?
unplug thermistor if doesn't cool over nite bad cooling unit of ok bad thermistor
Jun 04, 2014 | Dometic DM2862 Americana Plus Fridge...
Refirdgerator won't cool proprely on refridgerator side
Hi SN,
This could be a couple of things, but you should check for evaporator icing, even though you said the freezer is working and the defrost control appears to be ok. If the evaporator is iced up, no air willl flow into the fridge section even if the fan is running.
You can also check the damper control board. I am sending you a link that shows a complete breakdown of your appliance. I do not work for this company nor am I affiliated with them in any way. They also have a troubleshooting section and contact information. See:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5121995&diagram_id=29020886#d29020886
Aug 18, 2012 | Refrigerators
Freezer works fine but top refridgerator won't cool
HI.TRY DEFROSTING IT ALL FIRST.IT MIGHT WORK.GOOD LUCK.ALI
Jun 25, 2012 | Maytag Refrigerators
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Freezer stopped working
ok,is the freezer fan working?is there frost buildup in the freezer?it sound like you have a defrost problem whick means your defrost timer,defrost heater or defrost sensor has failed,you need to check all the defrost parts to pin point the problem,let me know what you find-mike
May 22, 2008 | Traulsen Reach in Freezer - G12010
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
161 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
