Question about RCA D52W136D 52 in. TV/DVD Combo
Antenna analog input tunner broke off inside the box wondering if i could bypass it useing converter and the digetal input tunner
  • 30 Answers
Yes, just make sure your converter box has composite and you're set to go. Your antenna will then plug directly into your converter box. If you end up needing more than one port (dvd player, gaming console, etc.), grab up an A/V switch which also works off of composite and you're all set to go.
Posted on May 12, 2009
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
Mintek DTV-260
The Mintek DTV-260 only has a NTSC (analog) tuner. You will need to connect your RCA antenna to a digital to analog converter box to watch TV over the air. Then connect the output of the converter box to your TV.
The common converter boxes are limited to SD output. You might be able to find an HD converter box online. (With the standard converter box, the available outputs are coaxial and composite video.) The DTV-260 has a composite video port; alternatively set the TV to channel 3 or 4 and use the coaxial (RF) input on the TV.
There may be a low-power station that still broadcasts in analog. However these are rare. You will need to switch from CATV to OTA (Air) to check for one of these stations. Analog Cable has different parameters than scanning for over the air signals.
I hope this helps.
Mar 04, 2014 | Mintek Televison & Video
Antenna input on back of tv broken off
if your converter box has rca output toy can hook it up that away. Or you can look on ebay for a new main board. very easy to replace. be sure at all time to unplug tv while back cover is removed.........hope this helps
Dec 01, 2013 | Sharp Televison & Video
Can you bypass a converter box by using a dvd player that has all the hookups?
you must read your owner manual, and see the diagrams attached, and proceed according. use the common sense. God bless you.
Sep 19, 2012 | Sony TV & Video 5-Disc Progressive Scan...
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
A converter box for digital tv
of course!, as long as it has some way of connecting it!, via the antenna input or video in (yellow/red/white)
Dec 12, 2008 | Coby TVDVD1350 13 in. TV/DVD Combo
Converter box
1) Connect the coax cable from the antenna to the converter box input.
2) Connect the coax cable output of converter box to the input of the VCR.
This is the only way it will work but you will have many limitations such as using the programming features of your VCR.
The boxes are fine if you want to play prerecorded DVDs or tapes. If you want to record tapes you have to leave the box on and have it set to the station you want to record.
May 27, 2008 | Insignia Digital-to-Analog Converter for...
2006 RCA TV Digetal Receiver
NBC newsperson said I should check nbc.com to learn
what to do for the change in February. Where is it ??
You want my solution ? Improve your web site.
Feb 23, 2008 | Televison & Video
Antenna
if you want o spend money on this is up to you that tunner may cost $80.00 plus and next year we wont need analog tunner so if you have video imputs use a vcr as a tuner or get converter box
Jan 11, 2008 | Philips Magnavox MS2530C 25" TV
RCA D52W136D 52 in. TV/DVD Combo Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
