Question about Ruud UBHC Air Conditioner
Replace Rudd Achiever 10 ???
My Rudd Achiever 10 had the fan motor replaced and repairman left saying it was all fixed. However, I could not get cold air. It would blow but not cold. He came back and said freion was Ok but compressor had gone out. How does it blow if that is true? He says I probably need a new unit (this is 17 yrs old) rather tan replacing compuressor. Something doesnt sound right. He did not know what the cost of a new unit would be. I may better cut my losses and run. What can I expect to pay for a new unit? What to do? Get estimates? Any answers will be appreciated.
  • steve
    steve May 11, 2010
    Was the fan motor inside in the airhandler or outside in the condenser?
    Do you have a volt/ohm meter?
  • Robert Moller
    Robert Moller May 11, 2010
    What test did he perform to condem the compressor ?
  • 148 Answers
If the fan motor outside let go it could overheat the compressor which he should have known before he replaced the motor. also there is no way of knowing if there is enough freon in the system if the compressor does not start,your best bet is to get another repairman as a second opinion
Posted on May 12, 2009
Rudd air conditioner outside fan won't start
I just had the same problem. I replaced the motor with no luck. It turned out to be a bad capacitor. If it is a dual capacitor, three prongs on top, it also starts the compressor. It is recommended to replace the capacitor anytime you replace a motor. I would try replacing the capacitor first. It is a lot cheaper that a new motor. If that does not fix the problem then you can get a motor. No harm, no foul. The slow start of the motor is a common symptom of a bad capacitor. The motor is not getting enough voltage. The capacitor increases the voltage like a transformer. It will boost it to almost 400 volts, depending on your unit.
Jun 21, 2012 | Heating & Cooling
I have a Rudd Achiever 10 . The unit was working yesterday morning, it stopped in the afternoon , and is still not working. The fan in the unit in the basement is working fine. Do you think it could just...
you will need to check you condenser unit(the outside unit) here is a website that may help,Tim:
http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-troubleshooting.html
May 30, 2011 | Ruud UBHC Air Conditioner
I have a RUDD Achiever 11. The outside fan only intermittently runs and seems to quit in the evening (overtime for the air condo techs). It won't start again until the morning but when it runs, it blows...
Two possible problems here.
1. you have a bad condenser fan motor. average cost $140.00 for the part plus installation if you can't do it. just buy the motor you most likely will be able to use the existing fan blades.
2. you have a bad run capacitor on that fan. avg cost $5.00 - $35.00 plus installation
In my opinion if you're handy and safe with electicity save some money, if not have it done.
check out grainger.com for the parts they're very reasonable. for the fan you'll need to get specs from the defective unit like amp. voltage rpm. its all on the unit itself. for the run capacitor you'll need the same. all the info u need is on the parts. search the site for run capacitor or condenser fan motor.
good luck hope this helps
Jul 15, 2010 | Ruud UBHC Air Conditioner
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
Need Fan Motor and Capacitor
The best place is from rudd the cheep price will leave a bad taste in your mouth long after you replace it with after market parts. And the cost will be double. My experience in buying aftermarket parts almost cost me my business when the parts failed and I had to replace for free. Once you plug in a electrical part you own it. Take my advise don't save money on a aftermarket part unless you want to pay for it's repair twice. How ever if you still want to do this look in the yellow pages in your phone book in your town for any motor re-winder and they can get you one. or look on the net with your zip code for the closest rewinder.
Feb 05, 2010 | Ruud Matching Split Air Conditioner
I have a Rudd Achiever 14 and I want to know if
Take the front panel off the air handler and look for a heat element. You should notice controls and relays with larger wiring to it. It may not have any heat but you can add it.
Jan 05, 2010 | Ruud Handler Air Conditioner
Ruud Achiever 10, outside Fan wont spin unless I help it.
The part you are talking about is called a capacitor. They come in various voltages and ratings. The best thing to do would be to find the rating tag on the motor, and look for the capacitor rating. There are many, many different sizes and types, so it is best to consult a proffesional before attempting to replace it on your own.
Jul 06, 2009 | Ruud UBHC Air Conditioner
Rudd achiever 10 a/c will not kick on and some line is frozen in the unit.
The line will have to be thawed out with hair or air dryer. This may have frozen other components as well including a/c compressor relay or capacitor giving power to a/c compressor or motor unit
Jul 01, 2009 | Heating & Cooling
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud UBHC Air Conditioner Logo
342 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
