Question about Refrigerators
Compressor on, coil frozen, no inside fan, ice melting.
POWE IS ON,INSIDE FAN NOT ON, COMPRESSORAPPEARS TO BE ON, ICE COVERED COIL FOOD THOUGHING, ICE MELTING.
    Guru:
  • 1,524 Answers
This is a defrost problem (heater,timer,limit switch)
Posted on May 12, 2009
Samsung rf265abpn ice forming behind Fresh food fan, ice filling up funnel under cooling unit, was told to hang a piece of coat hanger off heat coil.
Hi Mike,
You could have an outside airleak which would let in warm moist air into the freezer.OR the condensate drain tube is plugged up or frozen up. thats the drain tube that drains the melted ice from the freezer OR the condenser fan located buy the compressor is not running. Check all drain tubes and drain channels for clo-
ging or freeze-up due to improper and complete draining.
Oct 20, 2011 | Samsung RF265AB (258 cu ft) Bottom Freezer...
Freezer is not keeping food frozen and water is leaking between the freezer door and seal on the freezer door? The fan is blowing cool air.
is the compressor running?how long has the freezer been melting out?if you open the fridge door,turn the cold control up and listen to see if you hear the compressor start,if it doesn't try tapping on the control with a screw driver,if the control is bad it sticks inside and if you tap it sometimes it will free it and start but it will stop again,just doing this to check what's bad in the fridge,lso there's a timer in the fridge section,look around where the control is,you'll see a hole in the bottom of the console,you can stick a straight bladed screw driver up it and turn it slowly until it clicks,if the compressor starts when it clicks you have a bad timer and it was stuck in defrost,if the compressor is running and the freezer is still melting out you could have a leak in the sealed system a freon leak,you can check this by removing the back inside wall of the freezer,look at the evap coil,if there's just ice on the top instead of an even frost pattern over the whole coil then you have a freon leak,if the fridge has been running and you look at the coil it should have frost covering the whole coil,if ice is just on top it's new refigerator time,get back to me and let me know if the compressor is running,iis the door closing correctly and no rips in the gasket,if it has a light in the freezer push the light switch in and make sure the light is going out,if not the bulb is heating up the freezer,make sure the evap fan is blowing in the freezer and no ice on the back wall of the freezer,has any water been dripping into the fridge from the freezer,if so you have a blocked drain.do some checks and get back to me,if the freezer is melting out it sounds like you have a compressor problem
Mar 26, 2011 | Maytag MTB2156G Top Freezer Refrigerator
My GE Profile Artica ice maker is making ice, but when I open my freezer, there are icicles from the ice compartment one the food below the ice maker and dripping down the inside of the freezer. The ice...
Hi!!
The Ice Maker and the Freezer/Fridge part of the unit work separate, that's why you get the ice made but the freezer can't keep it frozen.
Most likely the condenser, located in the back of the freezer is all frozen and covered with ice pluggin up the air ducts to the fridge, preventing it from cooling.
One quick solution will be unplugging the refrigerator and allowing it to defrost on it’s own or remove the freezer's back panel and using a heat gun or hair dryer to melt the ice, this will take about 20 to 30 min..
There are various reasons this type of problem:
The temp. controls are not set properly. Set controls according to manufacturer recomendation.
The small fan in the freezer is not working,
The defros timer is not working or,
The defrost heater coil is busted.
Once the ice is melted, plug unit back in and check for unit reactions. You should be able to hear the freezer fan working. Also, you'll hear about 4 to 6 times a day the defrost heater melting the ice in the back of the freezer, if NOT, check heater coil for continuity.
Don't forget to rate this post. Good Luck.
Jun 07, 2010 | GE Profile Arctica Stainless Steel Top...
Hotpoint refrigerator freezer(top) mod ctx18bacerww not cooling/freezing correctly. removed inside back panel in freezer compartment,found coils partially covered in frost, fan not blowing.. flicked fan...
Hi, fan may have stuck, but you could have a defrost problem, check defrost heater, thermodisc(defrost thermostat) and defrost timer. or excessive moisture, if your days are hot, or if you put hot foods in ref. could result in excessive ice build up. you can manually defrost it, by unpluging ref. for couple of hrs, until all ice melted. then restart. you make get excessive water on floor. be prepared.
Aug 02, 2009 | Refrigerators
Whirlpool ET18TK model evaporator fan
if cover is off there will be no air down there..was there frost on the coils ? if no then compressor is not running..if compressor is running and no frost..no freon or compressor valves shot.
Jun 10, 2009 | Refrigerators
My refrigerator is not keeping my food cold or frozen!!
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Mar 24, 2009 | Kenmore Refrigerators
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Compressor cycles
Yeh The klixon relay is not at fualt its the compressor im sorry to say that in my opinion that the compressor has failed.
the clicking sound is the compressor trying to start but inside its all burnt out and jammed.. If you need any more help or adivice then dont hesitate to ask
Jan 03, 2008 | Refrigerators
Refrigerators Logo
256 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
