Question about Yamaha HTR-5830 Receiver
No Sound From DVD Input
Have the DVD player hooked to the TV via component cable.  The sound is from the OUT to the Receiver.
No sound, but I do have pictures.  I reset all factory settings on the Receiver and then cycled thru the A and B and still got no sound.
It is connected via the 6 channel inputs.
How can I get some sound?
I had the same problem,. I when in to settings on my dvd player while the dvd disk was on stop mode, (by pushing display buttom in remot.) in settings I activated sound and better picture by choosing componet. hope this help....resolution (set your dvd righ not your tv.)
Posted on Dec 05, 2007
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
Cant figure out how to hook up the receiver to my phillips hi def tv and get the sound?
its old model, will not pass hd video, good only for audio. Connections depend on your equipment. If you use a cable box to watch tv, connect cable box audio out rca connectors (red and white), by an audio rca cable, to audio TV input on the back of the receiver. Now when you swith your receiver to TV input you get sound from cable box trough your speakers.
If you use DVD player: connect audio out of the player to dvd audio input of the receiver. Switch the receiver to DVD input, you have sound from DVD.
Jan 08, 2011 | Denon AVR-1403 Receiver
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
No sound fom optical input
Do you have your TV hooked up, so you can see the AVR-4800 system menu on its screen (if not, see the manual). You need to go down to the digital input menu item where you associate each component with its input source, whether it is coax, optical 1, optical 2, ..., etc.
Dec 07, 2008 | Denon AVR-4800 Receiver
Cant get the wiring figured out.........
TV is HD correct? Use the Y/CB/CR from the Sat to the TV. Use the Digital optical cable for sound from the sat to the receiver. Use the s-video from the dvd player to the tv and the l/r to the receiver for sound. I would suggest upgrading to another set of Y/CB/CR cables to connect your dvd to the TV and benefit from better picture. Also, buy another optical cable for dvd sound (so you can enjoy surround sound). Your receiver has two optical inputs so youre covered there.
Sep 03, 2008 | Kenwood VR-407 Receiver
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Yamaha HTR-5830 Receiver Logo
115 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
