Question about Mitsubishi SL1U Multimedia Projector
Working but lamp warning on screen,lamp led flashing
When swithing on projector, lamp indicator starts flashing and message lamp appears on screen but with apparently working
  • 3 Answers
Press < and > and Power buttons at the
same time on the projector to reset the
lamp hours counter
Posted on Oct 22, 2009
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
Viewsonic projector Pro 8200 will not start / get out of standby mode
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | ViewSonic Office Equipment & Supplies
Warning message for lamp replacement appears at each power up!
After replacing the lamp, make sure the lamp cover is securely closed. Select the Lamp Replacement option in the menu, (MENU > Settings > Setup menu) and follow the on-screen procedure.
Apr 20, 2017 | Sony LMP-H130 Projector Lamp Projector...
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Projector won't turn on and LED Temp/Lamp flashes! has new lamp
I wish you had received a relevant answer to your question, as I'm experiencing exactly the same thing here. Not sure is this site notifies people when they get responses, but did you ever figure out what the problem was?
Apr 08, 2010 | Optoma MovieTime DV10 Multimedia Projector
Infocus sp5000 red led blinks once indicating lamp
be sure and reset the lamp hours. Flash the software if you can. These are also notorious for the ballast cable on the inside of the lamp housing backing out when a lamp is removed or replaced. If you have the cover off push the cables back into place and hold them there as you install the lamp. Also look directely at your lamp in the center and move it side to side and up and down. If there are any cracks or frosty looking spots or bubbles in the mirror of the lamp that are visible, then the lamp is probably shot. If all this fails, most likely it is the power supply, or the lamp door has gotten mishapen from heat and the actuator on the lamp door isn't making full contact with the safety swith.
Jan 29, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
PT-L785U Projector
if the lamp warning light is flashing, this indicates a defective ballast (lamp power module). if the lamp warning light is lit steadily, then the lamp would be at fault.
Oct 13, 2008 | Panasonic PT-L785U Multimedia Projector
Mitsubishi SL1U Multimedia Projector Logo
185 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
