Question about Acer Power F1 PC Desktop
CPU Shutting Down the PC
Hi, my ACER F1 Desktop has a Pentium 4 3.2 installed. The CPU fan is not working effectively and is causing the PC to shutdown once the CPU is hot. I don't know what type of CPU it is and therefore don't know what type of fan to buy, plus I don't know how to take it out of the PC. There are 2 clips either side of it, which I haven't been able to remove.
Thanks
  • sureshbopiti May 12, 2009
    Thanks Greg,
    I will try to pry off the clips, was a bit worried earlier about them breaking. Suresh
  • 1,959 Answers
The clips attach on either side of the heatsink. They usually just pry up to remove (take a pic if u can of the heatsink b/4 removing clips). I'm guessing the fan is loaded with dust. Cleaning a fan will usually fix any problem you're having with the fan itself. If after cleaning the fan it works and PC still shuts down, you have 1 of 2 problems:
  • Bad power supply; make a not if the fan for the power supply is still working; a can of compressed air does a nice job of cleaning the inside of the PC including the power supply
  • Bad motherboard; only cure for bad motherboard is replacement
I hope this clarifies your issue and please don't hesitate to post back with other PC issues. All the best!
Greg
Posted on May 12, 2009
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Asus CG Series desktop keeps shutting down after CPU fan and power supply replacement. What is wrong with this thing?
get a heatsink compound and paste on the processor before putting the fan, or either the cpu fan isn't working constantly, or the power supply, or one or both of the replaced parts are not for your system, may be the power supply is for pentium 3 etc ...
Oct 01, 2013 | Computers & Internet
My acer Keeps shutting down Could it just be dirty or do need to upgrade the power supply
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 18, 2012 | Acer Black AX3400G-U4802 Desktop PC with...
Acer Aspire t690 Desktop Freezes or reboots with in minutes of start up...Running Windows Vista. Help???
It is possible that your computer is overheating and is shutting down to prevent it from doing any harm to itself.
Make sure that all fans are clean, there must be no dust present as it hinders airflow!!!
Install as many fans as possible. Computer temps should be in the region of 30-40 degrees centigrade. To avoid CPU throttling, where the CPU slows down to prevent frying itself.
Please take the time to rate my expertise.
Thanks
Nov 01, 2010 | Acer Aspire T690 (AST690UP820A) PC...
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
Thanks for the response to my Acer L100. have checked the cables and they are fine. have noticed the fan doesn't start up when the computer is switched on....could this be the problem???
The CPU fan should turn on when the PC is powered on, and then it usually slows down until the workload on the processor causes it to heat up, then the fan spins faster, it might also be a power supply issue, but if your able to boot and its giving you messages and not shutting down then you should re-install the operating system.
Nov 18, 2009 | Acer Aspire L100 PC Desktop
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
CPU shutting down.
Hi MonaMona,
Replacing a CPU fan is easy, but be carefull, the CPU will have old thermal grease on it, so unlatch the CPU at the same time you take the fan off. Because the CPU will come up with the fan, so unlatch the CPU pins, to release the CPU pins, when taking the fan off. And when putting the new fan on the CPU, & the fan nust be smaller then 80mm, the sell just CPU fans. Make sure you put on thermal grease on the CPU, so it won't over heat & will protect your CPU, also don't cake on the grease. Put on a small amout & spread it on the CPU thin. Let me know if that does it for you.
Good Luck with it.
Mar 09, 2008 | Acer Veriton 5200D PC Desktop
CPU fan not working
you need to check your power supply if this is okay you need to replace the cpu fan. the cause of shutting down is the overheating of your cpu
Jan 06, 2008 | Acer Veriton 5200D PC Desktop
Problem with my Computer
Is this a desktop or a laptop?
In either case, it could be one of your fans is not functioning. There is a fan on top of the heatsink on the CPU. If it's not turning then the CPU will shut itself down before it's destroyed...this is a good thing. If this is a desktop then the case fan may have failed. Make certain both of these fans are turning. You will need to open the computer to see the CPU fan.
If they are both turning then it's possible the CPU heatsink fins are filled with dust. This prevents airflow. If this is the case, use your vaccuum cleaner to get the dust out. This will be much easier if you have a desktop, opening laptops is more involved.
Please let us know what you find.
Dec 20, 2007 | Intel Pentium 4 3GHz 512/800 CPU processor...
Acer Power F1 PC Desktop Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
