Question about Samsung SPN4235 42 in. Plasma HDTV
Was smoking and had a burning smell and now tv won't come on
Smoke coming out of the plasma tv and burning smell and the tv won't come on.
  • ESTEBAN MERINO
    ESTEBAN MERINO May 11, 2010
    you need to call the repairman you might have different parts that needs to be replaced
    good luck
    caypianan@yahoo.com
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Samsung HP-S4252 gaseous smelling smoke and loss of picture
Unfortunately, your problem is familiar; the odor you smelled was signaling the death of an electrolytic capacitor.
The electrolyte gassed off after the part grew hot and finally burst.
You will not likely be able to do the repair yourself since the cap could have first been destroyed by the failure of a diode rectifier so replacing the cap may not cure the problem.
If you are adventurous, you might pull the plug on the set, allow the set to sit overnight, gain access to the innards, and with good light, inspect any boards inside.
If you see one that has few ICs but many more larger discrete parts, this will be the power supply.
Again, before touching anything inside, especially on that board, allow at least several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
You are looking for components called electrolytic capacitors that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many failed caps (not all) will show signs of pregnancy when they fail, bulging unnaturally at the top when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will be four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006. This is due to the use of a defective chemical made in China and used in millions of parts made by other companies, never suspecting that they were building time-bombs doomed to fail.
The larger caps may be OK since the failure is likely related to functions other than brute-force filtering. A pretty good 'rule of thumb' is to replace any caps you see bulging of any value but especially those that are 100 uFd or less.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace it or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
If you choose to replace failed caps yourself, you will need a quality soldering iron with a small, preferably iron-plated tip, rosin core solder and a sponge which when wetted is used to frequently wipe oxidized solder from the tip. This should be kept bright and clean and fresh tinning will keep it that way.
You should also buy some solder 'wick' with the iron; this is used to place on the solder you wish to remove and then heated with the iron. Properly used, the wick will absorb nearly all of the solder from the lands from which you wish to remove a component.
Avoid lingering too long on the soldered area since this can cause the trace's bond with the board to yield, lifting the trace.
Posted on Nov 26, 2008
panchal643Ja
  • 243 Answers
SOURCE: The other night our Samsung plasma tv started
Some Capacitor of your plasma is defective pl change as soon as possible If you can do it than do it or call engineer for this.
Posted on Jan 25, 2010
  • 8457 Answers
SOURCE: my samsung hl56a650 tv power cycled and then
The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Jan 10, 2011
  • 18 Answers
SOURCE: techwood 42" plasma screen television
Do not turn this television on! Any electronic that smokes is NOT GOOD! The smoke and accompanying smell is from plastic and solder that is being melted by a short on one of the TVs logic boards. Call a local TV repair man this is not an issue you could fix yourself and will most likely be better off buying a new television. Stay away from off brands like these, spend the few extra bucks on a name brand like Sony, Toshiba, LG, or Samsung and you won't encounter these types of issues.
Posted on Feb 15, 2011
Smoke and burn smell from driver side front tire, slite ringing under hood
do not drive it , havee it checked out by a mechanic
May 27, 2015 | Cars & Trucks
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Jul 27, 2014 | Frigidaire Dishwashers
Why is there smoke?
Kindly switch off the TV, switch off power, and remove plug. The TV needs servicing by a qualified service technician.
Aug 23, 2012 | Toshiba REGZA 37RV530 LCD TV
TV catching fire
I have a 32inch Sceptre TV. Recently the picture stopped showing and smoke ces from the back of the set. I unplugged it and am waiting on the authorzation to return it as it was just purchased in February. Like the other writer I have another these sets in my bedroom. If anyone has further information I would appreciated it.
Jul 10, 2012 | Sceptre X32GV-Komodo 32 in. LCD Television
Is it possible for a 10 year old planar plasma hd tv flat panel to emit fumes in a room. Like someone is smokeing?
Hello
No. Ofcourse not. What are you saying. Smoke over the TV!
Switch it OFF. There is something wrong with its internal circuit. Any capcitor or resistor burns. Cannot troubleshoot remotedly to this fault. Plasma TVs may heat up to an extent, and there will be fans at the top of them to **** out the heat produced while it works. Look, whther the fans are working. If not replace them or findount the reason.
A plasma Tv; whatever old it is; won't blow out smoke at all. OK.
Oct 20, 2011 | Planar PDP-42BK 42 in. Plasma HDTV
Techwood 42" plasma screen television
Feb 15, 2011 | Samsung SPN4235 42 in. Plasma HDTV
I have a 2001 ford ranger and white smoke is coming from my tailpipe that smells like gas
your tail pipe is always going to smell like gas the white smoke is oil being burned from worn out valve guides or rings.
Dec 09, 2010 | Ford Ranger Cars & Trucks
Smoking out the back and burning smell inside.
check for a cracked head that smoke you see is probably antifreeze coming out of the coolant trench in the block itself or could just be a bad gasket on your head
May 06, 2010 | 2004 Mazda 6
Burning Smell with Samsung HC-p5241w
dont fear the smoke behind. firstly open your tv. get a brush and clean the in side,it might be other particals dropped in side.
you are able to see where the smoke is coming from.
a qualified tech will solve that without wasting time on it.
Jan 07, 2009 | Goodmans 257NS 20" TV
Samsung SPN4235 42 in. Plasma HDTV Logo
1,018 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
