Question about Olympus VN-2100PC Digital Voice Recorder
Fast forwarding How do I fast forward to specific content without changing folders and starting the recording all over a gain?
  • Doctori Jun 19, 2008
    how do I fast forward to the bit of speech that I need to get to quickly?
    Problem Solver:
  • 15 Answers
I would set index marks if you need to get to a specific part. I am not sure if that's what you are trying to do. (not sure about changing folders - you always need to be in the folder where your files are) Check video manual on Olympus 4100PC at www.HandBookLive.com under Electronics category. There are chapters on setting index marks (scroll to the end of the video chapters)
Posted on Sep 07, 2008
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
How to rewind/fast forward trough currently listening segment?
Touch the screen, and 'reverse', 'pause', and 'forward' icons will momentarily appear on the lower portion of the screen. Before the icons vanish, touch either the forward or reverse icon and continue to hold your finger on the icon without lifting it off of the screen. Fast forward or rewind will then begin, at a rate of 5 seconds per second held. I am told after holding for 15 seconds or longer the speed of the fast forward may increase (true for other Coby models I have owned), but so far I have had no luck getting this to occur with my MP828.
Jun 23, 2012 | Coby MP828 layer
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
I can't seem to be able to fast forward any more than twice speed. I know there is some way I can program it that it allows me to be able to do that but I can't seem to find in the manual where I...
Hi Henry,
  1. Usually DVD players DVD players come along with remote controls which have fast forward buttons which have the icon as ">>" .
  2. All you need to do , is press the button as per your requirement of fast forwarding.
  3. If you press the one, you would get a message as x2 on the TV screen and if you again press it , it would display x3 and if you press the button again it would show x4 , that is the maximum speed you can have usually for fast forwarding.
  4. So the solution is to keep pressing the button multiple times to change the fast forward speed.
Hopet his helps ...Your feedback would be appreciated.
May 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Ps3 skip previews instructions
Get a VHS system. It's easy to fast forward and easy to copy movies and to record off of live tv.
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
Camera plays in fast forward-like speed
Though I don't know the details of your camera and the tape you are playing, one explanation could be that the tape was recorded in "extended play" EP rather than "standard play" SP. Some VCRs and some cameras are incapable of playing back in EP, a mode where the tape moves at half speed so you can record more on the same tape. The result is that the tape playing back at regular speed appears twice as fast and fast forward will be even faster.
Unfortunately, unless your machine can be manually set to play back in EP (usually it is automatic) the solution is to play it back in a machine that can handle EP.
Dec 04, 2008 | Electronics - Others
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Olympus VN-2100PC Digital Voice Recorder Logo
74 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
