Useing jack-RCA for insert
I need to makeup some leads for the inserts useing stereo jacks and RCA connectors
  • 189 Answers
SOURCE: subwoofer conection
Ideally you want a speaker wire to RCA adapter like this one.
http://www.crutchfield.com/S-LaUCVO5Otro/App/Product/Item/Main.aspx?I=136CLR2SW
Posted on Jan 05, 2008
SOURCE: Sub Woofer Won't Work
mbruno did this work? I have the same issue
Posted on Jan 16, 2008
  • 121 Answers
SOURCE: Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Posted on Feb 26, 2009
dunnbiker
  • 8546 Answers
SOURCE: no headphone jack on samsung tv,so i got a ,y
Headphone output is usually dependent on the source's volume setting and are not a good way to transfer signal between devices. RCA is the way to go as it is independent of the volume control. Many TV's have a setting for the audio output to select variable or fixed (independent of the TV volume setting). Look for it.
Posted on May 16, 2009
tech240
  • 169 Answers
SOURCE: bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Posted on Sep 20, 2009
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
What do i need to play back recorded video onto my t.v from my sony handycam dcr-trv260...i have s cord, usb cord, yellow rca jack??? so what else do i need!!!...nothing i have tried has worked???please...
You can connect this camera to a suitable TV with either the S-Video lead or the RCA lead, but only if the TV is equipped with the appropriate inputs. The S-Video lead looks like a tiny DIN plug, and the RCA jacks are three separate plugs coloured red, white and yellow (yellow is composite video, red and white are left and right stereo sound). If you use S-Video you will also need to make a separate connection for sound (using the red and white RCA connectors). Sometimes the TV sound input is a mini stereo jack, and you will need a Y connector to adapt the two RCA connectors to the mini jack, or maybe the camera's sound output is also by mini jack, in which case you may need the reverse Y connector. Most TVs have some way of accepting a video signal, but you may already be using it for a DVD player or the like.
If your TV lacks these connections, you may be able to use an adapter. In the UK, most recent TVs have a SCART (Peritel) socket, which takes a big plug with 21 connections on it. You can get an adapter to fit that socket that will allow you to plug in the RCA connectors and maybe the S-video too. I don't know what country you are in, or what adapters are available in your country if it isn't the UK.
Once you have made the connections, you must select the appropriate input on your TV. The other possible hiccup is setting the camera to the right video standard, NTSC or PAL., to match that used by your TV.
The USB cord will not connect your camera to the TV.
Jan 11, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
I have Radioshack wireless headphones with a 30 foot range. I cannot hook them up to my new Panasonic Viera 42 inch HD T.V. - The "audio outlet" is a square and the headphones only have red and...
hi there.
At present, the square connector is what is called an "Optical" connector.  It's purely digital and transmits digital data via what looks to us like a RED LIGHT.  Your headphones are incompatible. Your heaphones have an analog connection on RCA Phono type connections.  The type you usually get on the back of hifi equipment.
The pannasonics DO have a headphone socket, but it is the small 3.5mm type socket.  a small round hole that looks slightly larger than a pin head.  It normally has a small diagram of a pair of headphones above or below the socket to indicate what it is.
In order to connect your headphones to your set you will need a stereo,male 3.5mm jack to two RCA Phono jacks.
If your current lead on your headphones has "male" ends, the red and white ends should have silver or gold points sticking out.
If your current lead on your headphones has "female" ends, the red and white ends should have silver or gold surrounds with holes in.
With this in mind, if you have male ends you will require a stereo 3.5mm jack to stereo female Rca Phono vice versa so that they basically lock into eachother forming a "Constant chain".
I have tried to explain this as best I can, I hope you've managed to get the idea of what I'm saying.
You will either need this :
http://cgi.ebay.co.uk/1-2m-3-5mm-Stereo-Jack-2-X-RCA-Phono-Plugs-MP3-/270689011629?pt=UK_Computing_CablesConnectors_RL&hash=item3f065287ad
or this :
http://cgi.ebay.co.uk/3-5MM-STEREO-JACK-MALE-2X-RCA-PHONO-FEMALE-ADAPTER-/360300626060?pt=UK_Computing_CablesConnectors_RL&hash=item53e397408c
Sometimes the colours of connectors vary.  Just remember that Red to Red (for right hand side)  and White to White or Black To White  or Black To Black (for left)
Jan 07, 2011 | Audio Players & Recorders
Just bought a stereo mini to rca cable. i have a macbook and a 32" dynex tv. I dont know where to insert the cables on the tv.
you need a mini to two rca plugs cable; once you have this: connect the red rca plug to the left TV stereo rca connector and, the white rca plug to the right TV stereo connector
and, the mini stereo plug to your speaker jack on the macbook You will now have sound.
then: connect the video to you macbook using another either s-video or, vga cable to the TV
Aug 03, 2010 | Televison & Video
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
How can i play my ipod - do i insert jack into phones and ipod, then what do i need to do?
If you dont have an ipod port, then run a 1/8" audio cable from the Headset jack to the Line Input or Aux input of your stereo. If your stereo receiver has Left and Right RCA style connector inputs, you can find simple cheap adapters at Best Buy.
Good luck
Dec 30, 2009 | Sharp CD-MPX850 Shelf System
I have a samsung NC10. I have connected to my TV via the PC cable. I can see the screen but here no sounds. I have connected the red/yellow/white audio cable to the tv. It has a jack plug on the other end....
The cable you are using is a rca audio/video cable. The colors translate to:
  • red=audio,right
  • white=audio,left
  • yellow=composite video
Your laptop headphone input uses a ⅛′ (3.5 mm) mono and stereo (TRS).
You need a Stereo 3.5mm mini phone plug male to 2 RCA female connectors.
Nov 07, 2009 | Samsung NC10-11PBK Netbook
How do i connect graphic equalizer to reciever
A graphic Equalizer (GE) is acomprehensive tone controller which enables cut and boost over wide range of frequencies a Klark Technik DN27 was a mon unit and had 27 bands) And a DN22 was stereo with 11 bands /ch
They are called as named because when viewed from a distance they look like a graph of the sound.
Normally a GE is inserted into the signal chain between the pre amp outputs and the power amp inputs.
So look on your equipment for these rca /jacks. (pre out) (amp in)
It is possible to do the in /out fubctions on one connector (stereo jacks) so look for jacks marked insert point.
This will be a very suitable place for the GE connection.
Hopw this helps. thanks for using Fixya
Sep 27, 2009 | Yamaha Audio Players & Recorders
How would you connect a Roland Space Echo direct into a Behringer 2642a mixing desk? Have tryed all inputs/outputs with nothing. Could this be because the mixing desk has ballanced ins/outs and the Roland...
In order for this to work, you need what is called an "insert" cable. This will have a balanced 1/4" connector on one end and 2 1/4" mono-connectors on the other. The balanced connector is also known as a TRS connector (Tip,Ring,Sleeve). You should have "insert" jacks on the mixer. Place the balanced connector into whatever insert you wish to use (usually this is inserted into the main insert). One of the 1/4 plugs is for input, one for output. I don't know which is which for your specific unit, you will have to experiment. Keep us posted. Dan
Jun 12, 2009 | Behringer Audio Players & Recorders
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
29 people viewed this question
 Grubhead
Grubhead
