Question about Motorola Mobility MPx220 PDAs
MPX 220 Cell phone
I have an MPX 220 cell phone.  I have purchased two replacement batteries.  Both batteries held the initial charge, but would not charge a second time.  Once the initial charge disipates, the phone is non-operational with or without ac adapter.  Any suggestions?
0 characters
1 Points
Nokia n96 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 17, 2012 | Nokia N96 Smartphone
Hi, my phone HTC Innovation has no power indicator. even i charge it long. but this phone has not been used for a year, then right now, i try to charge it. there is no power, no heat indicator that the...
Please test the voltage at the battery terminals of the phone with the battery removed. If voltage is present the battery must have developed reverse polarity and will not charge as a cell in blocked.
so replace battery but if there is no voltage the adapter is faulty.
Sep 28, 2010 | HTC 8100 Smartphone
I went in the sea with my phone in my pocket yesterday this was yesterday is there any hope 4 my g1?
Follow these procedure to save or revive your phone, remove Cell Phone from Water: Time is of the essence when it comes to saving a fixing a submerged cell phone, as soon as you see your phone in water, remove it quickly! Every second matters do this step quick.
Saving the Battery: In order to save the battery on your cell phone after it's been wet, quickly take the battery out of the phone as soon as you take it out of the water. Buy doing this you will ensure that minimal damage is done to your battery.
Drying the Phone Out: Quickly shake your cell phone to get all of the water out and reach for the paper towels. Press down on your cell phone to make sure all of the excess water has come out. If you have accessories such as cell phone covers, take them off promptly otherwise water will still be stuck in your phone.
Saving your Info: If your cell phone takes a SIM card, quickly remove it before the phone dries. While you may still loose some of your information, you won't lose it all if you take the SIM card out of your cell phone in time
.Removing Excess Moisture: To remove the unseen moisture in your cell phone you will need to cover it with either Desiccant gel packs or rice. Desiccant gel packs can sometimes be found when purchasing brand new shoes or clothes. Make sure your cell phone is completely covered with either one of these for up to 3 hours.
Vacuuming: Take your vacuum hose and place it up to 4 inches away from your cell phone with it on. While this won't remove all of the water, it will certainly eliminate the big spots of water damage.
Turing the Phone On: After allowing your cell phone to sit a day or two with the power off, turn it on to see if it works. More than likely if you followed these steps as soon as your phone was submerged, it will cut on. If not, you will have to purchase a new cell phone because the one you have can't be saved.
Take care.
Aug 08, 2010 | HTC G1
My N96 battery died,So I put it on charge and nothing happened. I then replaced the battery with a new one and charged that up enough to turn the phone on. I then put it on charge again so i could give it...
It appears that the phone is not charging the battery. you may need a new charging connector or mainboard repair. You can get a free repair diagnosis and estimate from cell phone repair services.
Nov 14, 2009 | Nokia N96 Smartphone
Tmobile Dash won't work at all
I had to visit quite a few stores and finally purchased a used battery from a licensed dealer. With the new battery I was able to restart the phone and the new battery also held a charge. This phone is prone to overheating and gets what the phone tech called, "thermal shutdown." Too hot, it turns off or freezes up. I ran into other problems with this phone so I finally got a different one.
Aug 07, 2009 | T-Mobile Dash Smartphone
My cell phone has been on the charger for over 8 hours and i have just recently purchased another battery and it still says low battery and to wait a few minutes and the phone will power on so what else...
This can be a problem on the battery terminal or the charging terminal of the unit. It could be the unit has not giving a proper charge or the unit has a problem when you try to charged a battery.
It is better to send the unit into the nearest service center to check the unit, and better not to charge on the for the moment it was not fix, to avoid any further damaged or burnt out on the unit.
Hope this helps.
Just let me know for further clarifications.
Jul 28, 2009 | T-Mobile Sidekick
Keeps resetting itself
there is a small watch cell battery inside your phone cercuite. actually its not a lithum watch cell. replace using another phone watch cell.
Jul 19, 2009 | Palm Treo 650 Handheld
try a hard reset. I had same problem and hard reset seems to have solved it.
Dec 21, 2007 | Motorola Mobility MPx220 Pocket PC
Stops while talking
Hi folks with aging JAMS. My JAM is still dying (complete shutoff) using phone. I wish it would just lose the phone signal but my unit shuts off completely during phone calls. I can have 80% charge. I spoke with a friend that mentioned on his cell phone (different manufacturer) that although his battery will show a full charge or less, the time it takes for the charge to go down is ridiculously fast once the battery is old. He watches his phone lose a charge in under an hour though it charges to full.
I wish IMATE would make some formal post regarding when to get a new battery and what symptoms are possible. I'm a bit hesitant to invest in batterys if the issue is hardware. I use the unit alot--as a PDA, a phone, etc. It gets jostled about so maybe something is lose inside, though I doubt it.
I purchased a cheap phone charger so in the car I'm recharging and at work I just keep a cheap USB to plug charger. I reserve the phone when I'm out. This is not really optimal for cell phone use but it's a behavioral fix. I figure I should be looking at a new device (despite high prices) soon.
I did a full discharge/charge cycle or two or three but only noted short term benefit. At some point the quirky behavior returned and off went the PDA cell with the 80% charge. I see dots of us around the net. Again my Jam is probably 3 years old this March.
Oct 28, 2007 | i-mate JAM Pocket PC
MDA problems
Your battery is very very low. The red light is indicating an almost dead battery. In fact, you may have a battery that is too low to charge. Or you may have dead cells in the battery that require you to purchase a replacement. Try my guide to manual battery charging. I have it listed in all of the HTC Wizard (which is actually what type of phone you own) sections.
Oct 04, 2007 | T-Mobile MDA
Motorola Mobility MPx220 PDAs Logo
52 people viewed this question
Top Motorola Mobility PDAs Experts
David Payne
David Payne
Abby Carter
Are you a Motorola Mobility PDA Expert? Answer questions, earn points and help others
