There is mold on the rubber gasket of my Maytag front load washer. How can I remove it?
  • jsterly2port May 16, 2009
    Thank you for the solution to try a Magic Eraser. It took most of the mold off, and it looks a lot better.
  • 130 Answers
Try a Magic Eraser first. That usually works. If not, use straight bleach and a white cotton rag to clean it off. You may even need to scrub it with an old toothbrush if the mold is thick.
Posted on May 15, 2009
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    RUBBER LINER COLLECTING MOLD
    I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
    Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Mold on rubber gasket of washer
    Clean with a strong solution of bleach and water. Don't latch the door between washings.
    Jun 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Smell of mold and mold on rubber in front loader
    If you don't leave the door open when not in use and not wipe the door dry and the door gasket dry, mold will build up as there is no air to let the moisture escape into. Makes sense, manufactures do no not say this in their manuals, I think they should !
    Mar 20, 2010 | Maytag Neptune MAH6500A Front Load Washer
    Mold on rubber gasket on Maytag Neptune washer -- how do I get rid of it?
    you can not the door boot has to be replaced there is a black commercial one available although unsightly it will not cause any harm
    Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
    MOLD REMOVAL FROM WASHER RUBBER BOOT
    Try this:
    Run an empty load and as soon as water has filled and the washer begins to run, open the washer door (probably have to pause the washer via the control panel) and add 3 - 4 cap fulls of regular bleach. If you don't have regular bleach, you can try vinegar. After cycle completes, open washer and wipe the entire gasket with an old towel.
    When washer is not in use, prop the door open so the inside can fully dry.
    Please report back here with the results and if you are still having problems, we can take the next steps if needed.
    Aug 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
    RUbber front load washer
    Yes unfortunately that rubber gets molded or gets cut . For mold you can try wiping it down with bleach with a rag. If you do it regularly it will slow down the mold. it's annoying but it helps
    Jan 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Change rubber gasket
    Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversable, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everthing. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. We used strong vice grips and much struggling and sweat, and #@*&%!&@ and finally got it on without damage to the new gasket. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
    Sep 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    133 people viewed this question
    Top Washing Machines Experts
