Question about Kicker ZX400.1 Car Audio Amplifier
Kicker amp as i was driving the other day i noticed that my amp is not pushing my subs like they were last week. i checked and i didnt blow a speaker or anything. i checked the fader, balance, etc and its all the same. any ideas what couldve happened?
  • 709 Answers
Hi Itoms76,
Try another speaker for good measure.Any possiblilty your bass gain is set too low on the amp, or the Switch is set to HPF. It needs to be on LPF.
Posted on Oct 14, 2007
SOURCE:
Kicker 12L5 blew from a kicker zx750.1
MY BEST GUESS FROM WHAT YOU HAVE SAID IS THAT THE BOX WAS TO SMALL. BUT YOU ARE OVERPOWERING THE SUB RUNNING IT AT 2 OHMS ON A 750 WATT AMP WITH A SUB THAT IS ONLY RATED FOR 600. NO MATTER HOW FAR YOU TURN YOUR SETTINGS DOWN, YOUR STILL PUSHING TO MUCH POWER FOR THE SUB TO HANDLE. IT IS ONLY RATED 600 WATTS FOR A REASON. ESPECIALLY IF YOU LISTEN TO MUSIC THAT HAS A REAL LOW END AND THEN A HARD HIT. REMEMBER A HARD HIT WILL SPIKE YOUR AMPS OUTPUT THEREFORE PUSHING MORE WATTAGE TO THE SUB.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_ec38c09da1ae48dd
Nov 19, 2013 | Kicker Car Audio & Video
I just bought a cvr kicker 10' sub, hooked it up in my car replaceing a polk audio sub. The kicker keeps blowing my fuse. i have checked the wireing. i have an 800watt sony xplode amp. Please help
i am assuming that you bought this sub used? their could be a problem with your voice coil. the voice coil moves the cone of the speaker in and out. the problem with the voice coil is that it has become lose and is doping the impedance of the sub. A lose voice coil can be cause by over powering the sub. this problem is not fix able.
Aug 01, 2011 | Kicker 01C8VR4 Car Subwoofer
Busted Kicker Subs
hi not worth fixing as labor is to high.
look around on ebay make sure you replace them with a name brand some companies like JBL sell refurbished subs with full warranties for cheap.
Remember with subs you must have a crossover either electronic or just a component in the cabinet so that the speaker is only reproducing the correct frequencies.
Lastly 12" subs require a ton of clean power 200 watts per ch minimum..and if possible they should be either 1 channel amps or bridged to 1 channel meaning for a pair of 12's you would have 2 amps
Contrary to popular belief most subs are damaged because people overdrive their amps and that blows the voice coil
hope that helps
Jan 24, 2010 | Car Audio & Video
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
How to order
The L7 I have is brand new in the box (not a speaker box just the retail packaging box) and the rms is 750 watts RMS and 1500 watts peak, but you are correct they blow easy when you push rated power to them, the hifonics subs will take 1200 watts rms all day long and over 3500 peak for burping at competitions, i run mine at 2000 watts everyday in a daily driver. if you hook 1 dual 4 ohm sub to a zx1000.1 it will be 2 ohm load on the amp so you will get 1000 watts to the sub so if you want to run it slightly underpowered to keep it from blowing use the 750.1 per sub, i can do those at about 250 each shipped
the price is 150 plus 10$ flat rate USPS shipping and yes I accept paypal Wyattconnolly@msn.com .
the warranty starts the day you buy it for 12 months but kicker will not cover burned or blown voice coils, that is why i recommended the hifonics (which is what i use to compete with now) because they put out better quality sound and alot more of it and they will take alot of abuse, if you want boxed speakers ready to go in kicker brand ported boxes I can have them drop shipped right to your door as well, the only reason i am selling the 1 L7 i have so cheap is because a customer ordered it then never paid for it so I am selling it at cost. be careful if you are buying on ebay as you have no warranty at all and you cant force the seller to give you 1 even if they say it has 1. because authorized dealers are not allowed to do internet sales at all so kicker and most other companies will not honor the warranties.
also you dont need 2 amps you can use 1 bigger amp and still run 2 subs just by changing how you wire the subs at the amp. 1 large amp costs less than 2 smaller 1's usually just not with kicker brand
Sep 15, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
SOLO BARIC L7 15 SUB
no as the the voice coil has been burnt out there is no way u can repair them. didnt you test the subs out before you bought them? remember if u buy used den allways check em out!
Jul 12, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Stopped working.. Blown? or..
how did u wire the speaker ?what is the speaker rated at 2 ohm or 4ohm? thees kicker l7s 15 inch is rated for 1000 rms and 2000 peak the only thing that could of hapend was somthing was touching some were in the wiring or u hade the speaker wired at a load of 1 ohm
May 18, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Intermittent Subwoofer
the wire from the coil to post is probably severed.you might have to take the dust cap off..
http://www.mwaspeakerparts.com/
this is a speaker part site
Jan 13, 2008 | Kicker CVR12 Car Subwoofer
Kicker solo l7 12" 2004 model
common problem of this subs are in the litles cables that goes to the voice coil. few times brock....check those. another .....if you heard the music too hihg with many bass..and your amp ..i think is big block... may be you blow off!!!!!!!!! the voice coil and the little wires...im calling trencillas...are the aquiles talon of this L7 and a manny others kickers. check the ¨TRENCILLAS¨ FIRST.
Feb 16, 2007 | Kicker Solo-Baric L7 04S12L74 Car...
Open Questions:
See all Kicker ZX400.1 Car Audio Amplifier Questions
Car Audio & Video Logo
61 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
