Question about Siemens Refrigerators
Fridge part has dropped temperature, doesnt appear to be cooling. Temp reading - no number. In Chinese, don't know how to reset it ???? Hope you can help before my food goes off - Freezer is working as normal.
I took a lot of non essential items out and that seemed to fix it, either there was not enough circulating air ie something was jamming a sensor I cant find...any way fixed it thanks
Posted on May 13, 2009
I have Samsung fridge model RS267LBSH. The freezer works but why won't the frig side cool?
If the door temp is reading low then it will not cool as that is the temperature the fridge thinks it is at (regardless of the real temperature). Try setting the door temp lower and see if there is still a 14 degree difference between the 2 readings. If it does cool down further and the difference is the same then I would suspect the thermostat.
Aug 16, 2015 | Samsung Refrigerators
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
Why did my frigidaire refrigerator digital temp display numbers just disappear after I tried to adjust them up? I tried resetting by pressing the on/off button to the left of the adjustment arrows-the...
Good Afternoon Friend,
I understand that the digital display, on your Frigidaire refrigerator, went out after trying to adjust the temperature. Without seeing the display, you will not be able to tell what the temperatures are set at, as well as if there is any trouble with the temperatures being hi, should that occur. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, if the display is still not showing, I recommend contacting your local authorized technician. The technician will be able to diagnose your refrigerator and determine why the display has gone out. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire Refrigerators
How to change the temp in a frigidaire galaxy refrigerator
Units will vary give or take a few degrees from the control panel display. Keep in mind once you change the temperature it will take up to 10-12 hours to stabilize and reach that temperature. If the unit is not cool, even at the bottom of the refrigeration portion (where the coolest air will be found) then contact a professional to diagnose the control pane and board.
Dec 29, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Car runs great until it get about 180 degrees andthen shuts off let it cool off a lil bit its starts back up until it shuts off again why
I am thinking that perhaps the temperature sensor is reading wrong and therefore sending a message to the computer that the car is running too hot. This can happen, my VW presently reads 20 hotter on the guage than a heat gun records at the temp sensor location on the head. If you have access to a heat gun it might be a good idea to check out the actual temperature, but it probably won't hurt to change the sensor.
The other problem that occurs to me is the oil sending sensor. While a temperature sensor won't shut an engine down, the oil sender can. If it is reading a large drop in oil pressure it will shut the engine off. Since oil gets thinner as it gets hot, perhaps a defective sending unit is reading it as too low. Once the oil cools off, it would restart until the temperature gets too high again. I would think that upgrading to a heavier oil might cure the problem. I don't know what you are currently usung but certainly you could go to 10W30 or 10W40 without too much trouble, at least for a test. Hope this helps.
Nov 17, 2011 | 2000 Chevrolet Cavalier
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
When we open the freezer door, a lot of steam/smoke comes out. A lesser amount comes out when the fridge door is opened.
If the fridge is working and keeping things cold and frozen, you don't have a refridgerant leak that is producing vapor that might appear as steam or smoke.
The steam/smoke is actually water vapor being made visable due to the temperature difference between the freezer/fridge temperatures and the air temp in the room (or garage) the appliance is in.
It's nothing to worry about and is normally more likely to happen when the outside or house air temp is very warm (Summer months) and when the air is humid.
What's happening is the very cold and cool air is hitting and mixing with the much warmer and much more dense air (humid air contains microscopic water particles) when you open the doors, and is instantly being cooled. Thus it appears as thou the fridge is steaming or smoking.
Have a great day an hope this explains the situation. Best regards.
Jul 30, 2009 | GE Refrigerators
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Cannot get the fridge to start cooling
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Did you think this was helpful? Yes No
Feb 08, 2009 | General Electric GFSS6KKXSS Stainless...
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Refrigerators Logo
251 people viewed this question
Top Siemens Refrigerators Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
John Tripp
John Tripp
 Mikey
Mikey
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
