Question about Karcher DE4002 Steam Vacuum
My karcher indoor steam cleaner won't heat up properly or emit steam. I mught need to descale it,can I ue ordinary vinegar instead of buying the karcher descaler, or is there something else readily available that I can use?
    Problem Solver:
  • 12 Answers
Have you tried fizzy cola?
Posted on Jun 18, 2009
The heating element within the steam cleaner gets hot but does not emit any ateam
Hi norma, make sure all the tanks are full water and soap and operating properly. Refer to the manual, Greg.
Dec 20, 2014 | Vacuums
My shark stem mop will heat up, but it won't emit any steam
Did you use a pipe cleaner in the jets, (be careful if steam is hot)
keep doing until it emits steam. Good Luck
Sep 23, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How to get steam out Clogged h20 mop
Put vinegar in it and let it sit for several hours. Then turn it on to heat the vinegar. It should start to sputter and you may see some material ejected. This is good. Now dump out the vinegar and fill with water, make steam and let it push out any more material that caused the clog. You may have to do this several times in order to get the vinegar smell out.
Jun 28, 2014 | H2o TR220002 Steam Cleaner
I have a SIMAC steam iron that isn't performing well at the moment. I think it needs descaling as it is making a large whistling sound when I turn it on and it has heated up. Can someone tell me what...
To clean the reservoir of your iron, pour a solution that is one part vinegar to one part water in. Turn the iron on. Allow it to steam for about four minutes. Drain the iron for an hour, and be sure to repeat the process with clean water before you iron any clothing items.
Jun 20, 2011 | Vacuums
Is there a reset button on the karcher de 4002
open the lid and you will fine a red button with a clear rubber cover
press that button. When you have to reset, it is telling you that you need to descale the unit
Jun 15, 2011 | Karcher DE4002 Steam Vacuum
Regardless of setting, I have not been able to get any more than 1/4 to 1/3 of a cup of coffee. The water barely comes out and now the descale message is on the screen. I need instructions for...
Although this is in "Problem with Vacuums," I found it while searching for a solution to my steam cleaner vacuum problem. You must be talking about a Keurig or Breville-Keurig coffee maker. Tap water, especially chemically softened tap water, contains minerals that require periodic descaling, as often as every two months if you make only a couple of cups a day.
Filling the tank with white vinegar and making multiple large mugs without a Keurig coffee cup in the holder will remove most scale. There are products that claim to do better than white vinegar if this does not work. Amazon sells a couple of brands in its Keurig section.
It will take several tank fulls of clean water to rid the machine of the vinegar or commercial cleaning solution. Use distilled water for this. Then switch to good bottled water without a heavy mineral load.
Jun 13, 2011 | Vacuums
How do i descale a SWAN iron model no S15030N. CAN I PUT DESCALER INTO WATER STORAGE TANK
The best and cheapest way to descale irons,steamers, etc. is to use white vinegar, mixed 1 cup to a quart of water. Pour in the iron and allow to steam. The vinegar will dissolve the calcium, which is the blocking scale. Do this a few times toensure that the holes are clear and operating correctly. For the last rinse, put a little lemon into plain water and allow to steam. This gets rid of any vinegar smell.
Jun 09, 2011 | Vacuums
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
May 05, 2010 | Karcher DE4002 Steam Vacuum
Shark steam blaster jr. makes steam but has no pressure
yes no vinegar please. Try a product called scale clean or tablets for de-scaling coffee machines. Available from coffee machine retailers
Sep 19, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Mar 25, 2008 | Karcher DE4002 Steam Vacuum
Karcher DE4002 Steam Vacuum Logo
1,198 people viewed this question
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
