Question about MSI KM4M-L Motherboard
Long pep after trying to reinstall a new broad
Put in a new MB after the first one,, a power spike and damaged MB and power supply. started up then had lines on the montor so I reset and had long peps after,,I didnt go in to set up first guess i should have. Since was the same MB though it would boot up,,Email is MSI MS 6734   VER :1
  • 2,351 Answers
Remove & reseat your memory.
Posted on Jan 15, 2008
Hp dx5150 mt shut itself down won't start
most likely power supply, those power supplies are horrible and the slightest power surge cooks them. a majority of them I get in for repair are p/s issues, a few for mobo issues.
Mar 08, 2014 | HP dx5150 Small Form Factor PC Desktop
Intel D946GZIS machine will not start after being reassembled. The green light on the Motherboard is on but after hitting the power button nothing happens
It is more than likely the power supply that is faulty. Newer PSU's have a 5volt supply missing, this means that some older boards will not run with the new PSU's. Try and find an exact match for your older supply but with a better power rating, if that is what is required.
Jun 24, 2012 | Intel D946GZIS Motherboard
A power spike broke Dell Precision M20 motherboard
Hi there!
Yes it really does damage the motherboard when that kind of things happen.
You'd rather replace the motherboard than repairing it.
Hope this helps!
Feb 13, 2010 | Dell Precision M20 Notebook
Replaced dead power supply computer still dead
most power supplys are protected against faults when they are connected to damaged equipment
so it possibly just protecting its self
disconnect everything from the PSU except your MB
try to turn on
if your pc boots ok
re connect everythng else one thing at a time attempting to boot each time
when it wont boot you have found your fault
Feb 07, 2009 | E-Machines D2046 PC Desktop
Emachines W2888 will Not Start up
Most likely the system board has failed. If the power supply had blown it is not unusual for the subsequent spike to blow the system board. On the other hand it may have been the system board that failed and the PSU is ok. Emachine system boards are rubbish
Either way you will need a new board and most likely a reinstall of the OS
Dec 09, 2008 | E-Machines eMachines Desktop PC
Computer is not working, changed power supply and is sti dead
Try to unplug the power cable from the system for 2 minutes and then turn the PC on.
If that does not work, then look for the battery of the motherboard, it would be like a coin. Use clippers and remove it for 2 minutes and put it back in and power the system.
If that does not work then try and remove the one RAM at a time and restart your system.
If all the above steps does not work, then you would have to replace your MB.
Aug 22, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Power problem
your power supply is possibly dead unplug it and smell the vents if you get a strange smell it has poped a capacitor or 2 try another psu from another pc loose before you buy a new one many a time a voltage spike may have done more damage depending where it got to
Jun 06, 2008 | HP Compaq Presario Media Center SR1750NX...
CMOS Battery?
I am going to go out on a limb here and infer that when you try to power up the machine you get nothing - no lights, no display no beep. If this is the case then this would be symptomatic of a failed power supply, however the problem may not start or end there it is also sympomatic of a failed MB.
A good power supply will sacrafice itself to protect reliant components if there is a power spike, a "budget" one will pass the damage on.
In answere to your first question about the CMOS battery you are correct.
Basicaly buy a new power supply and don't buy budget but having done that don't be suprized if the MB has gone as well. Worse news is if you do have to change the MB depending on the age of your system you may have replace the CPU as well.
Sorry about the bad news, all I can offer on the positive side is that electrical equipment is usualy covered under a home and contents insurance package or a lease/rental agreement.
Hope this helps.
May 01, 2008 | Matsonic MS8137C Motherboard
My Computer does not work at all.
more than sure if you have replaced the power supply already and the computer still not working,there must be a electrical damage to the board.
it is sure that.but you have to check some other components too seeing that they are stuck in the board,like the procesor and ramm dims or the video card..the electrical charge may have affect them too.
but 1st thing to do is to change the mainboard..
oh by the way...just to be sure..try to make a bios reset..maybe it will work and pull out the ramms from the computer..put them back after...ussualy this works...
good luck and let me know about
Feb 03, 2008 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Power supply
Usually this will damage the power supply only. To make sure your that your motherboard is working, try to find a working power supply unit and connect it. If it does not work your motherboard may be get damaged. Also check for warranty. If your system contains a graphics card, check that too, it may also get damaged with voltage variations.
Oct 02, 2007 | ASUS P5LD2 Motherboard
MSI KM4M-L Motherboard Logo
67 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
