Hello, I put a DVD with a lot of JPG.files on it in my Magnavox MRV810h. After that the machine started READING and never stopped. In no way I can get the DVD out of the player/recorder. The program crashes and will not react to any input any more. Is there a solution for this? Is it possible to open the DVD-player to get the DVD out? Thanks for any help. Huub Esten from the Netherlands.
  • waalnetschep May 12, 2009
    Thank you for your advise. I already did this a couple of times. I think it has something to do with the software. After restarting I can watch recorded movies. When I try to program something from TV everything works fine until I have to close the recorder down. It will not close down but crashes. I have tried several ways to open the DVD-drive, but no success. I even opened the recorder, but the DVD-drive is of the enclosed type. The solution would be to remove the DVD, but I do not know how. There is no alternative route to address the eject function.
  • waalnetschep May 13, 2009
    Well, for an expert you gave me a lot to work with. For these tips I could have asked the guy who delivers the morning paper. Little disappointed.
    If this was your best shot, you will never see me on FixYa again.
    All the best from Holland.
  • 10,594 Answers
Unplug dvd player form AC outlet for couple of minutes, replug back in and press Eject / Open button to take out DVD, now power up the unit and let it prepare to load another disc.
Hit "add a comment" button for further query / info.
Thanks.
Posted on May 12, 2009
  • Shahid Electronics
    Shahid Electronics May 12, 2009
    the eject function.
    OK, seem its software (firmware) issue then best option is to contact nearest service center that can handle the unit in better way.
    Thanks.
"Bad Disc" message when reading a disc with JPEG files
Hi
Similar Issue happen to one of my client what we have done is putting the JPEG files into folders (Not Subfolder). It worked well however some JPEG images being skipped if the size is unusual. JPEG images will appear as tracks. Hope this will be helpful. If issue persist please post once more. Also let me know if WMA files are being played.
Good Luck
Jan 24, 2008 | Onkyo DV-CP704 DVD Player
Panasonic cn hds625d dvd sound problem
Try using google translate on the Japanese manual.
Apr 04, 2014 | Panasonic Audio Players & Recorders
Recorded pictures onto a DVD on my computer, they won't play on the ZV420mw8
I looked up your DVD player's model number online. It is not equiped to read picture files (.jpg, .bmp, etc.) You have to be carefull when you transfer pictures to a DVD on your computer. If you just burn them to the disc, most DVD players wont be able to read the information. Frequently you have to use a program like Microsoft Movie Maker to get them in the right format.
You may have to start over and use a DVD making program to make them a video and not just picture files.
Hope this helps! Don't forget to rate!
Jun 26, 2012 | Magnavox ZV420MW8 DVD/VCR
I have a 4 yr old magnavox dvd/vhs player and the dvd just started making a clicking noise while it was reading the dvd, played the dvd and then just completely shut off.... Help?
Laser will click loudly when diode is burnt out. Invest in a new machine. Cost of repair would prob be more than new machine. Good Luck.
Nov 20, 2009 | Philips Magnavox DVD/VCR Dual Player
How to make my dvd recorder regio-free
Power on
Switch to DVD mode
Open tray
Press 0 0 8 6 0 0 0 on remote
Press OK
Power off the unit using remote (Very Important)
Power on (It should now be region free)
Mar 26, 2009 | Televison & Video
I am trying to record from my dvr to my magnavox 10d6 recorder
Connect the yellow/red/white out from the VCR to the same inputs on the 2160. Press setup. select general. select video select video input. select L1 or L2. press ok. select video or s-video.
press setup to exit.
select HDD or DVD (whichever you want to record to)
use source or channel to select L1 or L2
press rec mode to select sp/lp/ep/etc
press record to start recording
start playback on the input device
press stop to stop recording.
The manual is available as a PDF file on the web. It would save a lot of typing...
tom
Jan 20, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Philips DVD750VR will not load DVD or cleaner CD
When my dvd player starts doing this it usually means that it is going bad and you may need to replace the dvd.
Jan 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox 60
It's probably the magnets on the neck of each CRT that moved since you removed them or the CRTs weren't put back in the exact orientation . Use a white paint pen to mark each one as they are now. If there's a clamp or two metal rings that locks them in place you can try rotating them as a group (their location up and down the neck is also critical).  If not you will have to adjust them individually and then do a complete convergence adjustment. That's a big task. Good luck.
Sep 28, 2008 | Philips Magnavox 51MP392H Rear Projection...
Playback
saving .jpg/.JPEG/ .BMP file to a dvd disc don't wrie properly. try using a CD-R disc and save pctures as .jpg.
Jul 30, 2008 | Televison & Video
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
