Question about Zyxel ZYAIR G-1000 802.11g/b (91-005-026002)
No connection do i need some drivers to connect my router?
  • 355 Answers
You can download here
http://www.zyxel.com/web/support_download.php
Posted on May 12, 2009
How do i connect my net book to use my wireless router
How do you connect your wireless router to your netbook..?
you must have an internet connection with your service provider or isp(internet service provider),...
connect it with your wireless router modem, or modem to wireless router to your wifi laptop,.
make sure power of your modem and wireless router is on there was an ac power cord it needs to be plug...
next in to your laptop install the wifi driver,... to know that it is intalled go to my computer(windows xp/?)right click then properties go to harware tab then device driver look for yellow ? and intall driver if necessary that your wireless connection driver is not install...
if done and install go to start menu then connect to --> show all connection--> wireless connection and done it will connect... sometimes theres a security u need to type wep key,, etc etc..
HOPE IT HELPS!!!
Jun 27, 2011 | Sylvania G-Netbook
My wii won't connect to my cisco e10000 and I already checked the security settings !!
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps i just read something on the setup of a cisco
Use the Cisco connect software for the initial set up of your new E series router. While running the software for the first time it will ask you to connect the modem to the router. But will not ask you to connect the computer to the router. However it will be better if you connect the computer to the router with an Ethernet cable. Otherwise it will not find the router and you will get the error "we did not find your router". Run the program and at the end it will connect you to the Internet. You don
Jun 26, 2011 | Computers & Internet
Have Linksys E2000, whenever i connect router, I loose all internet connections. I follow the disc, but the self diagnosis says I have no driver. I tried DriverWhiz, but it locks up computer. ...
Use the newer drivers http://homedownloads.cisco.com/downloads/utility/1224659225421/Downloadable.CiscoConnect.E2000.1.2.10260.0-ship-Stable.Hotspot.exe
If that doesn't work, then your ethernet drives may be corrupt. Go to: Start -> Right Click "My Computer" -> Properties -> Device manager. In Device Manager select: Network adapters -> Your ethernet chip name -> Right Click & select "Update Drivers". You need to select the drivers off of your cd if your computer doesn't have an internet connection.
Dec 30, 2010 | Cisco Linksys E2000 Advanced WirelessN...
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
Hello I have a netgear wireless router WGR614 V5 which is connected to a cable modem and since several weeks I have many unexpected and random disconnection. So I must turn off my wireless router and...
HELLO,
Why are you using two routers,these might be conflicting with each other? Somtimes the drivers need updating.Try this first,and if this fails,disconnect the cable modem and just connect the wireless router to the main phone line socket via a modem filter and connecting a wireless adapter to your pc and install the driver for this adapter.The signal from the phone socket connection to the wireless router situated close to the main phone socket.Then connect the adapter to the usb port on your PC,and let the driver software and PC do the rest.That's all I've got on my PC.
Aug 07, 2010 | NetGear WGR614 Wireless Router
My belkin wireless router router consistently disconnects all wireless devices from the internet only to reconnect moments later. Is their any way i can fix this? it's getting rather annoying
You need to up date the firm ware for your router. Go to belkin support site and download latest firmware and update your router and this will fix your issue
Jun 04, 2010 | Belkin (F5D8231-4) Wireless Router...
Lan driver problem
A D-Link Router is a "plug-and-use" device.
Just connect its 'WAN' port to your cable-modem (or DSL-modem) and connect one 'LAN' port to the network-port on your computer, and you'll be connected -- there is no need for a "LAN-driver" for the DVG-2001S Router.
Apr 16, 2010 | D-Link (DVG-2001S) Router (DVG2001S)
WRT300N not working after computer was reformatted. Hooked everything up the same way but no connection. It is not finding the router. Could I be missing drivers? If so which ones would I need?
are you trying to connect to the wireless network ? Or you are trying to set up the router ?
Anyways first you will need to check the settings of the router.
To check the settings of the router, you will need a computer connected to the network.
open the set up page of the router and check the settings.
You don't need any drivers for the router.
Click Here for more information about the router and network
Feb 22, 2010 | Linksys WRT300N Wireless Router
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Have Dell Inspiron 1501 had to reformat hard drive and reloaded all system programs and drivers but cannot connect to wireless router. Could connect before reformat and other laptop connects to router...
Dell has a nasty habit of making you go to their website to get some of the drivers. Check to make sure your wireless card's drivers are there (probably not). Right click My Computer>Properties>Hardware>Device Manager. I'm betting you'll find a yellow circle with a black exclamation point under your Network Adapters. If so, go to the Dell site for your drivers, download and install. It'll be recognized automatically. Let me know if this doesn't work. If it does, please rate me accordingly!
Jan 15, 2009 | Computers & Internet
Zyxel ZYAIR G-1000 802.11g/b (91-005-026002) Logo
306 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
