Question about Lakewood HV 18-c Floor / Box Fan
Lakewood HV-18 fan... how to wire switch?
This fan is from about 5-10 years ago. Took it apart to use the motor for something else and the wires popped out of the switch... it is a 4-position switch (off low med high) there are the 2 white wires leading to outlet plug) (not sure where to put them) and a green ground. the switch has four colored wires coming from motor into switch: black, blue, red, white.
The black and blue wires are in place in position - blk-1, blu-2, which leaves the red and white wires to put in position L or 3 but since I don't know wiring I'm not sure if these are supposed to go here (and which) or in the additional two slots (which for the moment I'm assuming are for the white cord/extension/outlet wires).
Sorry if this is confusing. Please help
  • blastfurnace Aug 06, 2008
    need a new switch for my hv18. where can i buy one?
  • mocte Sep 05, 2008
    same problem everything exact fan type model even the age of it , but i didnt open the hting up i just triped on it while it was pluged to the wall and the corrent wire are out of the switch this is the type of switch this fan have
    http://www.nelsonappliance.com/Lakewood+...
How to fix up a wire if it has burnt out of the soldering. Is it possible to fix it cheap on our own?
Posted on Jul 09, 2008
My switch unit also fell apart as I took the back off and I didn't get to see the correct position of the switch. After much trial and error, I found this to be the initial "Off" position (see photo)
Posted on Aug 18, 2012
  • Vito Sep 20, 2012
    did your fan have 6 wires? where does the Black & white wire showing on your pic from the motor or cord?
I got the same problem with the wires on this exact switch of the exact fan and aswell 5 to 10 years old heres the type of switch that this fan uses --> any idea? btw im checking the case where the velocitys are marked let me put u the order goes like the this
HIGH_ _ MEDIUM
OFF------ O ------ LOW
http://www.nelsonappliance.com/Lakewood+Switches+for+HV-18+Fan+%7C+HV-12+%7C+P25+Fan.html
Posted on Sep 05, 2008
  • 625 Answers
One wire from the line cord goes directly to the motor, the "hot" is switched.  The "L" indicates the hot cord wire, the rest are speeds.
Posted on Oct 14, 2007
  • Vito Sep 20, 2012
    can you explain further on your solution. i have the same problem. my fan has 6 wires. Black & white from cord Black, white, red, brown from motor. my new switch has slot L, 1,2,3
I am trying to replace a belt on a Beko Condenser tumble dryer DRCS68W. I cannot find any instructions or videos online , surely this is something i can do without having to pay someone else to do it.
not same model number .but on my beko....i had to remove side panel.........remove element cover remove motor fan inside fan opening is 4 small bolts,. remove them..... ,.they hold motor to back plate...on front of machine.remove front fan.....then from side panel..remove plastic motor covering and wire harnes...then the motor just pulls forwards remove back plate...and machine bearing...put new belt on.... manover motor back inti place then refit as you took apart..........
chers
Nov 30, 2016 | Dryers
Ceiling fan 3 way switch install
The black is the hot wire, the white is natural and the black/white wire is for the light option.
Jul 02, 2013 | Dryers
Marvin Model 1220. I have several of these fans and each one has issues with fan blades either not turning or slowing down and eventually stopping. I took one of the fans apart and found that the bearings...
I own a Marvin model 1220 box fan since 10 years ago. The stand broke on the hooks part. I need the buy the same, please help me on this. It is out of stock in the Internet. This fan is fantastic, but need to keep it clean so the blades don't slow down do to dust
Aug 12, 2011 | Marvin 1210 Floor / Box Fan
I have an E1060 drop in. The unit was purchased three years ago, but major delay in construction. Installed a couple months ago, all was fine. Have yet to cook on this grill. Two weeks ago, went to use,...
Dan, did you check the circuitry and relays to the motor, as was suggested on March 29th? If the motor can't get power it won't work. It seems, that this may be the problem, since you took the motor apart and there were no broken gears and all other electrical devices work. The other resolution was to contact R.H.Peterson Company, the manufacturer for more information, if all else failed.
Mar 31, 2011 | Fire Magic Echelon E1060s2E1P51 Stainless...
I have a 1995 tracker with an aftermartket a/c added several year ago. I started having a problem with the fan blower, it would only blow at the lowest speed. A/C and low speed still worked , just no...
Sometimes aftermarket systems will have an in line fuse. If that's not it, look around on the blower box, for some wires going to a connector that is held to the blower box with a couple of screws. It's the blower motor resistor. It could be that or the switch.
Aug 15, 2009 | Geo Tracker Cars & Trucks
Electrical
ok, what I meant was is it a live wire. Assuming it is and setting it aside, The other three must be leaving the switch. Hot in and three out for different speeds. The speeds are controlled downstrean on each wire either by resistors or motor design. The fan motor(s) are grounded at their mounting locations. So, touch the hot wire to each of the others one at a time to confirm. Then, turn the switch to low and insert the hot wire into a terminal until the one that that turns the fan on is found. Turn the switch off to confirm control and then turn switch to confirm control of the other two speeds. No need to worry about shorting anything, The ground would be your only fear and it's far remote. Good luck
Jun 25, 2009 | 2005 Chevrolet Venture
Lasko 3520 20-Inch Cyclone fan - disassemble fan for cleaning?
How do I clean my Cyclone or Air Companion™?
Lay the fan face up on a flat surface. The front grill should be facing you. Remove the screws from the rear grill. Place a flat-head screwdriver into the gap between the front and rear grills. Pull the front grill towards you, exposing the fan blade. Do not remove the knobs on either side. Then, wipe the blade with a soft, damp cloth. Use a mild detergent if necessary. Be sure not to touch the motor. Click here to download product instruction sheet.
Jun 08, 2009 | Dryers
Rewire air conditioner controls
Assuming "Window Unit" with rotary switch.
L1 (smooth part of line cord) to thermostat 1, thermostat 2 to overload (black disk) from overload to Common( C) terminal on compressor.
From Run (R) terminal on Compressor to Common (C) terminal on dual capacitor. From Start (S) terminal on Compressor to "Herm" terminal on capacitor. From fan motor to # 4 on switch = Medium Speed, to # 6 on switch = High Speed, from fan motor to # 7 on switch - Low Speed. Brown wire from fan motor to (F) on dual capacitor, white wire from fan to (C) on capacitor and L2 (ribbedwire) (N) to (C) on capacitor
May 10, 2009 | Heating & Cooling
'03 NB Turbo - Starting Problems
Sounds like the radiator fan might be staying on and not switching off causing the battery to drain when you're parked. Could be a defective fan switch or more complicated the wires going to or from the fan module or the fan module itself.
Nov 04, 2008 | 2003 Volkswagen New Beetle Convertible
Burner knob wont turn
appliance repair and yes you can fix it you likely need an infinite switch
Apr 17, 2008 | Cooktops
Lakewood HV 18-c Floor / Box Fan Logo
1,923 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
