Question about Dell XPS M1330 Notebook
When i put my av adapter into my laptop the light goes out i have tried other chargers and the same thing happens the battery is fully charged but the computer wont start up
  • rodgersbhoys May 12, 2009
    no even though battery has full charge
    no even though battery showing full power
    Problem Solver:
  • 5 Answers
Hi Does the laptop work powered by the battery?
Posted on May 12, 2009
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Screen has hp logo and says press the ESC key for startup menu, but is not responding
Try a hard reset. Disconnect the power adapter (charger). Remove the battery. Now press few times the power button. Yes, with no power the laptop will not start but the idea is to drain any residual power left inside your laptop. Put the battery back and try again.
Dec 15, 2013 | HP ProBook 4530s Notebook
My lenovo G550 appears not to charge when the charger is plugged in despite turning the mains power on and off to see if power is getting though and the blue neon light showing on the mains...
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Jun 18, 2011 | Lenovo G550 PC Notebook
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
I have a dell studio 14. When i plug my ac adapter in to charge my battery, it charges for 5 seconds and then goes to idle. I have a brand new battery and charger, so I doubt it is either of these...
You didn't say, but I assume that you think the battery is not fully charged. Maybe it is?
If the power adapter is putting out the required voltage ~18v. and the battery is new, and still it can't charge, I would suspect the motherboard.
Feb 18, 2011 | Dell Studio 14Z Notebook
How will be i identify it is fully charged battery i charged for 45 minites.But the battery will not be fully charged. please send me the solution for this problems
If using usb charger use usb port on back of desktop, not data port in front, also most laptops do not have fully powered usb ports due to battery consumption. The wall charger, or a usb charger plugged into a usb/ac adapter (like included with ipods and kindles or sold seperately) is your best bet for reliable charge.
Charging unit should have a light on it.
When charger is plugged into power source and not helicopter, the light will show you {#1} what it looks like when battery is fully charged. Typically this is steady on, and usually red. (sometimes green) When you connect helicopter to charger, the light will change (usually goes dark) to signify it is charging {#2}. When light comes on fully (or completely returns to #1) then charging is done. (Note: charging using a laptop usb or a front side data port usb can take several hours.) Watch the light on charging unit when you unplug helicopter, if it gets brighter, helicopter is not charged, plug it back in. Make sure to let battery cool for 10 minutes after every charge and 10 minutes after every flight, and never run battery all the way down. As soon as you can't maintain altitude, land and power off. Fully draining a Li/Po battery weakens it's ability to hold a charge and can ruin it.
If all else fails, replacement batteries are available from Amazon and many others, they are cheap (around 5$) and very easy to install with no soldering and just a small screwdriver.
Hope this helps
r
Dec 31, 2010 | SYMA Toys industrial Syma S032 Ready to...
When I plug in the adapter the blue light on the charger goes out immediately and does not charge the battery. I bought a new charger and it does the same thing. I've had both chargers checked and they are...
I got a brand new 170 battery for my studio 1737 . Now the battery has charged, but I plug it in and the window says battery plugged in, but not charging
May 14, 2010 | Dell Studio 1737 Laptop
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Battery not charging
You need a new battery. That battery goes dead maybe its a factory defect its very rare this to happen but try to contact the Company to ask if you have a warranty for this unit. One more thing make sure that your charger is functioning.
Aug 04, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Dell XPS M1330 Notebook Logo
152 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
