Bios setup key
What key do you press on startup
    Problem Solver:
  • 8 Answers
Hi
there are some keys and some comes with key combinations.
Delete, F1, F2, F10, F9, F12, Ctrl+Esc, Ctrl+F1
Posted on Dec 09, 2013
4 Suggested Answers
shynysaxena
  • 166 Answers
SOURCE: laptop bios
Its power supply have serious problems and plz consult any nice electrician for its power check-up otherwise it will harm ***********-board or RAM which are really costly affair to be played with.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 30, 2009
sijudoniston
  • 134 Answers
SOURCE: IBM ThinkPad R50 restore factory settings
You might have deleted the Hidden partition within the drive .So you will not get the restore factory setting option
Posted on Aug 27, 2009
  • 3278 Answers
SOURCE: Instructions say to use the Acess IBM button when
Hello, Salvador.
For most IBM system, select F11 at bootup to start the Product Recovery program.
Hope this helps.
Posted on Jul 18, 2010
My satellite Toshiba L875D-s7230 says bootmgr is missing press ctrl alt and delete to restart and does nothing
Which operating you are using?
Method 1: Run Startup Repair from Windows Recovery Environment (WinRE) To run Startup Repair from the Windows Recovery Environment (WinRE), follow these steps:
  1. Insert the Windows installation disc into the disc drive, and then start the computer.
  2. Press a key when the messagePress any key to boot from CD or DVDappears.
    If your PC does not detect the media automatically
    1. During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
    2. Look for a tab in the BIOS Setup Utility that is labeledBoot Order,Boot Options, orBoot. Following the directions on the screen, use the arrow keys to go to theBoot Order, then press Enter.
    3. Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYes in the confirmation window. The PC will restart.
  3. Select a language, a time and a currency, a keyboard or input method, and then clickNext.
  4. ClickRepair your computer.
  5. In theSystem Recovery Optionsdialog box, select the drive of your Windows installation, and then clickNext.
  6. At theSystem Recovery Optionsdialog box, clickRepair your computer.
  7. Click the operating system that you want to repair, and then clickNext.
  8. In theSystem Recovery Optionsdialog box, clickStartup Repair.
Method 2: Rebuild the boot configuration data (BCD) from Windows Recovery Environment (WinRE)
  1. Put the Windows installation disc in the disc drive, and then start the computer.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYesin the confirmation window. The PC will restart. Allow the PC to restart normally. The scan will take a few minutes and remove any malware that may be infecting your computer.
  3. Select a language, a time, a currency, a keyboard or another input method, and then clickNext.
  5. Click the operating system that you want to repair, and then clickNext.
  6. In theSystem Recovery Optionsdialog box, clickCommand Prompt.
  7. TypeBootrec /RebuildBcd, and then pressENTER.
Jan 20, 2017 | Toshiba Computers & Internet
Hp8470 how to enter in bios
You asked this in the Mac Laptops area.
However,
To access the BIOS Setup, turn on the computer and repeatedly press the esc key to enter the Startup Menu, and then press the F10 key to enter the BIOS setup utility.
Figure 1: Example - BIOS Setup Utility
c02258786.gifThe BIOS Setup window consists of options for Security, System Configuration, and Diagnostics.
All the best to you,
Kerry
May 27, 2014 | Computers & Internet
I cant reformat my ibm pentium 4 where can i find the advance bios i press all the functions but icant see the advance bios
Try the below steps and I hope it'll work for you.
1) Shut down the operating system and turn off your computer.
2) Press and hold down the F1 key, and then turn on the computer.
3) When an IBM or other logo is displayed or if you hear repeating beeps, release the F1 key. The IBM BIOS Setup Utility will start.
4) Select "Start Options" from the first menu.
5) From the Start Options menu, press <Enter> on the top bullet labeled "Startup Sequence" (it is above all the other options). This brings up a new "Startup Sequence" menu.
6) Change boot order as needed using arrow keys.
Jul 24, 2012 | IBM Netvista Intel Pentium 4 2.4GHz /...
WHAT IS BIOS
BIOS is Basic Input Output System. On startup, before the windows screen comes on, you need to press one of the F# keys to enter the BIOS/setup screen. On my PC I have to press F2 to enter the BIOS/setup screen. The delete key can also take you to this screen on some PC's.
Mar 17, 2012 | Advent Computers & Internet
Reset bios laptop ibm thinkpad 2647
Turn the computer off.
Turn the computer on, and immediately look for a message on the screen, e.g.,
press <blah> to enter BIOS SETUP
or
press Enter to interrupt normal startup
Press the specified key. Then, choose to enter BIOS SETUP.
Use the arrow-keys on the keyboard to navigate to 'LOAD BIOS DEFAULTS'.
To reload those settings, just press the Enter key.
Feb 12, 2011 | IBM ThinkPad T20 2647 Notebook
Which key to press at startup to gain access to BIOS E2180 Intel
There are a number of keys used to access the system BIOS at startup. F2 is probably the most common, but I see you've already tried that. I've also seen the ESC and DEL keys used, so try those. If that doesn't work, start working your way across the F1-F12 keys.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 13, 2009 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Which one key to press to togin to bios setup??
If this is an IBM Netvista you start the Bios by pressing the F1 key while the computer is starting up, press it many times as soom as you hear the computer startup beep.
Nov 19, 2008 | IBM NetVista Socket 370 Barebone Kit /...
Setup
I think in all bios at boot start up you press delete
Oct 07, 2008 | Computers & Internet
Reformatting my computer
  • Using System Recovery CDs
  • Change the boot order in the BIOS:-
  • Turn off the computer:
  • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
  • Turn on the computer.
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
  • Wait until the BIOS setup program opens.
  • Press the right arrow key to select Boot.
  • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
  • Change the first boot device to CD-ROM using one of these methods:
  • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
  • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
  • Start the recovery:-
  • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
  • Press the F10 key to save the changes and exit BIOS.
  • With Yes selected, press Enter.
  • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
  • Press R, and then press the F key again.
  • Click yes to perform the full system recovery.
  • Insert the remaining CDs when directed.
  • When the recovery program finishes, click Restart to restart the computer.
  • Before the computer restarts, the CD tray ejects. Remove the CD
  • Return the BIOS to the previous setting
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
  • Press F5 Key to Set Default Settings in BIOS.
  • Select yes and press Enter.
  • Complete the recovery
  • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
  • Complete the registration process, and then reconnect the devices that were disconnected earlier.
  • Reinstall software that did not originally come with the computer.
  • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
Jul 04, 2008 | Computers & Internet
How to goto cmos setup.
Press the ESC key during startup. You should then see a message telling you to press F1. Do so. This will load the Bios settings screens.
Mar 28, 2008 | Toshiba Portege 4010 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
