Question about Microsoft Office Professional Edition 2003 (26907408)
Excel vba i want to create a vba excel form by which i can findout a selected data from excel sheet and can input data next cell
  • 413 Answers
For complete guide please refer to this link
http://www.fontstuff.com/VBA/vbatut03.htm
Thanks and regards
Fixya is educating to educate
Posted on May 12, 2009
Excel cell replacement
To have the contents of the cell change from something you input into something else, you would need to put in a macro using VBA. You'll need someone who knows VBA to help with that.
OR... It is a lot easier to get similar results, if you are ok with using a few more cells to do it. The item# will remain where it was entered, and the product name will have to go in a different cell. In that case, you can use a lookup formula.
To do this, lets say your item# is entered in cell 'Sheet1'!C1, and you want the product_name to display in cell 'Sheet1'!D1. On another sheet (lets say sheet2) In cells 'Sheet2'!A1:B5 input the item#'s in the first column (column A1:A5) and input the matching product-names in column B1:B5. This is your lookup data. This sheet can be hidden if you want In cell 'Sheet1'!D1, use a vlookup formula that will look at the item# and find a match in the list, and display the product name for you. =vlookup('Sheet1'!C1,'Sheet2'!$A$1:$B$5,2,false)
This will display N/A# if the number can't be found.
Feb 15, 2013 | Microsoft Excel for PC
Excel Tool VBA Password Recovery
Are you looking to unlock a protected sheet or actually recover the password? I can help you with the former.
Note this will only work to unlock a worksheet. It will not recover the VBA editor password (however this is possible by very hard to explain.)
1) Open the excel sheet you want to unlock,
2) Open VBA editor, (Alt+F11 while in excel)
3) add a module (insert > module)
4) and paste in this code into the main window (big window on the right)
Sub PasswordBreaker()
Dim i As Integer, j As Integer, k As Integer
Dim l As Integer, m As Integer, n As Integer
Dim i1 As Integer, i2 As Integer, i3 As Integer
Dim i4 As Integer, i5 As Integer, i6 As Integer
On Error Resume Next
For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
ActiveSheet.Unprotect Chr(i) & Chr(j) & Chr(k) & _
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
If ActiveSheet.ProtectContents = False Then
MsgBox "One usable password is " & Chr(i) & Chr(j) & _
Chr(k) & Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
ActiveWorkbook.Sheets(1).Select
Range("a1").FormulaR1C1 = Chr(i) & Chr(j) & _
Exit Sub
End If
Next: Next: Next: Next: Next: Next
End Sub
5) Then either:
5a) go back to the excel window, click Developer > Macros > select PasswordBreaker
6) Or just hit the play icon (green triangle) in the top of the VBA editor
This will unlock the sheet, and give you a password which will unlock it in the future.
Note: Due to the encryption method used in excel, there are many possible passwords which will unlock the sheet. This will give you "a" password which will work but it will not be the one that you originally set up. Both the original and this one will still work.
Jan 20, 2013 | Excel-Tool Excel Tool VBA Password...
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
How to create macro button in microsoft excel 2007 because
well follow the steps below to get your job done:
To create an option button in Microsoft Office Excel 2007, make sure that you add Option Button (form control) to the Quick Access Toolbar. To do this, follow these steps:
  1. Click the Microsoft Office Button, and then click Excel Options.
  2. Click the Customize category, select All Commands in the Choose commands from list, select Option Button (form control), and then click OK.
To create an option button and to assign a macro to it, follow these steps:
  1. In Excel 2003 and in earlier versions of Excel, click Option Button on the Forms toolbar, and then draw the outline of the button on the sheet.
    In Excel 2007, click Option Button (form control) on the Quick Access Toolbar, and then draw the outline of the button on the sheet.
  2. Select any cell in the worksheet.
  3. In versions of Excel that are for Microsoft Windows, right-click the option button, and then click Assign Macro.
    In versions of Excel that are for Macintosh, press COMMAND while you click or press CTRL while you click, depending on your operating system version. Then, click Assign Macro.
  4. In the Assign Macro dialog box, click the name of the macro that you want to assign to the option button, and then click OK.
When you click the option button, the macro will run.
good luck ...:-)
Apr 08, 2010 | Microsoft Office Excel 2007
In Excel trying to compare two ranges
I imagine that the only way is with VBA coding. This is possible if you know programming in Excel (VBA - Visual Basic for Applications).
Apr 17, 2009 | Oracle Database Enterprise Named User Plus
Validation using Excel VBA code
Thats a lot of form work to be expecting out of Excel. You might be better off using Access, creating a table. If you need to export it back to a spreadsheet you can. The validation controls are better in Access and don't have a lot of limitations to them.
Good luck on that
Jul 21, 2008 | Microsoft Office Professional 2007 Full...
Macro
Hi alwinkumar
You can set a default value in most form items under the properties of that item. Look for "value". You can also do this in code, by setting up a sub routine to set/reset the values on your form. Then just run the sub routine before you open or enter the form.
Private Sub resetForm()
'formname.itemname = value
UserForm1.Label1 = "Hello World"
End Sub
For the second one you have a couple of options, you can find the bottom on the data and store the row index in a variable, use a loop to find the next empty cell in a row, and store the value or you can use the current region method to select all the cells with data continously touching the selected range. Example below
numberOfRows = Sheet1.Range("A1").CurrentRegion.Rows.Count
Jul 16, 2008 | Microsoft Office Professional 2007 Full...
Pls hepl me wit Excel VB integration
you can use a OLE object that is available in VB as standard object. Drag the tools to your form that your creating and it will ask for create or link existing object. so now browse to the excel sheet and embed it into the VB form or use run time for manuplating the cells and other info in excel.
Mar 25, 2008 | Computers & Internet
One problem in the application of excel sheet
I can make out that
You are speaking about creating a macro to take data from one constant updated cell and to put that data into another cell or form sheet.
You will need to get precise help from a programmer on this.
If you want to see a little on macros just open a sheet and checkout the help section on macros.
Some macros can take many hours to write and test.Some make take months.
hope this helps.
Jan 30, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
178 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
