Question about Intertherm P3RA-060K Air Conditioner
Condensation tube not flowing and unit not cooling
  • 148 Answers
Compressor may not be running or low on freon
Posted on May 12, 2009
A copper thin tube from the unit is very hot. Is it normal?
Yes, well somewhat normal. The refrigerant leaves the compressor at high temperature and flows through the condenser coil where it cools about 20 degrees warmer than the outside air flowing through the condenser. Many small air conditioner units use a small copper tube (capillary tube) of a specific diameter and length for that system to cause a decrease in refrigerant pressure between the condenser and the evaporator. The refrigerant leaves the compressor as a gas at high pressure, cools in the condenser and changes into a liquid. The liquid flows through the cap tube and cools more as the pressure decreases and gets closer to the evaporator. The refrigerant boils and evaporates under the low pressure of the evaporator and turns back into a gas. That gas is pulled back to the compressor.
If the condenser is not cooling the refrigerant enough, the tube can become extra hot. Efficiency is reduced. Actual temperatures throughout the system depend on the type refrigerant used, suction and discharge pressure at the compressor, outside and inside temperature. Tables, charts and graphs for various pressure-temperature relationships can be found in refrigeration books and chemical web sites.
Mar 17, 2015 | Carrier FB4ANF060 HVAC Electric Unit & AC...
Quasar cool look hq2061fh
Hello, some window units do not use a drain tube instead they use the condenser fan blade to scoop the condensate from the bottum of the base pan and splash the condenser coil to keep the condenser cool and also evaporate the condensate. Most of the time you can hear a "swishing sound"
Jun 19, 2012 | Quasar HQ2052UH Air Conditioner
Lincoln MKT - air conditioner won't stay cold
It could be any of a number of things:
  • Low refrigerant. An A/C system requires a certain amount of refrigerant to cool properly. If low, it works less efficiently and does not cool well.
  • Dirty condenser -- The condenser is the heat exchanger mounted in front of the radiator. It cools the high pressure refrigerant vapor after it exits the compressor so it can condense into a liquid. If the condenser is full of leaves, bugs and road debris, air flow through the unit may be blocked to the point where little cooling occurs. Cleaning the condenser should cure the problem.
  • Inoperative condenser cooling fan. The condenser often has its own separate electric cooling fan. This fan should come on and remain on when the A/C system is operating. If the fan motor, motor relay or wiring is defective, the fan may not be working.
  • Air or moisture contamination -- For the refrigerant inside the system to do its job properly, it must not be contaminated with air or moisture. Air reduces the cooling efficiency of the system while moisture can freeze and form ice that causes blockages in orifice tubes and metering valves. Air and moisture contamination may be the result of unrepaired leaks in the system, or failing to vacuum purge the system prior to recharging it with refrigerant.
  • Blockages -- Debris, rust or debris in the system may plug up the orifice tube or metering valve that admits refrigerant into the evaporator. If this vital point becomes obstructed, the flow of refrigerant may be restricted or blocked causing a loss of cooling -- and possible compressor damage as well in systems that rely on oil circulating with the refrigerant for lubrication.
  • Mechanical problem -- These include things like metering valve failures, compressor wear, a compressor clutch that fails to engage, bad pressure switches, etc.
  • Jul 16, 2011 | Air Conditioning and Heat for Lincoln MKT
    Air conditioning stopped working suddenly. power not getting to clutch . fuse ok
    It could be any of a number of things:in your case I would look under the hood at the fuses and relays there , here are some other things
  • Jul 14, 2011 | Air Conditioning and Heat for Toyota...
    I just went out to my 2002 Volvo XC70 and turned on the car. The A/C would not come on. I just had the compressor replaced a couple of months ago. Could it be a fuse? thanks for any help.
    yes it could be a fuse heres other items to check
  • Jul 14, 2011 | Air Conditioning and Heat for Volvo XC70
    Air conditioner turns on but no air comes out. does it works with a fuse or sensor if so where is it located in the scion tc 95. can someone help me or list the possibles problems that i can look out for...
  • Jul 14, 2011 | Air Conditioning and Heat for Scion xB
    AC COMPRESSOR CLUTCH WON'T ENGAGE.
    It could be any of a number of things: be sure and check the fuses and relays under the hood in that fuse panel , also the mail switch inside ,, you can jumper those contacts to see if it's the switch , here are some other ideas
  • Jul 13, 2011 | Air Conditioning and Heat for Hyundai...
    My 2006 Torrent air -con temperature dropped to in car temp. after 15, 20 minutes and will not get colder , why ? It was very cold when it started . I have to shut it down for a short time and turn it...
  • Jul 13, 2011 | Air Conditioning and Heat for Pontiac...
    What is the white part that holds water tubing on back of Amana refrigerator? It is leaking water around the tubing
    hi,
    tubing at the back refrigerator is the condenser, function of this is heat rejection that absorb from your evaporator inside your refrigerator,the white part of holding tube condenser is tube holder mounted by screw to hold condnser tubing has no relate inr efrigetration cycle.the screw use on tube holder was directly pin at the back side of eveporator where cooling effect emerge some ice melted or defrosted form water pass through on screw tube holder,you can fix loosen screw have some sealant pathced to hole where srcew located after a minute of drying time screw it again so that water leak may not come out to that tube holder through your condenser,
    well,if that leak does not harm or not make any trouble passing through your condenser its still good condenser need to be cooled so that refrigerant inside tube can flow on liguid state effeciently.on large refrigeration such as ice plant
    condenser was designed to have a water shower on tube called evaporative system.it make coole the condenser tube.
    this ideas can give you clear explanation why water leaking on tube condenser.have anice day rate me,thanks a lot
    May 04, 2009 | Refrigerators
    Amana window air conditioner unit keeps freezing.
    There are 2 causes for freezing. Lack of air flow or shortage of Freon. After defrosting, start the machine and look for an even pattern of water condensing on all the coils. If the cooling is even and complete on all the coils, see if the coil is so dirty that it restricts the air flow. The fan blade can build up dirt and need to be cleaned, too. If the cooling (condensation) is not complete, you have a Freon problem. Some of it could have leaked out or the metering tubes could be partially pllugged up (on the inside of them).
    Jul 22, 2008 | Amana Heating & Cooling
    Intertherm P3RA-060K Air Conditioner Logo
    115 people viewed this question
    Top Intertherm Heating & Cooling Experts
    Dennis Boxerman
    Bill Long
    john h
    Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
